Civil Engineering Association eBooks Structural Books Concrete Optimizing Cementitious Content in Concrete Mixtures for Required Performance
 mahyarov
User ID: 1197
Threads: 452
Likes: 3,226 in 534 posts
Given Likes: 1492
11-17-2012, 12:10 PM
Author: Taylor, Peter | Size: 1.82 MB | Format: PDF | Quality: Original preprint | Publisher: Iowa State University, Ames | Year: 2012 | pages: 54
[Image: 29162443856690287760.png]
This research investigated the effects of changing the cementitious content required at a given water-to-cement ratio (w/c) on workability, strength, and durability of a concrete mixture. An experimental program was conducted in which 64 concrete mixtures with w/c ranging between 0.35 and 0.50, cementitious content ranging from 400 to 700 per cubic yard (pcy), and containing four different supplementary cementitious material (SCM) combinations were tested. The fine-aggregate to total-aggregate ratio was fixed at 0.42 and the void content of combined aggregates was held constant for all the mixtures. Fresh (i.e., slump, unit weight, air content, and setting time) and hardened properties (i.e., compressive strength, chloride penetrability, and air permeability) were determined. The hypothesis behind this study is that when other parameters are kept constant, concrete properties such as strength, chloride penetration, and air permeability will not be improved significantly by increasing the cement after a minimum cement content is used. The study found that about 1.5 times more paste is required than voids between the aggregates to obtain a minimum workability. Below this value, water-reducing admixtures are of no benefit. Increasing paste thereafter increased workability. In addition, for a given w/c, increasing cementitious content does not significantly improve compressive strength once the critical minimum has been provided. The critical value is about twice the voids content of the aggregate system. Finally, for a given w/c, increasing paste content increases chloride penetrability and air permeability.
  â€¢ kowheng, Dell_Brett, portal61, pram
  Computer Modelling of Concrete Mixtures oanm2000 1 2,909 05-21-2019, 06:19 AM
  PCA Design and Control of Concrete Mixtures 15ed. ir_71 0 1,673 03-12-2016, 07:55 PM
  High Performance Concrete (Modern Concrete Technology) oanm2000 3 4,110 01-21-2016, 08:49 PM
Last Post: cargadory2k
  PCA: Design and Control of Concrete Mixtures i_kabir 6 5,736 07-15-2015, 10:48 AM
Last Post: f_slikken
  Fibre Reinforced cementitious Composites babak 3 3,541 07-04-2013, 01:23 PM
Last Post: ssobhan
  Supplementary Cementitious Materials to Enhance Durability of Concrete Bridge Decks mahyarov 1 2,025 11-30-2012, 07:48 AM
Last Post: Nilupa
  EB 111 - Cementitious Grouts and Grouting mybest 0 1,577 05-05-2012, 09:38 AM
Last Post: mybest
