Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Archive AISC 3rd Edition
AISC 3rd Edition
 7.85
Turkey
User ID: 13097
Threads: 5
Likes: 26 in 4 posts
Given Likes: 17
10-26-2010, 09:18 PM
Dear friends,
I need AISC 3rd Edition.
Thank you for your helps,
[-] The following 1 user Likes 7.85's post:1 user Likes 7.85's post
  • manzoor_quadri
 mdmh10
User ID: 24944
Threads: 2
Likes: 187 in 65 posts
Given Likes: 66
10-26-2010, 11:44 PM
AISC 3rd edition or 13th edition?
The only reason to use 3rd edition will be to retrofit a 40 year old building, it is a code from the 1970's in ASD instead of LRFD.
Please verify.
MDMH
[-] The following 1 user Likes mdmh10's post:1 user Likes mdmh10's post
  • manzoor_quadri
 robertsas
Indonesia
User ID: 655
Threads: 155
Likes: 5,665 in 416 posts
Given Likes: 3149
10-27-2010, 01:44 AM (This post was last modified: 10-27-2010, 01:45 AM by robertsas.)
Use search button :
or
in my 4 shared files :
regards,
robertsasmita
[-] The following 12 users Like robertsas's post:12 users Like robertsas's post
  • Dell_Brett, mdmh10, jcbv, RANA WASEEM, ilgar, leonelmariana, mishanya, rendel_©, rcnet, iashas24, slowet, manzoor_quadri
 7.85
Turkey
User ID: 13097
Threads: 5
Given Likes: 17
10-27-2010, 06:26 AM
Thanks for ur helps,
I need AISC 3rd Edition(2001), not AISC 13th Edition.
  • manzoor_quadri
 mdmh10
User ID: 24944
Threads: 2
Given Likes: 66
10-27-2010, 06:12 PM
Been trying to find it, but I have not been able to find it. I've got a hard copy of it which I may attempt to scan for you if you are looking for an individual section. Most sections resemble the 13th edition for the most part, some sections have been switched around, but they are still the same.
What you are looking is better referred to as AISC LRFD 3rd edition, a.k.a. AISC 12th edition.
Please PM me if you know the section you are looking for so that I can scan it for you, unless you found the equivalent one in the link Mr. Robertsas provided for you above.
Best regards,
MDMH
  • manzoor_quadri
 manzoor_quadri
Saudi Arabia
User ID: 6161
Threads: 33
Likes: 87 in 24 posts
Given Likes: 296
10-02-2012, 07:04 PM
Hello All,
Please share this book I am also in urgent need for this book, if anybody has please share it.
 vinnunsam
User ID: 3932
Threads: 34
Likes: 1,281 in 116 posts
Given Likes: 457
10-03-2012, 05:15 AM (This post was last modified: 10-03-2012, 05:19 AM by BennyP.)
Kindly find the PDF file being uploaded. Download from the mirror link below.
[-] The following 4 users Like vinnunsam's post:4 users Like vinnunsam's post
  • andersen3, blaze, manzoor_quadri, malc
  [REQUEST] AISC - Steel Construction Manual 14th Edition mastermind 11 12,073 03-14-2014, 08:42 PM
Last Post: pelon2040
  IBC 2012, THE LAST EDITION OF AISC loyal85 1 2,117 02-11-2014, 04:51 AM
Last Post: Mohammad6299
  AISC Manual of Steel Construction: Load and Resistance Factor Design, Third Edition ticojuanjo 3 3,873 07-04-2011, 10:26 AM
Last Post: ska51
