Civil Engineering Association eBooks Codes, Manual & Handbook British Standards (BS) BS EN 14731:2005 Execution of special geotechnical works - Ground treatment by deep v
Threads: 1,298
03-23-2012, 12:47 PM
BS EN 14731:2005 Execution of special geotechnical works - Ground treatment by deep vibration
Author: Technical Committee CEN/TC 288 | Size: 0.3 MB | Format: PDF | Quality: Original preprint | Publisher: CEN | Year: 2005 | pages: 25
[Image: 37153418467188976329.jpg]
This European Standard is applicable to the planning, execution, testing and monitoring of ground treatment by deep vibration achieved by depth vibrators and compaction probes.
The following types of treatment are covered by this European Standard:
- deep vibratory compaction to densify the existing ground;
- vibrated stone columns to form a stiffened composite ground structure by the insertion of granular material which itself shall be densified. Generally, stone columns have a diameter greater than 0,6 m and lower than 1,2 m.
The following treatment methods are covered by this European Standard:
- methods in which depth vibrators, containing oscillating weights which cause horizontal vibrations, are inserted into the ground;
- methods in which compaction probes are inserted into the ground using a vibrator which remains at the ground surface and which in most cases oscillates in a vertical mode.
Treatment methods are outlined in Annexes A and B.
The following treatment methods, among others, are not included in this European Standard:
- methods in which sand or stone columns are installed by means of impact or top vibratory driven casing;
- methods in which very stiff columns are formed either by the addition of cement to granular material or by the use of concrete or any other binder;
- dynamic compaction and other methods in which some form of treatment is applied to the ground surface;
- explosive compaction.
  • 3fan, kowheng, allagui10, jonev, sodapas, nhim4mat2006, st77bel, zrilek, Dell_Brett, malc, Jackass, vpmohammed, planeti_x, peixoto, mahyarov, superberti
 st77bel
Romania
User ID: 12964
Threads: 16
Likes: 432 in 86 posts
Given Likes: 696
11-02-2012, 06:58 PM (This post was last modified: 11-02-2012, 06:59 PM by st77bel.)
New working link:
Password:
[-] The following 7 users Like st77bel's post:7 users Like st77bel's post
  • utan, blaze, cace-01, zrilek, pousin, krishna22045, rizal13
  BS EN 12063:1999 Execution of special geotechnical work - Sheet-pile walls ir_71 4 4,092 06-29-2020, 02:50 AM
  BS EN ISO 22476:2005 part 2, 3 Geotechnical Investigation and Testing mybest 7 5,394 02-28-2017, 06:03 AM
  BS EN 1538:2010 execution of special geotechnical works diaphragm walls rishimaxi 1 2,033 02-06-2013, 06:09 PM
Last Post: 3fan
