Civil Engineering Association eBooks Structural Books Steel SCI P080: Fire resistant design of steel structures - A handbook to BS 5950: Part 8
Threads: 1,298
Likes: 25,490 in 1,924 posts
04-14-2011, 07:50 AM
Author: R M LawSon, G M Newman | Size: 10 MB | Format: PDF | Publisher: SCI | Year: 1990 | pages: 140 | ISBN: 1870004485
[Image: 96364616505778715845.jpg]
This publication covers the means of achieving the required fire resistance of steel structures used in building. It follows BS 5950: Part 8 ‘Code of Practice for Fire Resistant Design’ (1990), and describes the background to the Code Clauses. The publication is presented as a Handbook and is intended to be read as a narrative. Cross-references to the Code Clauses are included adjacent to the text.
The main Sections in the Handbook deal with the performance of steel at elevated temperatures, and the means of determining threis e in temperature of steel sectionsi n the standard fire. The evaluatiofn fire resistancei s treated in two ways: by performance based on tests, or alternatively, by calculation methods. The basis of the test approach is presented in terms of ‘limiting temperatures’ that have been determined for beams supporting floors and columns, as functions of the loads applied to them in fire conditions. The calculation approach used for flexural members, such as beams or floors, is called the ‘moment capacity’ method. The method of determining the required thicknesosf fire protection is new to the UK and is largely based on that put forward in the ‘European Recommendations for Fire Safety of Steel Structures’. It permits the calculation of thickness of protection as a functioonf the thermal properties at elevated temperatures of the materials used.
The other parts of the Handbook deal with particular structural forms, such as: shelf angle floors, composite floors, portal frames, and concrete-filled hollow sections. The concept of ‘natural fires’is also reviewed, although this is not strictly included in BS 5950: Part 8. Finally, a number of worked examples is provided.
  • Dell_Brett, kowheng, seriousboy, knrsa, hmwere, melkat, Clouseau, ziggywas1, jferrer, oanm2000, toa011, zrilek, Nilupa, sodapas, kmmh76, mahyarov, gulilero, bigone
Threads: 54
11-15-2012, 04:02 PM (This post was last modified: 11-16-2012, 12:14 AM by Dell_Brett.)
all links dead;
Post Edited by Moderator
  • blaze, gulilero, Trishu999, bigone
Threads: 54
05-14-2014, 05:33 AM
[-] The following 11 users Like andersen3's post:11 users Like andersen3's post
  • PinkPant, malc, Jackass, Dell_Brett, ting tsai huang, usman, zrilek, Mohammad6299, dinu69in, xpressmusic, bigone
  Behaviour and Design of Steel and Composite Connections in Fire carolinandra 0 3,057 01-10-2023, 12:16 AM
Last Post: carolinandra
  Steel Structures Design; For Lateral and Vertical Forces carolinandra 3 4,228 01-07-2022, 02:44 AM
Last Post: Veggeta
  Ductile Design of Steel Structures 2nd lamkin 8 7,371 09-06-2021, 04:15 AM
  Ultimate Limit State Design of Steel-Plated Structures apocalipse 2 2,990 11-19-2020, 03:16 PM
Last Post: Kurucz
  ECCS - European Recommendations for the Design of Simple Joints in Steel Structures agelos100 0 1,783 05-14-2020, 09:19 AM
Last Post: agelos100
  Advanced Steel Design of Structures carolinandra 1 2,365 01-08-2020, 08:58 AM
Last Post: kirankumarklk
  Design of Joints in Steel and Composite Structures amindoxiti 3 3,654 12-17-2019, 06:53 AM
