Civil Engineering Association eBooks Codes, Manual & Handbook British Standards (BS) BS EN 13285:2010 Unbound mixtures. Specifications
01-16-2012, 05:40 PM (This post was last modified: 06-29-2012, 11:53 AM by 3fan.)
BS EN 13285:2010 "Unbound mixtures. Specifications"
Author: CEN/TC 227 | Size: 0.75 MB | Format: PDF | Quality: Original preprint | Publisher: CEN | Year: 2010 | pages: 24
[Image: 18471125288444909209.jpg]
This European Standard specifies requirements for unbound mixtures used for construction and maintenance of roads, airfields and other trafficked areas. The requirements are defined with appropriate cross-reference to EN 13242.
This European Standard applies to unbound mixtures of natural, artificial and recycled aggregates with a upper sieve size (D) from 8 mm to 90 mm and lower sieve size (d) = 0 at the point of delivery.
NOTE 1 Mixtures with an upper sieve size (D) greater than 90 mm are not covered by this European Standard but may be specified in the place of use.
NOTE 2 Water content of the mixture and the density of the installed layer are not specified mixture requirements. Both parameters are related to the control of the construction of the layer and are outside the scope of this European Standard.
  β€’ 3fan, Jackass, Dell_Brett, ting tsai huang, kowheng, peixoto, st77bel
 [bds]
User ID: 30254
Likes: 4 in 2 posts
Given Likes: 6
06-29-2012, 11:42 AM
Can you re-upload please?
Best regards
  β€’
 3fan
Romania
User ID: 29614
Threads: 141
Likes: 7,359 in 1,207 posts
Given Likes: 5546
06-29-2012, 11:59 AM
DIRECT LINKS thumbup
[-] The following 1 user Likes 3fan's post:1 user Likes 3fan's post
  β€’ [bds]
 [bds]
User ID: 30254
Likes: 4 in 2 posts
Given Likes: 6
06-29-2012, 03:32 PM
Thanks but I canΒ΄t download from that site Sad
  β€’
07-17-2012, 07:42 PM
New working links:
  β€’ zrilek, 3fan, Jackass, blaze, lisine, Dell_Brett, st77bel
  BS EN 13242-2002 Aggregates for unbound and hydraulically bound materials for use in st77bel 3 3,745 01-23-2017, 05:52 PM
  BS EN 15743:2010 Supersulfated cement. Composition, specifications and conformity cri mybest 2 2,339 02-25-2013, 06:17 AM
Last Post: arshiakh
