Civil Engineering Association eBooks Codes, Manual & Handbook British Standards (BS) BS EN 1537
BS EN 1537
 epee
User ID: 5696
Threads: 7
Likes: 307 in 32 posts
Given Likes: 13
11-03-2009, 01:58 PM (This post was last modified: 12-11-2011, 08:01 AM by Grunf.)
BS EN 1537:2000
[Image: qmuyu0g5v2c1kt9g1cn.jpg]
Execution of special geotechnical work - Ground anchors
64pp
2.38mb
Download Links:
[-] The following 20 users Like epee's post:20 users Like epee's post
  • timosi™, concreteok, kowheng, Dell_Brett, vvvv, niki102, ruaumoko, eslamabdelgowad, Iktinos, nuttapolk, legarleon, chenamoy, zrilek, Chillpill, erimajus, ossmash, wanazri, utan, tuanpecc1, nhim4mat2006
 koldt
User ID: 5192
Threads: 4
Likes: 18 in 4 posts
Given Likes: 9
12-10-2011, 08:42 PM (This post was last modified: 12-11-2011, 12:09 AM by BennyP.)
[-] The following 7 users Like koldt's post:7 users Like koldt's post
  • Jackass, utan, Grunf, blaze, ting tsai huang, wanazri, serhioSPA
12-11-2011, 08:07 AM (This post was last modified: 12-11-2011, 08:07 AM by Grunf.)
[Image: comments.png]
Uploaded: Dec/11/2011, File Size: 622.69 kB, PDF, NOT-Paginated, NOT-Bookmarked, Searchable text, Secured.
[-] The following 3 users Like Grunf's post:3 users Like Grunf's post
  • Dell_Brett, 3fan, nhim4mat2006
 3fan
Romania
User ID: 29614
Threads: 161
Likes: 7,359 in 1,207 posts
Given Likes: 5546
08-02-2012, 12:11 PM
[-] The following 9 users Like 3fan's post:9 users Like 3fan's post
  • kowheng, blaze, AlmostThere, Dell_Brett, lisine, st77bel, oanm2000, pousin, durden
07-26-2015, 06:30 AM (This post was last modified: 07-26-2015, 06:23 PM by oanm2000.)
BS EN 1537:2013 Execution of special geotechnical works — Ground anchors
[Image: 78490772792476327683.jpg]
Author(s): Technical Committee CEN/TC 288 - Published By: CEN - Published Year: 2013 - Size: 1.56 MB - Quality:Original preprint
Abstract: 1.1 This European Standard covers ground anchors grouted into the ground which are stressed and tested.
They can be used for permanent or temporary applications.
NOTE For the purpose of this standard the term ‘anchor(s)’ refers to ‘ground anchor(s)’.
1.2 The anchors are designed in accordance with EN 1997-1 and are tested in accordance with prEN ISO 22477-5.
1.3 Typical bond and compression type anchors are shown in Figure 1 and Figure 2.
1.4 The term "ground" is taken to encompass soil, rock and fill already in place or existing prior to the execution of the construction work.
1.5 The planning and design of ground anchors calls for experience and knowledge in this specialised field.
1.6 The installation and testing phases require skilled, qualified labour and supervision.
1.7 This standard cannot replace the knowledge of specialist personnel and the expertise of experienced contractors required to apply this standard.
1.8 This standard does not address systems such as tension piles, screw anchors, mechanical anchors, soil nails, dead-man anchors or expander anchors as these do not fulfil the requirements of this standard.
[/align]
  • blaze, skyscraper, malc, zrilek, Dell_Brett, PinkPant, Jackass, hodzicemir, oanm2000, isurya, ting tsai huang, peixoto, Evandrojr, utan, nhim4mat2006
 f_slikken
User ID: 21091
Threads: 13
Likes: 910 in 88 posts
Given Likes: 778
07-27-2015, 08:46 AM
Mirror:
[-] The following 6 users Like f_slikken's post:6 users Like f_slikken's post
  • PinkPant, oanm2000, hodzicemir, knrsa, freequo, nhim4mat2006
01-10-2016, 03:33 PM
New Links for BS EN 1537:2013 Execution of special geotechnical works — Ground anchors
  • Dell_Brett, oanm2000, freequo, concreteok, malc, Rami11, knrsa, cace-01, f_slikken, PinkPant, temp1366, monter, nhim4mat2006
 concreteok
E-Book Moderator
Malaysia
User ID: 4764
Threads: 50
Likes: 4,962 in 637 posts
Given Likes: 3501
06-29-2020, 12:33 AM
concrete solution advocate
[-] The following 10 users Like concreteok's post:10 users Like concreteok's post
  • PinkPant, kowheng, jcbv, babakfeyzi, rami1976, Dell_Brett, tuanpecc1, CAMSECT, nhim4mat2006, oanm2000
Users browsing this thread: 11 Guest(s)
