Civil Engineering Association eBooks Journals, Papers and Presentations Dynamic Behaviour under Wind Loading of a 90 m Steel Chimney
 asim99
User ID: 9774
Threads: 461
Likes: 6,384 in 594 posts
Given Likes: 377
11-27-2012, 04:02 PM (This post was last modified: 07-30-2013, 05:36 PM by oanm2000.)
Author: Pär Tranvik, Göran Alpsten | Size: 5.25 MB | Format: PDF | Quality: Original preprint | Year: 2002 | pages: 159
[Image: 11185638233638321949.jpg]
This report presents results from an investigation of the structural behaviour of a 90 m high steel chimney equipped with a mechanical damper at the top. Due to a mistake in installing the chimney the damper was not active in the first period of service life, causing large oscillations of the structure and fatigue cracks to occur within a few months of service. Because of this an extensive investigation was started to rectify the action of the damper, repair the steel structure and to monitor the behaviour of the structure adopting a fail-safe principle. Data from four years of continuous measurements are presented in the report. VEAB of Växjö, Sweden is owner of the chimney, being part of a delivery of an electrostatic precipitator of the Sandvik II biomass power plant at Växjö. ABB Fläkt Industri AB of Växjö was contractor for the electrostatic precipitator including the chimney (activities of the company later subdivided between Alstom Power Sweden AB and ABB). The chimney was fabricated and erected by the subcontractor VL Staal A/S of Esbjerg, Denmark.
The authors are indebted to all parties involved for making it possible to present the results in this form. Special thanks are due to Mr Ulf Johnson of VEAB, Mr Lars Palmqvist of ABB Automation Systems AB, Mr Stig Magnell of Dryco AB, Messrs Rolf Snygg and Thomas Väärälä of Alstom Power Sweden AB, and Mr Stig Pedersen of VL Staal A/S.
The investigation presented in this report was initiated by VEAB, for which the second author acted as a consultant. The compilation of data and preparation of most parts of this report were made by the first author. The second author has acted mainly as advisor for the investigation.
[-] The following 11 users Like asim99's post:11 users Like asim99's post
  • david-smith, kowheng, jacs127, terrorruban, valinhas, zrilek, malc, Dell_Brett, slowet, blaze, KhaLed-S.E
 Dell_Brett
Admin Deputy
Admin Deputy
Brazil
User ID: 4
Threads: 246
Likes: 19,035 in 2,188 posts
Given Likes: 42494
07-30-2013, 03:16 PM
Direct Link:
[/MIRROR] 🔽🔽🔽🔽🔽🔽🔽🔽🔽
[-] The following 17 users Like Dell_Brett's post:17 users Like Dell_Brett's post
  • fred2010, rezart, Jackass, LiviuM, cace-01, SCREAM7890, blaze, oanm2000, jcbv, shadabg, andersen3, stigtg, subin91, dinu69in, femana, febo927, CAMSECT
  BEHAVIOUR OF STEEL SINGLE ANGLE COMPRESSION MEMBERS AXIALLY LOADED THROUGH ONE LEG asim99 1 5,350 10-15-2014, 11:00 PM
Last Post: KhaLed-S.E
  Loading Pattern and Spatial Distribution of Dynamic Wind Load and Comparison of Wind TAFATNEB 0 4,620 09-05-2014, 01:40 PM
  Dynamic response of bare steel concrete under human rhythmic activities TAFATNEB 0 4,205 08-14-2014, 07:39 AM
  Nonlinear Analysis of a Collapsed Reinforced Concrete Chimney TAFATNEB 0 4,366 08-10-2014, 02:59 PM
  Analysis and design of the prototype of a steel 1-MW wind turbine tower TAFATNEB 0 3,629 08-31-2013, 12:40 PM
  Dynamic Testing of Single- and Double-Story Steel-Sheathed Cold-Formed Steel-Framed S asim99 0 4,246 05-09-2013, 04:35 AM
  Wind pressures and buckling of cylindrical steel tanks with a conical roof asim99 0 4,012 04-02-2013, 11:42 PM
