EN50341
Overhead electrical lines exceeding AC 45 kV
EN50341
![]() Overhead electrical lines exceeding AC 45 kV ![]() Code: Content of this section is hidden, You must be registered and upgrade your account to see this content.See this link to read how you can remove this limitation: 👉 CLICK HERE 👈
05-10-2012, 11:36 AM
![]() DIRECT LINKS
![]() Code: Content of this section is hidden, You must be registered and upgrade your account to see this content.See this link to read how you can remove this limitation: 👉 CLICK HERE 👈 National Normative Aspects for Austria
05-10-2012, 07:45 PM
EN 50341-1:2001 Overhead electrical lines exceeding AC 45 kV -- Part 1: General requirements - Common specifications Author: Technical Committee CENELEC TC 11 | Size: 0.9 MB | Format: PDF | Quality: Original preprint | Publisher: CEN/CENELEC | Year: 2001 | pages: 230
![]() This standard applies to overhead electric lines with rated voltages exceeding 45 kV AC and with rated frequencies below 100 Hz. This standard specifies the general requirements that shall be met for the design and construction of new overhead lines to ensure that the line is suitable for its purpose with regard to safety of persons, maintenance, operation and environmental considerations. NOTE 1 The extent of the application of this standard by each country in respect of existing overhead lines is subject to the requirements of the National Normative Aspects (NNA) applicable to that country. NOTE 2 Design and construction of overhead lines with insulated conductors, where internal and external clearances can be smaller than specified in the standard are not included. All other requirements of the standard may be applied to overhead lines with insulated conductors. When necessary, requirements for clearances can be given in the NNAs. NOTE 3 This part of the standard is applicable for optical Ground Wires (OPGWs) and optical Conductors (OPCONs). However the standard is not applicable to telecommunication systems which are used on overhead transmission lines either attached to the transmission line conductor/earth wire system (for example wraparound,...) or as separate cables supported by the transmission supports for example All Dielectric Self Supporting (ADSS) or for telecommunication equipment mounted on individual transmission line structures. When necessary, requirements can be given in the NNAs. This standard does not apply to : - overhead electric lines inside closed electrical areas as defined in HD 637; - catenary systems of electrified railways. Code: Content of this section is hidden, You must be registered and upgrade your account to see this content.See this link to read how you can remove this limitation: 👉 CLICK HERE 👈
The following 13 users Like ir_71's post:• 3fan, jcbv, SCREAM7890, malc,
12-06-2012, 07:58 PM
New links:
The following 6 users Like ir_71's post:• Dell_Brett, lisine, zrilek, nhim4mat2006, PinkPant, ranasanga
11-25-2013, 10:50 AM
all links dead; new links:
Code: Content of this section is hidden, You must be registered and upgrade your account to see this content.See this link to read how you can remove this limitation: 👉 CLICK HERE 👈 password: Code: Content of this section is hidden, You must be registered and upgrade your account to see this content.See this link to read how you can remove this limitation: 👉 CLICK HERE 👈
06-13-2018, 07:45 AM
new link
Code: Content of this section is hidden, You must be registered and upgrade your account to see this content.See this link to read how you can remove this limitation: 👉 CLICK HERE 👈 password Code: Content of this section is hidden, You must be registered and upgrade your account to see this content.See this link to read how you can remove this limitation: 👉 CLICK HERE 👈
The following 7 users Like andersen3's post:• PinkPant, oanm2000, karthikeyans3d, Dell_Brett, ashcivilea, monter, nhim4mat2006 |
| EN 50341-3-17 - National Normative Aspects for Portugal | Songoku | 1 | 2,537 |
12-07-2012, 12:00 AM Last Post: Songoku |
