Civil Engineering Association eBooks Bad Posts (eBooks) Super Mega Links Finite element Method and numerical methods
Thread Closed
 jgarciafic
Peru
User ID: 3150
Threads: 40
Likes: 749 in 61 posts
Given Likes: 281
09-01-2009, 06:04 AM (This post was last modified: 05-09-2010, 02:37 PM by Grunf.)
dear friends:
Is a pleasure for me to share with you these e-books of finite element method, boundary element, numerical methods and others this post contains 75 e-book (the books are in English and Spanish) in four links. I am a fan of the methods numeric and special of the finite element method.
thanks by yours replys
CONTENT OF LINKS
Adaptive Finite Element Methods for Differential Equations - Wolfgang angerth
An Introduction to Computer Simulation - Woolfson and Pert
Anisotropic Analysis Using Boundary Elements - N.A. Schclar.djvu
Applied Finite Element Analysis - Larry J. Segerlind
Basic Structured Grid Generation - M. Farrashkhalvat and J.P. Miles
Boundary Elements An Introductory Course - Brebbia and Dominguez
Boundary Methods Elements Contours and Nodes - Subrata Mukherjee
Delaunay Triangulation and Meshing - George & Borouchaki
Design of Adaptive Finite Element Software - Alfred Schmidt & Kunibert G. Siebert
Discontinuous Finite Elements in Fluid Dynamics and Heat Transfer - Ben Q. Li
Domain Decomposition Methods Algorithms and Theory - Andrea Toselli
Elsevier - Handbook of Numerical Analysis V1 Part1 - Finite Difference Methods
Elsevier - Handbook of Numerical Analysis V2 Part1 - Finite Element Methods
Elsevier - Handbook of Numerical Analysis V4 Part2 - Finite Element Methods
Elsevier - Handbook of Numerical Analysis V9 Part3 - Numerical Methods for Fluids
Engineering Analysis with ANSYS Software - Y. Nakasone and S. Yoshimoto
Error-Controlled Adaptive Finite Elements in Solid Mechanics - E. Stein
Finite Element Aanalysis - David W. Nicholson
Finite Element Analysis - Flaherty J.E
Finite Element Analysis of Composite Laminates - Ochoa and Reddy
Finite Element Analysis Theory and Applications with ANSYS - Saeed Moaveni
Finite Element Analysis with Error Estimators - J. E. Akin
Finite Element Based Fatigue Calculations - Bishop & Sherratt
Finite Element Method - Boundary Element Method - Peter Hunter
Finite Element Method - Fluid Dynamics - Zienkiewicz and Taylor
Finite Element Method - Solid Mechanics - Zienkiewicz and Taylor
Finite Element Method - The Basis - Zienkiewicz and Taylor
Finite Element Methods - Parallel-Sparse Statics and Eigen-Solutions - D.T.Nguyen.
Finite Element Methods and Their Applications - Zhangxin Chen
Finite Element Methods for Flow Problems - Jean Donea & Antonio Huerta
Finite Element Modeling for Stress Analysis - Robert D. Cook
Finite Elements for Nonlinear Continua & Structures - Belytschko
Finite Elements Using Maple - A Symbolic Programming Approach - Portela & Charafi
Finite Volume Methods for Hyperbolic Problems - Randall J. Leveque
Fundamentals of the Finite Element Method for Heat and Fluid Flow - Lewis Nithiarasu
Galerkin Finite Element Methods for Parabolic Problems - Vidar Thomee
Generalized Difference Methods for Differential Equations - Li Chen Wu
Handbook of Grid Generation - Thompson, Soni and Weatherill
Higher-Order Finite Element Methods - Pavel Solin
Introduction to PDEs - A Computational Approach - Tveito & Winther
Mesh Free Methods - Moving Beyond the Finite Element Method - G.R.Liu
Mesh Generation Application to Finite Elements - P.J. Frey & P.L. George
Mixed and Hybrid Finite Element Methods - Brezzi and Fortin M
Multifield Problems in Solid and Fluid Mechanics - Rainer Helmig
Multigrid - Trottenberg et al
Nonlinear Continuum Mechanics for Finite Element Analysis - Bonet & Wood
Non-linear Finite Element Analysis of Solids and Structures Vol.1 - M.A. Crisfield
Non-linear Finite Element Analysis of Solids and Structures Vol.2 - M.A. Crisfield
Nonlinear Stability of FV Methods for Hyperbolic Conservation Laws - Francois Bouchut
Numerical Methods for Elliptic and Parabolic PDEs - P. Knabner & L. Angermann
Numerical Methods for Partial Differential Equations - W.F. Ames
Numerical PDEs for Environmental Scientists and Engineers - D.R.Lynch
Numerical Solutions of PDEs by the Finite Element Method - Johnson
Numerical Treatment of Partial Differential Equations - Grossmann and Roos
Partial Differential Equations and the Finite Element Method - P. Solin
Process Modelling and Simulation with Finite Element Methods - William B. J. Zimmerman
Programming the Finite Element Method - I. M. Smith & D. V. Griffiths
Splines and Variational Methods - P. M. Prenter
Structural Analysis with Finite Elements - Friedel Hartmann & Casimir Katz
The Boundary Element Method in Engineering - A. A. Becker
The Boundary-Domain Integral Method for Elliptic Systems - Andreas Pomp
The Combined Finite-Discrete Element Method - Ante Munjiza
The Finite Element Method - Thomas J. R. Hughes
The Finite Element Method a Practical Course - G.R. Liu & S.S. Quek
The Finite Element Method for 3D Thermomechanical Applications - Guido Dhond
The Finite Element Method for Solid and Structural Mechanics - Zienkiewicz & Taylor
The Finite Element Method in Engineering - S.S. Rao
The Finite Element Method using MATLAB - Kwon and Bang
The FV, FD, & FE Methods as Numerical Methods for Physical Field Problems - Mattiussi
The Scaled Boundary Finite Element Method - Wolf J.P
The Theory of Difference Schemes - Alexander A. Samarskii
PD: The books are in format PDF and djvu
for format DJVU look at
Content of this section is hidden, You must be registered and activate your account to see this content.
👉 CLICK HERE 👈
The links:
size 190 MB
👉 CLICK HERE 👈
size 190 MB
👉 CLICK HERE 👈
size 190 MB
👉 CLICK HERE 👈
size 27.4 MB
👉 CLICK HERE 👈
Edit reason: Changed the colour of the text because it was hard to read it. (G)
[-] The following 32 users Like jgarciafic's post:32 users Like jgarciafic's post
  â€¢ abudabeeja, abudabeeja, kowheng, kowheng, Dell_Brett, Dell_Brett, cgedmundo, cgedmundo, zrilek, zrilek, dfense, dfense, Krause, pousin, Grunf, pedrozarth, cace-01, cristi, mgdario, saed, sanderos_10, Slyte, ilgar, fer962933, imran, patio085, adshrt, seb3k, yanburak, ruaumoko, user108, mishanya
