Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Theses, Journals and Papers Request [REQUEST] ASCE Journal/Proceedings
[Request] ASCE Journal/Proceedings
12-04-2012, 08:22 AM
Dear members,
can someone upload this article:
PsD Test on Four-Story R/C Building Designed According to Eurocodes
Negro, P., Pinto, A., Verzeletti, G., and Magonette, G. E.
Journal of Structural Engineering, Vol. 122, No. 12, December 1996, pp. 1409-1417
Abstract:
An experimental program was conducted on a four-story full-scale reinforced concrete building designed as a ductility class “high” structure in accordance with Eurocodes 2 and 8. The activity was defined as part of a cooperative research program by the European Association of Structural Mechanics Laboratories. The pseudodynamic tests were conducted for a serviceability-level and high-level earthquake—1.5 times the reference accelerogram. The results of the pseudodynamic tests are presented. General conclusions about the performance of the structure are drawn, with attention paid to the effects of the adoption of the new high-strength B500 Tempcore steel. The results make it possible to discuss the influence of the modeling parameters to be used in predicting the behavior of this class of structures. Effects such as the pullout and the slippage of the bars in the joints, or the participation of the slab to the global stiffness were found to play a fundamental role.
Can be found here:
With regards,
 lisine
Vanuatu
User ID: 17927
Threads: 272
Likes: 11,709 in 1,305 posts
Given Likes: 4621
#312
12-04-2012, 09:07 AM
[-] The following 1 user Likes lisine's post:1 user Likes lisine's post
  • Grunf
 nickycruz
User ID: 13536
Threads: 9
Likes: 22 in 8 posts
Given Likes: 1111
#313
12-05-2012, 12:54 AM
Dear CiVILEANs,
I would like to ask for a paper about seismic design of communications tower, the name of the paper is:
Seismic Design of Communications Towers
Mark W. Fantozzi, P.E., SE, M.ASCE
Structures Congress 2006: 1-2.
Abstract | PDF (113 KB)
I would appreciate if anyone could share, thanks in advance! Grin
 Songoku
Azores
User ID: 2786
Threads: 29
Likes: 76 in 19 posts
Given Likes: 182
#314
12-07-2012, 12:20 AM
Joint effects on the behaviour of transmission towers
[-] The following 3 users Like Songoku's post:3 users Like Songoku's post
  • malc, apocalipse, kowheng
 apocalipse
Portugal
User ID: 41527
Threads: 105
Likes: 790 in 87 posts
Given Likes: 922
#315
12-07-2012, 09:40 AM (This post was last modified: 12-07-2012, 10:30 AM by apocalipse.)
Dear members,
Analysis of Flexible Transmission Lines
Authors:
by Alain H. Peyrot, M.ASCE, (Prof. of Civ. and Environmental Engrg., Univ. of Wisconsin, Madison, Wisc.) and Alain M. Goulois, (Research Engr., Electricite de France, Paris, France)
Abstract:
An iterative numerical procedure has been developed to analyze flexible transmission lines of arbitrary configuration. Conductors, ground, or guy wires are included as cable elements interconnected at linear or nonlinear supports. A single efficient subroutine determines the cable elements end forces, geometrics, and tangent stiffness matrices. Convergence of the procedure is very rapid as documented by two computer programs. Examples including broken conductors, unbalanced ice loads, longitudinal, or diagonal wind are presented. The procedure is absolutely general and can be extended to two-dimensional analyses of cable nets.
Can be found here:
With regards,
apocalipse
Dear members,
Probabilistic Design of Transmission Line Structure
Authors:
John D. Mozer1; Alain H. Peyrot, Members, ASCE2; and Anthony M. DiGioia, F. ASCE3
Abstract:
For many years, electric transmission line structures in the U.S. have been designed in accordance with the minimum load and strength requirements given in the National Electrical Safety Code (NESC). Transmission line designers have recognized certain deficiencies in the NESC and usually specify increased design loading requirements based on conditions in local service areas. This practice has led to a lack of uniformity in design criteria for transmission line structures in the U.S. and points to the need for a uniform design approach based on probabilistic concepts. A load and resistance factor design format is recommended in which the design factors are probability‐based. The design point method for reliability analysis is reviewed and a computer program which applies this method to transmission line structures is described. A calibration example is presented which illustrates the use of this program for establishing the level of reliability in an existing structure and the corresponding design factors. It is concluded that the methodology is quite suitable for application to transmission line structures and that sufficient data are available for determining the required design factors
Link:
With regards,
apocalipse
 ssobhan
User ID: 1054
Threads: 335
Likes: 8,975 in 1,182 posts
Given Likes: 2465
#316
12-07-2012, 11:45 AM
Dear apocalipse
Here get it;
[-] The following 2 users Like ssobhan's post:2 users Like ssobhan's post
  • apocalipse, kowheng
 realbabilu
User ID: 4534
Threads: 8
Likes: 130 in 23 posts
Given Likes: 55
#317
12-07-2012, 12:41 PM (This post was last modified: 12-07-2012, 12:47 PM by realbabilu.)
Dear my friend
could you find for me:
Design Method of a Hanger System for Long-Span Suspension Bridge
Stress Spikes in Pin and Hanger System of Truss Bridge
Investigation of a Cracked Hanger Plate Weld
 ssobhan
User ID: 1054
Threads: 335
Given Likes: 2465
#318
12-07-2012, 02:54 PM
Dear apocalipse
Here get it;
You can use "google book downloader" software to download this paper
 apocalipse
Portugal
User ID: 41527
Threads: 105
Given Likes: 922
#319
12-10-2012, 11:20 AM
Dear members,
can someone upload this publication
Electrical Transmission and Substation Structures 2009
Edited:
by Marlon W. Vogt, P.E.
Description:
Proceedings of the 2009 Electrical Transmission and Substation Structures Conference, held in Fort Worth, Texas, November 8-12, 2009. Sponsored by Electrical Transmission Structures Committee of the Structural Engineering Institute of ASCE.
This collection contains 45 papers on engineering issues regarding the structures used by the electric utility industry. Topics include loadings, analysis and design, foundations, substation design, applied technology, and case studies.
Link:
With regards,
apocalipse
 mary
User ID: 31558
Threads: 65
Likes: 341 in 77 posts
Given Likes: 692
#320
12-10-2012, 08:00 PM
Dear members, Hi
Luca de Sanctis and Alessandro Mandolini : Bearing Capacity of Piled Rafts on Soft Clay Soils
Journal of Geotechnical and Geoenvironmental Engineering, Volume 132, Issue 12 (December 2006)
regards
mary
Users browsing this thread: 26 Guest(s)
Pages (72): « Previous 1 … 27 28 29 30 31 32 33 34 35 36 37 … 72 Next »
  [REQUEST] ASCE Journal of Structural Engineering Vol. 132 (2006) mistahpablo 1 1,921 03-31-2017, 04:44 AM
Last Post: pezhmankhan
  [REQUEST] ASCE Journal of the Soil Mechanics and Foundation miquan 9 5,163 12-22-2014, 08:28 PM
Last Post: f_slikken
