Civil Engineering Association eBooks Journals, Papers and Presentations Underground Box Structure as a Foundation for Shear Walls in Seismic Resistant Bldgs.
 GROUT
User ID: 212
Threads: 3
Likes: 24 in 3 posts
Given Likes: 148
08-16-2012, 07:51 PM (This post was last modified: 08-16-2012, 09:54 PM by usman.)
Underground Box Structure as a Foundation for Shear Walls in Seismic Resistant BuildingsWink
This kind of foundation can be an alternative solution for direct foundations.It solves the problem where oversized ordinary raft foundations are needed. In fact, the box foundation gathers the gravity loads resting on the peripheral walls, so that the global soil reaction reduces its eccentricity. In most cases the elements constituting the box structure,such as peripheral walls, raft, and ground floors, are already part of any actual building; they only need a proper seismic design, which is herein proposed. A simplified theoretical approach is presented to allow a correct proportioning and design of each structural element, such as reinforcing ribs and panels constituting the box.
Amendment:
Boxing structure must not have a expansion or seismic joint , Please read together with Article Interaction-Based Design Formulas for Transfer Beams:Box Foundation analogy.
link:
[-] The following 5 users Like GROUT's post:5 users Like GROUT's post
  â€¢ hatkam, RazvanMelek, oanm2000, andersen3, blaze
 usman
User ID: 59
Threads: 131
Likes: 6,571 in 671 posts
Given Likes: 4974
08-16-2012, 09:53 PM
[Image: 02370043208609288031.jpg]
[/MIRROR] 🔽🔽🔽🔽🔽🔽🔽🔽🔽
[-] The following 9 users Like usman's post:9 users Like usman's post
  â€¢ malc, kowheng, gulilero, tang1942, civilphongvan, RazvanMelek, oanm2000, ruaumoko, zrilek
  Assessment of Shear Wall Building Seismic Performance by Nonlinear Analysis benny 2 12,647 08-01-2017, 09:19 AM
Last Post: abdulazizk
  Strength and Drift Capacity of GFRP- Reinforced Concrete Shear Walls TAFATNEB 0 5,096 03-16-2016, 09:41 AM
  SEISMIC DESIGN FACTORS FOR PRECAST CONCRETE SHEAR WALL PARKING GARAGES TAFATNEB 0 5,829 02-12-2015, 01:39 PM
  Soil-Structure Interaction of Retaining Walls under Earthquake Loads TAFATNEB 0 5,791 12-26-2014, 10:12 PM
  Constructing Seismic Resistant Masonry Houses in Indonesia RyanRS 0 4,286 07-19-2014, 04:44 AM
Last Post: RyanRS
  SEISMIC ASSESSMENT OF AN IRREGULAR THREE-STOREY FULL SCA LE RC TEST STRUCTURE WITH SU TAFATNEB 0 4,825 06-03-2014, 09:11 PM
  SEISMIC ANALYSIS OF RETAINING WALLS WITHIN PLASTICITY FRAMEWORK TAFATNEB 0 4,073 04-27-2014, 07:35 AM
