Civil Engineering Association eBooks Structural Books Bridge (Project and Technology) Design Aids of NU I-Girders Bridges
 mahyarov
User ID: 1197
Threads: 452
Likes: 3,226 in 534 posts
Given Likes: 1492
10-30-2012, 07:59 AM
Author: Hanna, Kromel E University of Nebraska, Lincoln Morcous, George Tadros, Maher K University of Nebraska, Lincoln | Size: 2.34 MB | Format: PDF | Quality: Original preprint | Publisher: University of Nebraska, Lincoln | Year: 2012 | pages: 41
[Image: 03787228753681619573.png]
Precast prestressed concrete I-Girder bridges have become the most dominant bridge system in the United States. In the early design stages, preliminary design becomes a vital first step in designing an economical bridge. Within the state of Nebraska, the two standard precast prestressed products used are Inverted Tee (IT) girders and University of Nebraska (NU) I girders. In the early 1990s, Nebraska Department of Roads (NDOR) developed design charts for NU-I girders in order to assist in member selection and preliminary design. In 2004, design charts were developed for IT girders. However, the NU-I girder charts have since become obsolete because they were developed for low strength concrete (6 ksi) and 0.5 inch prestressing strands. In addition, the charts were based off of American Association of State Highway and Transportation Officials (AASHTO) standard specifications. Since then, NDOR has adopted AASHTO Load and Resistance Factor Design (LRFD) specifications for superstructure design and the Threaded Rod (TR) continuity systems in their standard practice. Therefore, the new design charts are based on the latest AASHTO LRFD Specifications for superstructure design and NDOR Bridge Operations, Policies, and Procedures (BOPP manual). With the increasing use of 0.6 and 0.7 inch diameter strands as well as increasing concrete strengths, there is a need for new preliminary design charts for NU-I girders. The new design aids provide bridge designers with different alternatives of girder section size (from NU900 to NU2000), girder spacing (from 6-12 ft), prestressing strands (up to 60), prestressing strand diameter (from 0.6 to 0.7 inch), and compressive strength of concrete (from 8 ksi to 15 ksi). Two sets of design charts are developed to cover simple span and two-span continuous bridges. Each set contains two different types of charts: summary charts and detailed charts. Summary charts give designers the largest possible span length allowed given girder spacing, concrete strength, and NU-I girder sections. Detailed charts give designers the minimum number of prestressing strands required given girder spacing, span length, and concrete strength. Both sets of charts provide designers with the limit state that controls the design. If needed, this allows the design to be optimized in an efficient manner.
[-] The following 12 users Like mahyarov's post:12 users Like mahyarov's post
  â€¢ kowheng, cace-01, amadoo02, isurya, slowet, aslam, melekeen, oanm2000, knrsa, hignacio43, malc, xpressmusic
 amadoo02
Egypt
User ID: 1374
Threads: 5
Likes: 235 in 40 posts
Given Likes: 48
10-30-2012, 10:03 AM
Thanks for your share, I had the chance to work on a proposal with NU Precast girders.
iits major advantages are :-
1- thin web. hence, lighter self-weight.
2- maximum depth comparing to other precast elements of the same self-weight.
3- quite big bottom flange that fits for up to 60 * 0.6" strands.
4- wide top flange which reduces the precast slab span and provide large area for negative reinforcement.
[-] The following 2 users Like amadoo02's post:2 users Like amadoo02's post
  â€¢ blaze, aslam
  Seismic Design Aids for Nonlinear Pushover Analysis of Reinforced Concrete and Steel lamkin 12 8,827 11-23-2015, 03:22 PM
Last Post: ibg0203
  CADOT: Bridge Design Aids niki102 1 3,598 09-04-2011, 05:00 AM
Last Post: rusty
