11-09-2012, 07:18 AM
hi guys, i have this small project to design for a pool at the beach in sea water. i would appreciate it if anyone can point me in the right direction.
best Regards
best Regards
best Regards
11-09-2012, 07:30 AM
As per my awareness,
This topic has been discussed earlier on this forum. You may refer to the following links for proper understanding : Code: Content of this section is hidden, You must be registered and upgrade your account to see this content.See this link to read how you can remove this limitation: 👉 CLICK HERE 👈 I hope this will help you. Still the forum is open to discuss, in case of further confusion or non-clarity.
Shadab "Dream till you Live, Chase till you Die"
11-09-2012, 07:35 AM
@ernestrazk
1- What is the size of the pool 2- depths 3- Make sure you use pile 4- Analyze the pool for bouyancy for its empty condition 5- Provide at least fc'=4000 psi concrete 6- Min. of 4 inches of clear cover If you need more info, please post Regards
11-09-2012, 09:19 AM
Proper care should be taken, while design the water retaining structures.
As per dear friend "ykhackhack", Pool should be designed for empty conditions, because in this case, there will not be any counter pressure acting. so Max tension will be consider. Moody's chart should be used for determining the constant in designing for Water Retaining Structure.
Shadab "Dream till you Live, Chase till you Die" |
