Civil Engineering Association eBooks Journals, Papers and Presentations Partial factors for selected reinforced concrete members
 lisine
Vanuatu
User ID: 17927
Threads: 265
Likes: 11,713 in 1,307 posts
Given Likes: 4631
08-14-2012, 11:08 AM
Partial factors for selected reinforced concrete members: background to a revision of SANS 10100-1
Author: M Holický; J Retief; J Wium | Size: 0.19 MB | Format: PDF | Quality: Original preprint | Publisher: Journal of the South African Institution of Civil Engineering, Vol.52 No.1 | Year: Apr. 2010 | pages: 9 (36-44) | ISSN: 1021-2019
The application of Eurocode EN 1992-1-1 in revising the South African standard for structural concrete design SABS 0100-1:1992 will require the determination of partial factors in accordance with the reliability requirements of the revised South African loading code SANS 10160:2010. The partial material factors γs for steel and γc for concrete are proposed in analysing the reliability of reinforced concrete slabs and short centrically loaded columns. It appears that the partial factors γs = 1,10 and γc = 1,40 are a suitable set of factors to be considered in the foreseen revision of the code. Further research is required on the model uncertainty for different structural members (flexural members, shear, columns, walls) and the theoretical models of basic resistance variables related to quality control.
[-] The following 6 users Like lisine's post:6 users Like lisine's post
  • vvvv, zrilek, kowheng, malc, NBZ1400, DamirDz
  SEISMIC DESIGN FACTORS FOR PRECAST CONCRETE SHEAR WALL PARKING GARAGES TAFATNEB 0 5,875 02-12-2015, 01:39 PM
  SEISMIC RETROFIT OF REINFORCED CONCRETE BRIDGES WITH FIBER REINFORCED POLYMER COMPOSI TAFATNEB 0 4,855 04-03-2014, 12:26 PM
  A high performance fibre reinforced cement based plaster for retrofitting RC members asim99 0 4,561 05-11-2013, 05:57 PM
  Use Of Steel Fiber Reinforced Concrete In Structural Members With Highly Complex Stre aslam 1 5,264 04-08-2013, 08:00 AM
  Studies of Bond Between Concrete and Steel and Related Factors -5 Papers asim99 0 4,398 12-01-2012, 02:43 AM
  Design of Continuously Reinforced Concrete Pavements Using Glass Fiber Reinforced Pol ir_71 0 4,394 02-03-2011, 05:04 AM
