Civil Engineering Association eBooks Structural Books Bridge (Project and Technology) SELF-STRESSED SANDWICH BRIDGE DECKS
 mahyarov
User ID: 1197
Threads: 452
Likes: 3,226 in 534 posts
Given Likes: 1492
11-10-2012, 01:06 PM
Author: Zuk, W Sinha, R | Size: 1.56 MB | Format: PDF | Quality: Original preprint | Publisher: Virginia Highway Research Council | Year: 1971 | pages: 46
[Image: 00792308068363521788.png]
PRESENTED IS AN ENTIRELY NEW TYPE OF BRIDGE DECK, CONSISTING OF AN UNREINFORCED LIGHTWEIGHT CONCRETE SLAB MADE OF EXPANDING CEMENT SANDWICHED BETWEEN TWO THIN PLATES OF STEEL. THE EXPANDING CORE SERVES TO PRESTRESS THE PANEL. LABORATORY TESTS WERE CONDUCTED ON THE CONCRETE TO DETERMINE PREDICTABLE RELATIONSHIPS FOR EXPANSION. LABORATORY TESTS WERE ALSO CONDUCTED ON TEN SMALL SCALE PANELS, SOME LOADED WITH A CONCENTRATED LOAD AND OTHERS WITH A UNIFORMLY DISTRIBUTED LOAD. INSTRUMENTATION WAS INSTALLED TO MEASURE STRAINS AND DEFLECTIONS. MATHEMATICAL THEORIES WERE ALSO DEVELOPED TO PREDICT BOTH THE PRESTRESSING AND EXTERNAL LOAD BEHAVIOR OF THE PANELS. A SATISFACTORY CORRELATION WAS FOUND BETWEEN THE TEST RESULTS AND THE THEORY. A COMPARATIVE STUDY OF THE PROPOSED SANDWICH PANELS AND STANDARD REINFORCED CONCRETE SLABS INDICATED THAT THE PROPOSED SANDWICH PANELS ARE SUBSTANTIALLY STRONGER AND STIFFER THAN CONCRETE SLABS USING THE SAME QUANTITY OF CONCRETE AND STEEL. /AUTHOR/
  â€¢ blaze, jcbv, kowheng, Dell_Brett
  The Design of Pre-Stressed Concrete Bridges Ultra Zone 15 12,176 03-02-2016, 04:17 PM
Last Post: ibg0203
  Bridge Decks: Design, Construction, Rehabilitation, Replacement amindoxiti 0 1,898 01-06-2015, 04:08 PM
  Application of Precast Decks and Other Elements to Bridge Structures mahyarov 0 2,255 11-13-2012, 10:40 AM
Last Post: mahyarov
  Laser Welded Steel Sandwich Panel Bridge Deck Development mahyarov 0 1,834 11-13-2012, 10:35 AM
Last Post: mahyarov
  Performance load testing and structural adequacy evaluation of road bridge decks mahyarov 0 1,781 11-07-2012, 02:18 PM
Last Post: mahyarov
  Finite Element Analysis of Deep Wide-Flanged Pre-stressed Girders to Understand and C mahyarov 0 1,420 10-29-2012, 07:02 AM
Last Post: mahyarov
  Damage Detection and Repair Methods for GFRP Bridge Decks mahyarov 0 1,664 10-29-2012, 06:53 AM
Last Post: mahyarov
