Civil Engineering Association eBooks Structural Books Analysis & Design Examples in Structural Analysis
Threads: 154
07-16-2012, 11:51 AM
Direct Link :
More Download Links :
[-] The following 14 users Like shadabg's post:14 users Like shadabg's post
  β€’ giga, rezart, blaze, oanm2000, Quantumm, odiclas, Andrew seah, ykhackhack, lissics, jonny78, warbeast, malc, dinu69in, psk62
Threads: 274
Likes: 12,075 in 1,233 posts
04-09-2013, 09:56 AM
[-] The following 7 users Like pezhmankhan's post:7 users Like pezhmankhan's post
  β€’ blaze, Andrew seah, stigtg, paitaconst, oreslaw, jonny78, harsono
 cace-01
User ID: 15651
Threads: 433
Likes: 10,522 in 867 posts
Given Likes: 7468
#13
04-26-2015, 12:51 PM (This post was last modified: 04-27-2015, 09:22 AM by Dell_Brett.)
Examples in Structural Analysis - 2nd Edition
Author: William M.C. McKenzie | Size: 10 MB | Format: PDF | Quality: Unspecified | Publisher: CRC Press | Year: 2014 | pages: 838 | ISBN: 9781466595262
[Image: 08101534762700304638.jpg]
This second edition of Examples in Structural Analysis uses a step-by-step approach and provides an extensive collection of fully worked and graded examples for a wide variety of structural analysis problems. It presents detailed information on the methods of solutions to problems and the results obtained. Also given within the text is a summary of each of the principal analysis techniques inherent in the design process and where appropriate, an explanation of the mathematical models used.
The text emphasises that software should only be used if designers have the appropriate knowledge and understanding of the mathematical modelling, assumptions and limitations inherent in the programs they use. It establishes the use of hand-methods for obtaining approximate solutions during preliminary design and an independent check on the answers obtained from computer analyses.
What’s New in the Second Edition:
New chapters cover the development and use of influence lines for determinate and indeterminate beams, as well as the use of approximate analyses for indeterminate pin-jointed and rigid-jointed plane-frames. This edition includes a rewrite of the chapter on buckling instability, expands on beams and on the use of the unit load method applied to singly redundant frames. The x-y-z co-ordinate system and symbols have been modified to reflect the conventions adopted in the structural Eurocodes.
William M. C. McKenzie is also the author of six design textbooks relating to the British Standards and the Eurocodes for structural design and one structural analysis textbook. As a member of the Institute of Physics, he is both a chartered engineer and a chartered physicist and has been involved in consultancy, research and teaching for more than 35 years.
Thanks to Original Uploader
MODERATOR NOTE:
USE SUMATRA PDF (or FOXIT READER) program to read this file
Adobe PDF Reader does not works!!!
You can use a portable version of SUMATRA:
[-] The following 22 users Like cace-01's post:22 users Like cace-01's post
  β€’ titko, rezart, zrilek, mybest, amindoxiti, learner20, Veggeta, ruaumoko, Andrew seah, inge911, dizz, subin91, emmi, oanm2000, jonny78, atram, ssobhan, Munykong, bridgeengineer, simanta, Jackass, gafi
 titko
User ID: 10598
Threads: 15
Likes: 522 in 69 posts
Given Likes: 241
#14
04-26-2015, 01:24 PM (This post was last modified: 04-27-2015, 09:25 AM by Dell_Brett.)
MODERATOR NOTE:
[-] The following 8 users Like titko's post:8 users Like titko's post
  β€’ f_slikken, dinu69in, slowet, geomahesh, cristi, oanm2000, jonny78, bridgeengineer
 amindoxiti
User ID: 86739
Threads: 192
Likes: 8,341 in 584 posts
Given Likes: 2618
#15
04-26-2015, 03:33 PM
Hi,
Use foxit reader instead.For me it is ok.
There are some problems like this when Acrobat is used.
Do not worry about your difficulties in Mathematics, I can assure you mine are still greater. Β -Albert EinsteinΒ  Β  Β  Β  Β  Β
[-] The following 4 users Like amindoxiti's post:4 users Like amindoxiti's post
  β€’ Photon, apocalipse, cace-01, Dell_Brett
#16
04-26-2015, 07:07 PM (This post was last modified: 04-27-2015, 08:51 AM by Dell_Brett.)
Examples in Structural Analysis - First Ed.
Author: Willi McKenzie | Size: 26.55 MB | Format: PDF | Quality: Unspecified | Year: 2006
Moderator Note:
01 - This file is complete and can be opened by Acrobat Reader easily
02 - This is the 1st Edition - (comment after post below)
[-] The following 14 users Like TAFATNEB's post:14 users Like TAFATNEB's post
  β€’ Dell_Brett, cace-01, amindoxiti, malc, ykhackhack, dizz, Trishu999, PinkPant, oanm2000, jonny78, bridgeengineer, tang1942, zrilek, learner20
 emmi
Laos
User ID: 26
Threads: 33
Likes: 969 in 102 posts
Given Likes: 1203
#17
04-28-2015, 12:55 AM
[Image: comments.png]
This ebook can open by Adobe Acrobat
[-] The following 18 users Like emmi's post:18 users Like emmi's post
  β€’ Dell_Brett, malc, blaze, cace-01, zrilek, atram, PinkPant, amindoxiti, lisine, oanm2000, ykhackhack, gianniorlati, ali akbar, melekeen, jonny78, ruaumoko, learner20, harsono
 dinu69in
User ID: 16081
Threads: 68
Likes: 1,507 in 138 posts
Given Likes: 1634
#18
05-26-2015, 11:25 PM
Mirror link for first edition:
[-] The following 7 users Like dinu69in's post:7 users Like dinu69in's post
  β€’ simanta, jcbv, blaze, oanm2000, PinkPant, versiondemo, seraneng
 f_slikken
User ID: 21091
Threads: 9
Likes: 910 in 88 posts
Given Likes: 778
#19
05-27-2015, 12:33 PM
Link to the second edition:
[-] The following 13 users Like f_slikken's post:13 users Like f_slikken's post
  β€’ oanm2000, PinkPant, vvvv, dinu69in, vardan, versiondemo, gulilero, draluka, Dell_Brett, dizz, jcbv, viet2010, carolinandra
 concreteok
E-Book Moderator
Malaysia
User ID: 4764
Threads: 38
Likes: 4,964 in 638 posts
Given Likes: 3501
#20
06-03-2015, 01:31 AM (This post was last modified: 06-03-2015, 06:10 AM by Dell_Brett.)
the file could be corrupted during uploading process
use this
Use standard forum Password
concrete solution advocate
[-] The following 14 users Like concreteok's post:14 users Like concreteok's post
  β€’ amindoxiti, milova, subin91, matserco, Dell_Brett, PinkPant, ascetic19, bridgeengineer, oanm2000, onest30, cordoba123, learner20, harsono, tuanpecc1
  Energy Methods of Structural Analysis: Theory, worked examples and problems febo927 0 4,829 07-26-2018, 06:38 PM
Last Post: febo927
