Civil Engineering Association eBooks Structural Dynamics and Earthquake Engineering Seismic Response of Telescopic Pipe Pin Connections
 mahyarov
User ID: 1197
Threads: 452
Likes: 3,226 in 534 posts
Given Likes: 1492
10-27-2012, 03:11 PM
Author: Doyle, Kelly A | Size: 8.19 MB | Format: PDF | Quality: Original preprint | Publisher: University of Nevada | Year: 2008 | pages: 182
[Image: 48471359543088402022.png]
Two-way hinges are often used in reinforced concrete bridge columns to prevent excessive flexural stresses from entering the connection to the superstructure or the footing. A study was undertaken for Caltrans to understand the behavior of pipe pin connections to help develop a simple and reliable design method. Two 0.3 scale specimens were constructed and tested under cyclic loading to determine if the models behave in pure shear and to study the effect of rotation on the connection behavior and strength. Analytical studies of a simple method gave the foundation for the development of a design method. A sensitivity analysis of the equations revealed that using the ultimate stress of the pipe (rather than the yield stress) in calculations leads to a close estimate of the actual ultimate connection capacity. If yielding is to be avoided in the pin, however, the pipe yield stress should be used in the simple method.
  â€¢ blaze, cace-01, kowheng, malc
  Smart Structures Innovative Systems for Seismic Response Control TAFATNEB 0 3,270 06-28-2024, 08:15 AM
  Structural Damping: Applications in Seismic Response Modification (Advan in EQ. Engg) asim99 6 5,064 06-18-2018, 02:01 PM
Last Post: febo927
  Seismic Ground Response Analysis cace-01 1 2,212 02-20-2015, 04:12 PM
Last Post: Veggeta
  Smart Structures: Innovative Systems for Seismic Response Control oanm2000 6 5,031 11-28-2014, 08:06 AM
  Response Spectrum Method in Seismic Analysis and Design of Structures parhyang 4 5,644 06-18-2014, 06:01 AM
Last Post: bigone
  SEISMIC RESPONSE OF INTEGRAL BRIDGE CONNECTIONS mahyarov 0 1,698 10-27-2012, 06:07 PM
Last Post: mahyarov
  Seismic Response of Precast Segmental Bridge Superstructures mahyarov 0 1,652 10-27-2012, 03:28 PM
Last Post: mahyarov
