Civil Engineering Association eBooks Structural Books Concrete Nanotechnology-Based System for Damage-Resistant Concrete Pavements
 mahyarov
User ID: 1197
Threads: 452
Likes: 3,226 in 534 posts
Given Likes: 1492
10-29-2012, 06:22 AM
Author: Al-Rub, Rashid K Abu | Size: 3.97 MB | Format: PDF | Quality: Original preprint | Publisher: Texas A&M University | Year: 2012 | pages: 124
[Image: 38167438070402929406.png]
The focus of this study was to explore the use of nanotechnology-based nanofilaments, such as carbon nanotubes (CNTs) and nanofibers (CNFs), as reinforcement for improving the mechanical properties of Portland cement paste and creating multifunctional and sensing concrete. Due to their ultra-high strength and very high aspect ratios, CNTs and CNFs have been excellent reinforcements for enhancing the physical and mechanical properties of polymer, metallic, and ceramic composites. Very little attention has been devoted to exploring the use of nanofilaments in the transportation industry, however. Therefore, this study aimed to bridge the gap between nanofilaments and transportation materials. This was achieved by testing the integration of CNTs and CNFs in ordinary Portland cement paste through state-of-the-art techniques. Different mixes in fixed proportions (e.g., water-to-cement ratio, air content, admixtures) along with varying concentrations of CNTs or CNFs were prepared. Different techniques commonly used for other materials (like polymers) were used in achieving uniform dispersion of nanofilaments in the cement paste matrix and strong nanofilament/cement bonding. Small-scale specimens were prepared for mechanical testing in order to measure the modified mechanical properties as a function of nanofilament concentration, type, and distribution. With 0.1% CNFs, the ultimate strain capacity increased by 142%, the flexural strength increased by 79%, and the fracture toughness increased by 242%. A scanning electron microscope was used to discern the difference between crack bridging and fiber pullout. Test results showed that the strength, ductility, and fracture toughness can be improved with the addition of low concentrations of either CNTs or CNFs.
[-] The following 2 users Like mahyarov's post:2 users Like mahyarov's post
  â€¢ kowheng, blaze
  Damage and Cracking of Concrete Structures: From Theory to Practice poolmand 0 3,304 01-01-2023, 10:31 AM
  Blast Resistant Design Guide for Reinforced Concrete Structures Nita1391 2 2,903 05-01-2019, 02:34 AM
  Mechanical damage and crack growth in concrete amindoxiti 0 1,670 09-25-2014, 12:04 PM
  Alkali-Aggregate Reaction and Structural Damage to Concrete: Engineering Assessment, ir_71 3 2,680 08-04-2014, 06:33 AM
Last Post: ssobhan
  Ultra-High Performance Concrete and Nanotechnology in Construction ir_71 1 2,004 03-05-2014, 06:56 AM
Last Post: al_frd
  Rubblization of Portland Cement Concrete Pavements mahyarov 0 1,635 10-27-2012, 09:02 AM
Last Post: mahyarov
  Effects of Subsurface Drainage on Performance of Asphalt and Concrete Pavements mahyarov 0 1,455 10-24-2012, 09:48 AM
Last Post: mahyarov
