Civil Engineering Association eBooks Journals, Papers and Presentations GROUND IMPROVEMENT ENGINEERING
 giguni
User ID: 20677
Threads: 73
Likes: 208 in 33 posts
Given Likes: 166
09-27-2010, 02:18 PM (This post was last modified: 09-06-2012, 07:25 AM by lisine.)
GROUND IMPROVEMENT ENGINEERING-ISSUES AND SELECTION
The issues, which affect the successful application of ground improvement in soil and rock, are studied with emphasis on the design, construction and long-term performance of the improved ground. Discussed are over thirty technical issues affecting twenty four ground improvement techniques representing the eight main categories of ground improvement in soil: densification, consolidation, weight reduction, reinforcement, chemical treatment, thermal stabilization, electrotreatment and biotechnical stabilization. Theissues, which influence rock integrity, are also discussed, including those related to rock properties as well as external factors such as water, climate, earthquakes and others. Eight types of rock degradation are
described in the paper and possible remediation measures are identified for each, many of which include the application of ground improvement. Several factors, which may influence the selection of a ground improvement technique or a combination of techniques, are discussed and a case study is presented to demonstrate the selection process.
[Image: 26061886431385983229.jpeg]
[-] The following 11 users Like giguni's post:11 users Like giguni's post
  â€¢ kowheng, shaqee, roaming79, 2824, jaejeong, peymanlord, hanung, ykhackhack, oanm2000, uetian19, killerbee
 lisine
Vanuatu
User ID: 17927
Threads: 265
Likes: 11,713 in 1,307 posts
Given Likes: 4631
09-06-2012, 07:24 AM
[-] The following 10 users Like lisine's post:10 users Like lisine's post
  â€¢ shadabg, blaze, ykhackhack, malc, utan, zrilek, oanm2000, slurryha, uetian19, killerbee
  PRACTICAL APPLICATIONS OF GROUND IMPROVEMENT shadabg 0 3,919 09-29-2012, 08:52 AM
Last Post: shadabg
  TTM Ground Anchors, Geotechnical and ground anchor system ir_71 0 4,998 06-24-2011, 06:16 PM
  RECENT ADVANCES IN GROUND ANCHOR AND GROUND REINFORCEMENT TECHNOLOGY giguni 0 5,211 09-27-2010, 02:38 PM
Last Post: giguni
