Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Archive [REQUEST] Influence of Bolted-Joint Slippage on the Response of Transmission Towers Subjected t
[Request] Influence of Bolted-Joint Slippage on the Response of Transmission Towers Subjected t
 apocalipse
Portugal
User ID: 41527
Threads: 65
Likes: 790 in 87 posts
Given Likes: 922
12-06-2012, 10:59 PM (This post was last modified: 12-06-2012, 11:10 PM by apocalipse.)
Dear all, i appreciate if anyone could upload the following paper:
Influence of Bolted-Joint Slippage on the Response of Transmission Towers Subjected to Frost-Heave
Authors
K.I.E. Ahmed, R.K.N.D. Rajapakse, M.S. Gadala
Abstract
Slippage of bolted joints is an important factor in the behavior of transmission towers. Field inspections of towers located in the northern regions of Canada show substantial frost-heave induced displacements. The conventional structural analysis software solutions for tower leg axial forces, based on idealized joint behavior under field-observed frost-heave induced displacements, are excessively large, implying tower failure in some cases. However, field inspections show structurally stable towers, and design engineers often consider joint slippage as the main reason for this discrepancy. In this paper, the experimental slippage behavior of transmission-tower bolted joints investigated by Ungkurupanian (2000) is incorporated into a non-linear joint finite element and applied to study the behavior of transmission towers under working loads by using the finite element method. The analysis shows that tower-leg joint slippage has a significant influence on tower behavior by either reducing the load carrying capacity or significantly increasing the deflections under working loads. On the other hand, joint slippage has a positive effect on towers subjected to frost-heave induced displacements, as the resulting member axial forces are much lower than those corresponding to rigid joints.
The link to the paper
Thank you all.
  â€¢
 hich
User ID: 3732
Threads: 94
Likes: 5,003 in 418 posts
Given Likes: 101
12-07-2012, 08:09 AM
[-] The following 5 users Like hich's post:5 users Like hich's post
  â€¢ lisine, apocalipse, kowheng, Dell_Brett, nibbi
  [REQUEST] Sloshing Response of Floating Roofed Liquid Storage Tanks Subjected to Earthquakes of ssobhan 1 1,956 02-22-2014, 07:02 AM
Last Post: Mohammad6299
  [REQUEST] Dynamic Response of Lattice Towers and Guyed Masts f_slikken 0 1,790 07-21-2013, 03:51 AM
Last Post: f_slikken
  [REQUEST] influence of connection modelling on seismic response of moment resisting steel frame DamirDz 1 1,791 03-11-2013, 07:27 AM
Last Post: ssobhan
  [REQUEST] Influence of second order effects on the behavior of transmission line towers apocalipse 0 1,507 12-07-2012, 11:27 AM
Last Post: apocalipse
  [REQUEST] Numerical response of steel reinforced concrete slab subjected to blast and pressure david-smith 0 1,526 06-01-2012, 08:38 AM
Last Post: david-smith
  [REQUEST] Response of bridge structures subjected to blast loads and protection techniques jacs127 1 1,998 03-19-2011, 05:19 PM
Last Post: ssobhan
  [REQUEST] Joint Slip in Steel Electric Transmission Towers shmpabe 1 1,871 02-18-2011, 06:37 AM
Last Post: melkat
