10-02-2012, 07:44 AM
Pipe Welding Procedures
Author: Hoobasar Rampaul | Size: 11 MB | Format: PDF | Quality: Unspecified | Publisher: Industrial Press | Year: 2003 | pages: 257 | ISBN: 0831131411
![[Image: 24936168531673869111.jpeg]](https://pic.civilea.com/images/24936168531673869111.jpeg)
This edition continues to reinforce the welder's understanding of procedures. Drawing on his extensive practical and teaching experience in the field, the author describes in detail the manipulating procedures used to weld pipe joints.
You will find useful information on heat input and distribution, essentials of shielded metal-arc technology, distortion, pipe welding defects, welding safety, essentials of welding metallurgy, and qualification of the welding procedure and the welder.
Look for new or expanded coverage of:
• Root Bead--Pulse Current--Gas Tungsten Arc Welding
• Shielded Metal Arc Welding--Electrode
• Welding Steel for Low Temperature (Cryogenic) Service
• Down Hill Welding--Heavywall and Large Diameter
• Welding Metallurgy
• Weld Repair
Good book for anyone getting started with welding pipe
Contents
Forward
Preface
1. Introduction
2. Essentials of Shielded Metal-Arc Welding Technology
3. Heat Input and Distribution
4. Reperation of the Pipe Joint
5. Uphill Welding the Root Bead on Heavy-WallPipe (5G Position)
6. Welding the Rood Bead by the Gas Tungsten Arc Welding Process
7. The Intermediate and Cover Passes
8. Welding Thin-Wall Pipe
9. Horizontal Pipe Welding (20)
10. Welding Complicated Pipe Joints
11. Introduction to Welding Metallurgy
12. Distortion in Pipe Welding
13. Pipe Welding Defects
14. Fitting-UP Pipe
15. Qualification of the Welding Procedure & the Welder
16.General Welding Safety
Index
