04-11-2012, 11:46 AM
Revit Extention for Autodesk Revit 2013
![[Image: 87833725070578488258.gif]](https://pic.civilea.com/images/87833725070578488258.gif)
Revit Extensions for Autodesk Revit 2013 extend the capabilities of Autodesk Revit 2013, Autodesk Revit Architecture 2013, Autodesk Revit MEP 2013, and Autodesk Revit Structure 2013 software in key areas, including structural analysis, modeling, reinforcement, interoperability and construction documentation.
This download contains all previously released Revit Extensions and updates. In addition, this download includes enhancements to the positioning extension and improvements to the reinforcement extensions (dynamic model update, beam reinforcement).
- Reinforcement of Beams
An enhanced feature has been implemented to help detect supports for beams. The support analysis is performed on the bottom plane of a beam which is appropriate for slanted and vertical columns. Additionally, walls are considered as potential supports.
π CLICK HERE π
π CLICK HERE π
π CLICK HERE π
![[Image: 99767408333441961461.jpg]](https://pic.civilea.com/images/99767408333441961461.jpg)
![[Image: 53943969436635848772.jpg]](https://pic.civilea.com/images/53943969436635848772.jpg)
