Civil Engineering Association eBooks Geotechnical Engineering Soil Investigation and Mechanics Modeling of Pile Footings and Drilled Shafts for Seismic Design
 mahyarov
User ID: 1197
Threads: 452
Likes: 3,226 in 534 posts
Given Likes: 1492
10-27-2012, 06:28 PM
Author: Polam, I Earth Mechanics Incorporated Kapurskar, M Earth Mechanics Incorporated Chaudhuri, D | Size: 7.55 MB | Format: PDF | Quality: Original preprint | Publisher: Earth Mechanics Incorporated | Year: 1998 | pages: 162
[Image: 85355695450979134225.png]
This report documents two studies that were conducted to review, assess, and provide recommendations regarding the seismic design of bridge foundations. Specifically, the report addresses modeling approaches and parameters that affect the seismic design and response of pile groups and drilled shafts. The report attempts to bridge the interface between the structural and geotechnical design process by describing a two-step design and analysis procedure for these bridge foundation components. Recent research results on pile group effects and the design of pile foundations to resist lateral spreading of liquefiable soils are also reviewed. Recommendations are provided concerning: modifications to p-y curves to account for cyclic loading conditions, pile group effects and soil-pile interaction behavior, and development of p-y curves for the design of drilled shafts.
  â€¢ blaze, ruaumoko, cace-01, Evandrojr, kowheng, parhyang, malc, isurya, rizal13
  Group Efficiencies of Grout-Tipped Drilled Shafts and Jet-Grouted Piles mahyarov 0 1,803 10-27-2012, 07:54 PM
Last Post: mahyarov
  Modeling of Laterally Loaded Drilled Shafts Behind Mechanically Stabilized Earth Bloc mahyarov 0 1,741 10-27-2012, 07:44 PM
Last Post: mahyarov
  Drilled Shaft Bridge Foundation Design Parameters and Procedures for Bearing in SGC S mahyarov 0 1,700 10-27-2012, 07:41 PM
Last Post: mahyarov
  Design of Inclined Loaded Drilled Shafts in High-Plasticity Clay Environment mahyarov 0 1,803 10-27-2012, 07:38 PM
Last Post: mahyarov
