Civil Engineering Association eBooks Structural Books Bridge (Project and Technology) Evaluation of a Highway Bridge Constructed Using High Strength Lightweight Concrete B
 mahyarov
User ID: 1197
Threads: 452
Likes: 3,226 in 534 posts
Given Likes: 1492
10-30-2012, 08:13 AM (This post was last modified: 10-30-2012, 08:14 AM by mahyarov.)
Evaluation of a Highway Bridge Constructed Using High Strength Lightweight Concrete Bridge Girders
Author: Holland, R Brett | Size: 2.46 MB | Format: PDF | Quality: Original preprint | Publisher: Georgia Institute of Technology, Atlanta | Year: 2011 | pages: 112
[Image: 11112204882168287622.png]
The use of high performance concretes to provide longer bridge spans has been limited due to the capacity of existing infrastructure to handle the load of the girders during transportation. The use of High Strength Lightweight Concrete (HSLW) can provide the same spans at a 20% reduction in weight. This paper presents the findings from an ongoing performance evaluation of HSLW concrete bridge girders used for the I-85 Ramp “B” Bridge crossing SR-34 in Coweta County, Georgia,. The girders are AASHTO BT-54 cross-sections with a 107 ft 11½ in. (32.9 m) length cast with a 10,000 psi (68.9 MPa) design strength HSLW mix and an actual average unit weight of 120 lb/ft³ (1922 kg/m³). The prestressing losses measured experimentally by embedded vibrating wire strain gauges have been compared to the AASHTO LRFD loss equations, as well as the proposed methods by Tadros (2003) and Shams (2000). The investigation also included camber measurements and the effect of temperature changes. A load test was performed on the girders at 56-days of age and on the bridge after completion of construction to determine a stiffness estimator for use with the girders and to determine their performance as a completed system. The girders are the first use of HSLW girders in the state of Georgia, and they have proven to perform well for use in highway bridges.
[-] The following 3 users Like mahyarov's post:3 users Like mahyarov's post
  • kowheng, cace-01, SCREAM7890
  Bridge Engineering: Design, Rehabilitation, and Maintenance of Modern Highway Bridges poolmand 0 3,153 07-13-2021, 05:54 AM
  Bridge Engineering: Rehabilitation, and Maintenance of Modern Highway Bridges Dell_Brett 12 9,594 10-16-2018, 05:18 PM
Last Post: febo927
  Highway Bridge Maintenance Planning and Scheduling - 1st Edition febo927 0 1,722 09-25-2018, 12:35 PM
Last Post: febo927
  Highway Bridge Superstructure Engineering: LRFD Approaches to Design and Analysis cace-01 3 3,629 07-04-2018, 11:44 AM
Last Post: febo927
  Track-Bridge Interaction on High-Speed Railways ir_71 4 4,591 08-11-2016, 04:21 PM
Last Post: Kurucz
  Bridge Design and Evaluation: LRFD and LRFR ir_71 3 3,903 04-30-2016, 11:01 AM
  Bridge and Highway Structure Rehabilitation and Repair Learner 18 11,483 11-02-2015, 05:53 PM
Last Post: ibg0203
