Civil Engineering Association eBooks Journals, Papers and Presentations Hysteretic energy response of steel moment-resisting frames with vertical mass irregu
 asim99
User ID: 9774
Threads: 461
Likes: 6,384 in 594 posts
Given Likes: 377
12-29-2012, 12:10 AM
Hysteretic energy response of steel moment-resisting frames with vertical mass irregularities
Author: BYONG JEONG CHOI | Size: 362 KB | Format: PDF | Quality: Unspecified | Publisher: BYONG JEONG CHOI | Year: 2004 | pages: 23
[Image: 45788426346267157899.jpg]
Dynamic analyses were carried out to study the seismic response of high-rise steel moment-resisting frames in
16-storey buildings. The frames are intentionally designed using three different design procedures: strengthcontrolled
design, strong column–weak beam controlled design, and drift-controlled design. The seismic performances
of the so-designed frames with vertical mass irregularities were discussed in view of drift ratio, plastic
hinge rotation, hysteretic energy input and stress demand. A demand curve of hysteretic energy inputs was also
presented with two earthquake levels in peak ground accelerations for a future design application.
[-] The following 5 users Like asim99's post:5 users Like asim99's post
  â€¢ kowheng, ting tsai huang, malc, blaze, Dell_Brett
  Seismic Design of Steel Special Moment Frames: A Guide for Practicing Engineers yanburak 2 8,760 08-04-2021, 08:44 PM
Last Post: Wijono
  Propagating Waves in the Steel, Moment-Frame Factor Building Recorded during Earthqua TAFATNEB 0 4,944 07-03-2015, 09:57 PM
  Retrofitting steel special moment frame using ADAS metallic yielding dampers TAFATNEB 0 5,199 12-28-2014, 08:45 AM
  Evaluation of Egyptian code provisions for seismic design of moment-resisting-frame m TAFATNEB 0 5,267 09-05-2014, 02:03 PM
  Dynamic response of bare steel concrete under human rhythmic activities TAFATNEB 0 4,257 08-14-2014, 07:39 AM
  Estimation of hysteretic energy demand using concepts of modal pushover analysis TAFATNEB 0 4,717 08-10-2014, 02:52 PM
  Evaluation of the seismic performance of a three-story ordinary moment-resisting conc TAFATNEB 0 4,171 04-26-2014, 06:25 PM
