Civil Engineering Association eBooks General Books Response Surface Methodology
 rusty
Hungary
User ID: 17227
Threads: 68
Likes: 1,880 in 283 posts
Given Likes: 539
05-17-2013, 08:03 AM
Response Surface Methodology: Process and Product Optimization Using Designed Experiments
Author: Raymond H. Myers, Douglas C. Montgomery, Christine M. Anderson-Cook | Size: 22 MB (11MB) | Format: PDF (EPUB) | Quality: searchable | Publisher: Wiley; 3rd edition | Year: 2009 | pages: 704 | ISBN: 978-0470174463
[Image: 28926402500916341281.jpg]
Complete with updates that capture the important advances in the field of experimental design, Response Surface Methodology, Third Edition successfully provides a basic foundation for understanding and implementing response surface methodology (RSM) in modern applications. The book continues to outline the essential statistical experimental design fundamentals, regression modeling techniques, and elementary optimization methods that are needed to fit a response surface model from experimental data. With its wealth of new examples and use of the most up-to-date software packages, this book serves as a complete and modern introduction to RSM and its uses across scientific and industrial research.
This new edition maintains its accessible approach to RSM, with coverage of classical and modern response surface designs. Numerous new developments in RSM are also treated in full, including optimal designs for RSM, robust design, methods for design evaluation, and experiments with restrictions on randomization as well as the expanded integration of these concepts into computer software. Additional features of the Third Edition include:
Inclusion of split-plot designs in discussion of two-level factorial designs, two-level fractional factorial designs, steepest ascent, and second-order models
  • A new section on the Hoke design for second-order response surfaces
  • New material on experiments with computer models
  • Updated optimization techniques useful in RSM, including multiple responses
  • Thorough treatment of presented examples and experiments using JMP 7, Design-Expert Version 7, and SAS software packages
  • Revised and new exercises at the end of each chapter
  • An extensive references section, directing the reader to the most current RSM research
Assuming only a fundamental background in statistical models and matrix algebra, Response Surface Methodology, Third Edition is an ideal book for statistics, engineering, and physical sciences courses at the upper-undergraduate and graduate levels. It is also a valuable reference for applied statisticians and practicing engineers.
PDF
EPUB
[-] The following 4 users Like rusty's post:4 users Like rusty's post
  • blaze, Dell_Brett, kowheng, malc
 ska51
User ID: 11535
Threads: 427
Likes: 9,406 in 1,251 posts
Given Likes: 4017
12-15-2013, 02:28 PM
"Downstream is Weaker"
[-] The following 1 user Likes ska51's post:1 user Likes ska51's post
  • Dell_Brett
