Civil Engineering Association eBooks Structural Dynamics and Earthquake Engineering INFLUENCE OF SOIL SOFTENING AND LIQUEFACTION ON RESPONSE SPECTRA FOR BRIDGE DESIGN
 mahyarov
User ID: 1197
Threads: 452
Likes: 3,226 in 534 posts
Given Likes: 1492
10-27-2012, 05:53 PM
Author: Youd, T L Carter, B | Size: 18.50 MB | Format: PDF | Quality: Original preprint | Publisher: Brigham Young University | Year: 2003 | pages: 159
[Image: 70829866692142331124.png]
The purpose of this investigation is to assess the adequacy of seismic bridge design criteria and to suggest modifications to account for the influence of soil softening and liquefaction. To define the influence of soil softening on response spectra and assess the adequacy of LRFD seismic criteria, records are analyzed from five sites underlain by soils that liquefied. Findings are: (1) Where pore water pressures rose early during ground shaking, soil softening reduced short period (<0.7 sec) spectral accelerations. (2) Where soil softening did not occur early, softening has little influence on short period (<0.7 sec) ground motions. (3) Soil softening usually causes enhanced long-period (>0.7 to 1.0 sec) spectral values due to the onset of ground oscillation that persisted after strong ground shaking ceases. (4) For short fundamental periods (< 0.7 sec), LRFD acceleration coefficients, A, of either 0.60 g or 0.30 g and Code Soil Profile Types (CSPT) III or IV, elastic seismic design coefficients, Csm, conservatively envelope calculated spectra, indicating that criteria in the LRFD code are adequate for liquefiable sites. (5) For structures with fundamental periods >0.7 sec, an A of 0.60 g and a CSPT IV generates Csm, that conservatively envelope the calculated actual response spectra. (6) For design at liquefiable sites, increased ground deformation within the liquefied zone must be considered.
  â€¢ blaze, cace-01, oanm2000, mgdario
  Earthquake Spectra and Design (Engineering monographs on earthquake criteria, structu preceptor 7 4,002 08-04-2021, 01:58 PM
Last Post: cace-01
  Soil Liquefaction During Earthquakes asim99 3 3,541 07-26-2018, 06:31 PM
Last Post: febo927
  Soil Liquefaction during Recent Large-Scale Earthquakes Saze808 3 2,955 03-30-2016, 04:01 PM
Last Post: ibg0203
  SEISMIC RESPONSE OF INTEGRAL BRIDGE CONNECTIONS mahyarov 0 1,660 10-27-2012, 06:07 PM
Last Post: mahyarov
  Seismic Response of Precast Segmental Bridge Superstructures mahyarov 0 1,613 10-27-2012, 03:28 PM
Last Post: mahyarov
  Advances in Geotechnical Earthquake Engineering - Soil Liquefaction and Seismic Safet ssobhan 1 2,247 07-27-2012, 08:46 AM
Last Post: shadabg
  Seismic Design And Evaluation Of Multistory Buildings Using Yield Point Spectra miquan 1 2,330 07-11-2011, 06:42 AM
