Civil Engineering Association Software Software Product Autodesk Products Autodesk Quantity Takeoff 2013
Threads: 1,128
04-18-2012, 06:39 PM
[Image: 98664733672611681378.png]
Autodesk Quantity Takeoff: Building material cost estimate software. Cost Estimating & Quantity Surveying Software. Autodesk® Quantity Takeoff building cost estimating software helps make material costing faster, easier, and more accurate. Cost estimators can create synchronized, comprehensive project views that combine important information from building information modeling (BIM) tools such as Revit® Architecture, Revit® Structure, and Revit® MEP software together with geometry, images, and data from other tools. Automatically or manually measure areas and count building components, export to Microsoft® Excel®, and publish to DWF™ format.
•Takeoff in minutes automatically—Perform a takeoff on an entire building information model (BIM) in just minutes through integration of 2D and 3D design data.
•Greater flexibility than typical databases or spreadsheets—Perform interactive examination of 3D models for material cost estimating purposes.
•Dynamic counting—Count and quantify design data quickly and easily.
•More efficient manual takeoff—Supports the takeoff of JPG, TIF, PDF, and other “nonintelligent” image formats.
•Share, query, and clarify—Generate quantities linked to specific objects. Mark up and “round-trip” your comments.
•Faster and more insightful quantity reports—Create summaries and detailed quantity surveying reports quickly and easily.
  • Quantumm, 3fan, maad59, oanm2000, w64bit, Dell_Brett, zrilek, Andrew seah, Petrit, albert23rd, blaze
Threads: 1,128
04-19-2012, 03:06 AM
[-] The following 8 users Like BennyP's post:8 users Like BennyP's post
  • mahyarov, w64bit, zrilek, stosto6666, uetian19, Quantumm, 3fan, blaze
 melshy2711
Vietnam
User ID: 40647
Threads: 1
Likes: 52 in 15 posts
Given Likes: 49
04-19-2012, 11:01 PM (This post was last modified: 04-19-2012, 11:01 PM by melshy2711.)
[-] The following 2 users Like melshy2711's post:2 users Like melshy2711's post
  • zrilek, killerbee
Threads: 1,128
07-21-2012, 03:02 PM
This was and remains a 32 bit application. Inside you can find Xforce KG for x64 and x32 but only the keygen for x32 will activate. I saw inside the same old setup files from the previous release (from April) and the only 64 bit application included is the DrawingViewer 2013 but the size to download is about 2 GB instead of 810 MB. If you want to install copy on the HD (when trying to install from DVD asks for the second disk).
Other links:
  • oanm2000, zrilek, Dell_Brett
 Mohammad6299
User ID: 42302
Threads: 261
Likes: 7,913 in 854 posts
Given Likes: 4212
09-16-2012, 02:31 PM
Direct Link:
  Autodesk 2013 Programs Activation BennyP 3 9,581 03-06-2025, 12:27 PM
  Autodesk 3ds Max 2013 (x86/x64) Mohammad6299 3 8,814 01-26-2016, 06:53 PM
Last Post: gotcha
  Autodesk 2013 All Products Keygen For Win & Mac OS kirankumarklk 8 21,269 01-02-2014, 10:45 PM
Last Post: Petrit
  Autodesk Simulation CFD 2013 (x86/x64) Mohammad6299 4 9,871 09-12-2013, 04:52 AM
Last Post: Mohammad6299
  AUTODESK BUILDING DESIGN SUITE ULTIMATE 2013 BennyP 6 13,139 05-20-2013, 01:28 PM
Last Post: halil
  Autodesk® Vasari 2013 Beta 2 KhaLed-S.E 0 7,121 05-07-2013, 11:33 AM
Last Post: KhaLed-S.E
  Autodesk AutoCAD Civil 3D 2013 (x86/x64) BennyP 13 27,334 03-21-2013, 06:47 PM
Last Post: mibaksh
