Civil Engineering Association eBooks Codes, Manual & Handbook British Standards (BS) BS EN 40 Lighting columns - all parts
02-01-2011, 12:26 PM
Author: CEN/TC 50 | Size: 3.2 MB | Format: PDF | Publisher: CEN
[Image: 56018305268679644681.jpg]
Contents of the zip-file:
1. EN 40-1:1991 Lighting columns - Part 1: Definitions and terms
The present European Standard gives definitions and terms in the field of ''lighting columns'' (i.e. support intended to hold one or more lanterns consisting of one or more parts: a post, possibly an extension piece and if necessary a bracket. Columns for catenary lighting are not included).
2. EN 40-2:2004 Lighting columns - Part 2: General requirements and dimensions
This document specifies the requirements and dimensions for lighting columns, brackets, base compartments, cableways and earthing terminals. It applies to post top columns not exceeding 20 m height for post top lanterns and columns with brackets not exceeding 18 m height for side entry lanterns.
This Part does not attempt to restrict the actual appearance or shape of the column or bracket. The majority of lighting columns are normally of a stepped tubular, round, octagonal or polygonal cross-section. Lighting columns may be manufactured from materials other than those listed in the foreword (e.g. wood, plastic, cast iron) or in other forms (e.g. lattice and telescopic).
This document specifies performance related to the essential requirements of resistance to horizontal (wind) loads and performance under vehicle impact (passive safety) in support of the Essential Requirement No 4 Safety in use measured according to the corresponding test methods included in this document or available in separate documents.
3.EN 40-3-1:2000 Lighting columns - Part 3-1: Design and verification - Specification for characteristic loads
This European Standard specifies design loads for lighting columns. It applies to post top columns not exceeding 20 m height for post top lanterns and to columns with brackets not exceeding 18 m height for side entry lanterns. Special structural designs to permit the attachement of signs, overhead wires, etc. are not covered by this standard. The requirements for lighting columns made from materials other than concrete, steel or aluminium (for example wood, plastic and cast iron) are not specifically covered in this standard.
4. EN 40-3-2:2000 Lighting columns - Part 3-2: Design and verification - Verification by testing
This European Standard specifies the requirements for the verification of the design of steel, aluminium and concrete lighting columns by testing. It gives type tests and so does not cover testing for quality control purposes. It applies to post top lighting columns not exceeding 20 m height for post top lanterns and to lighting columns with brackets not exceeding 18 m height for side entry lanterns. The requirements for lighting columns made from materials other than concrete, steel or aluminium (for example wood, plastic and cast iron) are not specifically covered in this standard.
5. EN 40-3-3:2003 Lighting columns - Part 3-3: Design and verification - Verification by calculation
This European Standard specifies the requirements for the verification of the design of lighting columns by calculation. It applies to post top columns not exceeding 20 m height for post top lanterns and to lighting columns with brackets not exceeding 18 m height for side entry lanterns.
The calculations used in this standard are based on limit state principles, where the effects of factored loads are compared with the relevant resistance of the structure. Two limit states are considered:
a) the ultimate limit state, which corresponds to the load-carrying capacity of the lighting column;
b) the serviceability limit state, which relates to the deflection of the lighting column in service.
NOTE In following this approach, simplifications appropriate to lighting columns have been adopted, These are:
1) the calculations are applicable to circular and regular octagonal cross-sections;
2) the number of separate partial safety factors have been reduced to a minimum;
3) serviceability partial safety factors have a value equal to unity.
The requirements for lighting columns made from materials other than concrete, steel, aluminium or fibre reinforced polymer composite (for example wood, plastic and cast iron) are not specifically covered in this standard.
This standard includes performance requirements for horizontal loads due to wind. Passive safety and the behaviour of a lighting column under the impact of a vehicle are not included, this group of lighting columns will have additional requirements (see prEN 40-2).
6. EN 40-4:2005 Lighting columns - Part 4: Requirements for reinforced and prestressed concrete lighting columns
This European Standard specifies requirements for reinforced and prestressed concrete lighting columns. It applies to columns not exceeding 20 m height for post top lanterns and columns with brackets not exceeding 18 m height for side entry lanterns.
This European Standard specifies:
a) performance related to the essential requirement of resistance to horizontal (wind) loads, measured in accordance with EN 40-3;
b) performance under vehicle impact (passive safety) in support of the Essential Requirement No. 4 Safety in use, measured in accordance with the corresponding test methods included in this document or available in separate European Standards.
7. EN 40-5:2002 Lighting columns - Part 5: Requirements for steel lighting columns
This European Standard specifies requirements for steel lighting columns. It includes materials and conformity control. It applies to post top columns not exceeding 20 m height for post top lanterns and to columns with brackets not exceeding 18 m height for side entry lanterns.
This European Standard specifies performance related to the essential requirements of resistance to horizontal (wind) loads and performance under impact in support of the Essential Requirement No 4 Safety in use measured according to the corresponding test methods included in this European Standard or available in separate European Standards.
It provides for the evaluation of conformity of the products to this European Standard.
8. EN 40-6:2002 Lighting columns - Part 6: Requirements for aluminium lighting columns
This European Standard specifies requirements for aluminium lighting columns. It includes materials and conformity control. It applies to post top columns not exceeding 20 m height for post top lanterns and to columns with brackets not exceeding 18 m height for side entry lanterns.
9. EN 40-7:2002 Lighting columns - Part 7: Requirements for fibre reinforced polymer composite lighting columns
This Part of EN 40 specifies the performance requirements for fibre reinforced polymer composite lighting columns for which the main intended use is road lighting. It includes materials and test methods. The composite materials considered are those constructed from a fibrous reinforcing material that is suspended in a matrix of resin material. It applies to post top columns not exceeding 20 m height for post top lanterns and columns with brackets not exceeding 18 m height for side entry lanterns.
  â€¢ kowheng, blaze, Dell_Brett, usman, Grunf, jcbv, ziggywas1, zrilek, DamaD, PanosP, dbsimon29, riprap, gulilero, avscorreia, rigid_joint, Clouseau, SCREAM7890, vvvv
07-26-2012, 02:29 PM
New working links:
  â€¢ avscorreia, Dell_Brett, warbeast, Jackass, st77bel, zrilek, malc, isurya, rigid_joint, Clouseau
01-04-2015, 07:43 PM (This post was last modified: 06-26-2015, 02:14 PM by 3fan.)
  â€¢ jcbv, Dell_Brett, SCREAM7890, Mohammad6299, warlord1, malc, dizz, PinkPant, knrsa, melekeen, amindoxiti, ykhackhack, TAFATNEB
 PinkPant
Turkey
User ID: 25448
Threads: 67
Likes: 4,007 in 374 posts
Given Likes: 10354
06-26-2015, 02:55 PM
[/MIRROR] 🔽🔽🔽🔽🔽🔽🔽🔽🔽
Use regular forum pass
PinkPant
[-] The following 9 users Like PinkPant's post:9 users Like PinkPant's post
  â€¢ vvvv, amindoxiti, oanm2000, slowet, subin91, Dell_Brett, Trishu999, TAFATNEB, f_slikken
  BS EN 12464 Light and lighting mybest 0 2,103 12-03-2011, 05:48 AM
Last Post: mybest
