Civil Engineering Association eBooks Codes, Manual & Handbook British Standards (BS) BS EN 16582, parts 1 - 3 Domestic swimming pools
Threads: 1,252
Likes: 25,491 in 1,924 posts
12-30-2017, 06:49 AM
Author(s)/Editor(s): CEN | Size: 4.34 MB | Format: PDF | Quality: Original preprint | Publisher: BSI | Year: 2015
[Image: 44796034319298013372.jpg]
BS EN 16582-1:2015
Domestic swimming pools Part 1: General requirements including safety and test methods
This European Standard specifies the general safety and quality requirements and test methods for domestic swimming pools. These requirements and test methods are applicable to inground, aboveground or recessed swimming pool structures, including their installation and means of access.
This standard does not apply to:
— pools for public use covered by EN 15288-1;
— spas for domestic or public use;
— paddling pools according to EN 71-8.
BS EN 16582-2:2015
Domestic swimming pools Part 2: Specific requirements including safety and test methods for inground pools This part of EN 16582 specifies the specific safety and quality requirements and test methods for domestic partially or fully inground swimming pools in addition to the general requirements of EN 16582-1 and shall be read in conjunction with it. The requirements of this specific standard take priority over those in EN 16582-1. These requirements and test methods are only applicable to partially or fully inground pool structures, including their means of access.
This European Standard applies to pools with a minimum water depth of more than 400 mm.
This European Standard does not apply to:
— pools of public use covered by EN 15288-1;
— paddling pools according to EN 71-8;
— domestic or public use spas.
BS EN 16582-3:2015
Domestic swimming pools Part 3: Specific requirements including safety and test methods for aboveground pools This part of EN 16582 specifies the specific safety and quality requirements and test methods for domestic aboveground swimming pools in addition to the general requirements of EN 16582-1 and shall be read in conjunction with it. The requirements of this standard take priority over those in EN 16582-1.
These requirements and test methods are applicable to aboveground pool structures, including their means of access.
👉 CLICK HERE 👈
👉 CLICK HERE 👈
  • zrilek, blaze, Andrew seah, PinkPant, rezart, Aviator, karthikeyans3d, cace-01, Dell_Brett, Trishu999, Paul, civilfafa, oanm2000, monter, malc
 rigid_joint
Senior Member
Jamaica
User ID: 6110
Threads: 13
Likes: 333 in 122 posts
Given Likes: 244
01-27-2023, 12:56 PM
Dear all, please provided new live links if it is possible! Thank you in advance!
