Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Theses, Journals and Papers Request [REQUEST] Scitation and Sciencedirect/Elsevier JOURNAL
[Request] Scitation and Sciencedirect/Elsevier JOURNAL
 hessi
User ID: 31872
Threads: 21
Likes: 116 in 18 posts
Given Likes: 75
#211
10-23-2012, 01:54 AM
My dear friends that access elsevier
I would be pleased and appreciate if you prepare these papers.
 Badis
Senior Member
User ID: 16671
Threads: 53
Likes: 2,308 in 169 posts
Given Likes: 221
#212
10-23-2012, 05:43 AM
to ”hessi”
5 papers
[-] The following 6 users Like Badis's post:6 users Like Badis's post
  • malc, lisine, hessi, zrilek, Dell_Brett, ska51
 Songoku
Azores
User ID: 2786
Threads: 16
Likes: 76 in 19 posts
Given Likes: 182
#213
10-23-2012, 09:51 AM (This post was last modified: 10-23-2012, 10:39 AM by lisine.)
Dear colleagues,
I'm interested in the following papers. Can someone help:
1. A Newmark-based method for the stability of columns
M.A. Bradford
2. Second order effects in slender concrete columns-reformulation of the Eurocode 2 method based on nominal curvature
Helena Barros, Vitor D. Silva, Carla Ferreira
3. An approximate nonlinear design procedure for partially prestressed concrete beams
Antoine E. Naaman
4. An improved design formula for a biaxially loaded slender RC column
Hyo-Gyoung Kwak, Ji-Hyun Kwak,
5. Pre-stressing and Eurocode E.C.2
Marco A. Pisani
6. Stability design of steel plane frames by second-order elastic analysis
Hirotaka Oda
Thanks in advance.
 lisine
Vanuatu
User ID: 17927
Threads: 265
Likes: 11,713 in 1,307 posts
Given Likes: 4630
#214
10-23-2012, 10:33 AM (This post was last modified: 10-23-2012, 10:40 AM by lisine.)
[-] The following 2 users Like lisine's post:2 users Like lisine's post
  • zrilek, ska51
 giguni
User ID: 20677
Threads: 73
Likes: 208 in 33 posts
Given Likes: 166
#215
11-06-2012, 06:17 PM
Surface-Wave Group-Velocity Tomography for Shallow Structures
Leland Timothy Long Argun H. Kocaoglu
J. Environ. Eng. Geophysics 6, 71 (2001)
Thanks.
 marion33
Poland
User ID: 15632
Threads: 28
Likes: 501 in 66 posts
Given Likes: 885
#216
11-08-2012, 03:14 PM (This post was last modified: 11-08-2012, 03:33 PM by lisine.)
1. Benchmarks for finite element modelling of bolted steel connections
2. Numerical analyses of steel beam–column joints subjected to catenary action
3. Experimental and numerical analysis of three-dimensional semi-rigid steel joints under non-proportional loading
4. Numerical simulation of steel pretensioned bolted end-plate connections of different types and details
5. Experimental and numerical analysis of single-lap joints for the automotive industry
6. Numerical and experimental analyses of damage behaviour of steel moment connection
7. The finite element analysis of the ultimate behavior of thin-walled carbon steel bolted connections
8. Finite element modeling of bolted connections between cold-formed steel strips and hot rolled steel plates under static shear loading
9. Finite element analysis and experimental study on high strength bolted friction grip connections in steel bridges
10. Finite element analysis of steel beam to column connections subjected to blast loads
I need this papers.
Please upload. Thank You in advance.
 ssobhan
User ID: 1054
Threads: 224
Likes: 8,975 in 1,182 posts
Given Likes: 2465
#217
11-08-2012, 03:56 PM (This post was last modified: 11-08-2012, 04:00 PM by ssobhan.)
Dear marion33
All links are direct;
[-] The following 5 users Like ssobhan's post:5 users Like ssobhan's post
  • kowheng, marion33, zrilek, Dell_Brett, ska51
 lisine
Vanuatu
User ID: 17927
Threads: 265
Given Likes: 4630
#218
11-08-2012, 04:18 PM (This post was last modified: 11-08-2012, 04:19 PM by lisine.)
Papers for marion33
Papers 3,4,8
Papers 2,7,9
Paper 5
Paper 6
Paper 10
[-] The following 3 users Like lisine's post:3 users Like lisine's post
  • marion33, zrilek, ska51
 rusty
Hungary
User ID: 17227
Threads: 56
Likes: 1,880 in 283 posts
Given Likes: 539
#219
11-10-2012, 03:37 PM
Dear colleagues,
I would highly appreciate if someone could share the following paper:
On combinations of load effects
P. Marek, W.J. Venuti
Thank you in advance.
 ssobhan
User ID: 1054
Threads: 224
Given Likes: 2465
#220
11-10-2012, 03:41 PM
Dear rusty
here get it;
  • rusty, zrilek, kowheng, Dell_Brett, ska51
Pages (50): « Previous 1 … 17 18 19 20 21 22 23 24 25 26 27 … 50 Next »
