Civil Engineering Association eBooks Journals, Papers and Presentations Journal of Geotechnical Engineering - Requested Paper
 melkat
User ID: 1901
Threads: 77
Likes: 3,565 in 324 posts
Given Likes: 1623
07-17-2012, 07:05 AM
Interpretation Procedure for Pressuremeter Tests in Sand
Author: Ilan Juran & Behnam Mahmoodzadegan | Size: 0.9 MB | Format: PDF | Quality: Unspecified | Publisher: Journal of Geotechnical Engineering vol 115, issue 11 | Year: 1989 | pages: 1617-1632
A new approach for the interpretation of pressuremeter tests in sands is proposed that permits the determination of shear strength characteristics, dilatancy properties, and shear modulus from the analysis of pressuremeter test results. A relatively simple soil model has been developed that takes into account the contracting or dilating behavior of the soil, or both, during the pressuremeter cavity expansion. The soil is assumed to be an elastoplastic material with a nonassociated flow rule. To evaluate the proposed interpretation procedure, laboratory cavity expansion tests on Fontainbleau sand specimens have been conducted in a specially designed hollow-cylinder cell. The comparison between the sand properties (shear modulus, peak friction angle, dilation angle) derived from the cavity expansion tests and those obtained from conventional tests illustrates the applicability of the proposed interpretation procedure.
[-] The following 9 users Like melkat's post:9 users Like melkat's post
  â€¢ 3fan, shadabg, kowheng, lisine, malc, zrilek, oanm2000, Dell_Brett, mz55
  The AISC Engineering Journal Archive [1964-2001] agelos100 2 8,302 03-02-2020, 01:50 AM
  AISC Engineering Journal Fourth Quarter 2014 Volume 51, No. 4 malc 1 6,867 10-15-2014, 07:26 AM
Last Post: Saze808
  Journal of Engineering Mechanics - Papers lisine 3 8,037 06-28-2013, 09:24 AM
  Journal of Materials in Civil Engineering - Papers lisine 3 8,770 06-28-2013, 09:24 AM
  Journal of Structural Engineering - Papers lisine 10 19,782 06-07-2013, 06:41 AM
  Journal Engineering Structures - Papers lisine 6 12,671 04-10-2013, 07:01 AM
  International Journal of Geomechanics - Requested papers lisine 3 8,044 02-26-2013, 08:47 AM
