Civil Engineering Association eBooks Structural Dynamics and Earthquake Engineering Seismic Behavior and Retrofit of Infilled Frames
 aslam
Abu Dhabi
User ID: 64
Threads: 284
Likes: 7,707 in 755 posts
Given Likes: 2168
07-15-2012, 09:41 AM
Author: Mohammad Reza Tabeshpour, Amir Azad1 and Ali Akbar Golafshani | Size: 0.5 MB | Format: PDF | Quality: Unspecified | Publisher: Sharif University of Technology, Tehran, | Year: - | pages: 28 | ISBN: -
There are many important
questions in the field of infilled frames, such as:
1. What are the negative and positive effects of infill walls in various types of buildings
(local and global)?
2. Where infills should be considered (in which type of structures, considering lateral
resisting system)?
3. When it is better to have interaction between frame and infill? In what type of
structures considering the number of stories?
4. When it is better to have a gap between frame and infill?
5. What is the state of the art in this field?
6. Comparing National and international codes, what is the state of the practice?
7. What are the suitable strategies to retrofit existing infilled frames?
The aim of this chapter is to answer some of these questions. A categorized discussion is
presented here to classify the problems solved or to be solved.
[-] The following 13 users Like aslam's post:13 users Like aslam's post
  β€’ kowheng, mary, slowet, Dell_Brett, malc, Jackass, simanta, jokerβ„’, cristi, jcbv, gacella, Sumatra, zrilek
Threads: 307
07-15-2012, 02:19 PM (This post was last modified: 07-15-2012, 02:40 PM by Grunf.)
If using the link in above post, after extracting the file extension is missing. Add ".PDF" without quotes to the end of that file to be able to open it.
Direct link:
[-] The following 10 users Like Grunf's post:10 users Like Grunf's post
  β€’ gulilero, sodapas, Sumatra, zrilek, seriousboy, Dell_Brett, subin91, blaze, mgdario, civilgen
  Advanced Design Examples of Seismic Retrofit of Structures sabooryan 2 4,628 07-08-2024, 05:38 AM
  Seismic Assessment, Behavior and Retrofit of Heritage Buildings and Monuments TAFATNEB 0 3,199 06-28-2024, 02:32 PM
  Seismic Behavior and Design Guidelines for Steel Frame Structures with Added Viscoela david-smith 3 4,148 12-20-2022, 07:30 PM
Last Post: bridgeengineer
  Dynamic Behavior of Concrete and Seismic Engineering abudabeeja 10 7,623 07-20-2018, 04:04 AM
Last Post: axcel
  Seismic Design and Retrofit of Bridges toa011 6 5,518 08-31-2015, 02:56 PM
Last Post: ibg0203
  METALLIC DAMPERS FOR SEISMIC DESIGN AND RETROFIT OF BRIDGES mahyarov 1 2,222 08-12-2014, 02:10 PM
  Theory and Design of Seismic Resistant Steel Frames miquan 3 3,918 04-01-2013, 02:38 AM
Last Post: pezhmankhan
