Civil Engineering Association eBooks General Books Civil Engineering MSc and PhD thesis Displacement-based Seismic Design of Shear Wall Buildings
 hich
User ID: 3732
Threads: 93
Likes: 5,003 in 418 posts
Given Likes: 101
05-02-2012, 03:57 PM (This post was last modified: 05-03-2012, 05:36 PM by mybest.)
Author: Freddy Eduardo Pina Burgos | Size: 7.5 MB | Format: PDF | Quality: Unspecified | Publisher: Carleton University (Canada) | Year: 2006 | pages: 300 | ISBN: 0494183314, 9780494183311
[Image: 14317039347512627333.jpg]
A displacement-based method of seismic design (DBSD) is presented with particular reference to the design of reinforced concrete shear wall buildings. For preliminary design, approximate estimates of the yield and ultimate displacements are obtained, the former from simple empirical relations, and the latter to satisfy the following criteria: (1) satisfy code-specified drift limits, (2) ensure stability under P-Delta effects, and (3) keep the ductility demand within ductility capacity. For a multi-storey building the structure is converted to an equivalent single-degree-of-freedom (SDOF) system using an assumed deformation shape that is representative of the first mode. The required base shear strength of the SDOF system is determined from the inelastic demand spectrum corresponding to the ductility demand, which is the ratio of ultimate to yield displacement. The base shear is distributed across the height using an assumed pattern, such as the one given by the National Building Code of Canada, and the structure is designed for the moments produced by the estimated shears. (Abstract shortened by UMI.)
[-] The following 8 users Like hich's post:8 users Like hich's post
  • david-smith, zrilek, 3fan, miquan, mary, cace-01, Sumatra, SCREAM7890
 david-smith
United States
User ID: 43924
Threads: 247
Likes: 4,023 in 582 posts
Given Likes: 1085
05-02-2012, 04:56 PM (This post was last modified: 05-03-2012, 05:24 PM by usman.)
[-] The following 19 users Like david-smith's post:19 users Like david-smith's post
  • blaze, warbeast, SCREAM7890, gulilero, Dell_Brett, igor1234, seriousboy, mgdario, malc, ruaumoko, oscargon, miquan, Jackass, melkat, ikoleci, Batman07, kowheng, Sumatra, shadabg
 miquan
Vietnam
User ID: 631
Threads: 204
Likes: 3,748 in 387 posts
Given Likes: 1331
05-03-2012, 04:42 AM
[-] The following 9 users Like miquan's post:9 users Like miquan's post
  • Batman07, slowet, kowheng, 3fan, Dell_Brett, erthqkengnr™, sodapas, simanta, SCREAM7890
  Inelastic seismic response of precast concrete large panel coupled shear wall sys TAFATNEB 0 1,919 03-27-2015, 11:44 AM
  Performance Based Approach in Seismic Design of Embedded Retaining Walls TAFATNEB 0 2,044 02-09-2015, 07:24 AM
  SEISMIC BEHAVIOUR OF STEEL PLATE SHEAR WALLS TAFATNEB 0 1,930 10-08-2014, 02:00 PM
  SEISMIC SHEAR DEMAND IN HIGH-RISE CONCRETE WALLS TAFATNEB 0 1,789 05-30-2014, 02:05 PM
  Performance-Based Seismic Demand Assessment of Concentrically Braced Steel Frame Buil TAFATNEB 0 1,843 05-09-2014, 05:09 PM
  SEISMIC DESIGN, TESTING AND ANALYSIS OF REINFORCED CONCRETE WALL BUILDINGS TAFATNEB 0 1,923 05-09-2014, 04:36 PM
  Seismic Performance, Modeling, and Failure Assessment of Reinforced Concrete Shear Wa TAFATNEB 0 1,804 05-09-2014, 04:00 PM
