Civil Engineering Association eBooks Journals, Papers and Presentations Scientific journals and Research papers Journal of Geotechnical & Geoenvironmental Engineering
 lisine
Vanuatu
User ID: 17927
Threads: 265
Likes: 11,713 in 1,307 posts
Given Likes: 4631
03-07-2012, 11:54 AM (This post was last modified: 02-18-2017, 12:47 PM by lisine. Edit Reason: N/A )
Ultimate Lateral Resistance of Pile Groups in Sand
Author: Patra, Nihar Ranjan, Pise, Prabhakar Jagannath | Size: 1.41 MB | Format: PDF | Quality: Scanner | Publisher: Journal of Geotechnical and Geoenvironmental Engineering Vol 127 No. 6 | Year: 2001 | pages: 481-487 | ISBN: 1090-0241, 1943-5606
[Image: 37090467417474987683.jpg]
Abstract : Presents information on a study which investigated the resistance of model pile groups to lateral loads in Chennai, India. Methodology; Results and discussion.
Evaluation of Pile Diameter Effect on Initial Modulus of Subgrade Reaction
Author: Ashford, Scott A., Juirnarongrit, Teerawut | Size: 145 KB | Format: PDF | Quality: Original preprint | Publisher: Journal of Geotechnical & Geoenvironmental Engineering Vol. 129 Issue 3 | Year: 2003 | pages: 234-244 | ISBN: 1090-0241, 1943-5606
[Image: 68631097426228518416.jpg]
This paper presents the results of a study on the effect of pile diameter on the initial modulus of subgrade reaction. A series of ambient and impact vibration tests were performed on four different diameters of cast-in-drilled-hole piles to determine the natural frequencies and damping of the soil-pile systems. The measured natural frequencies were then compared with those estimated from a numerical model. The soil springs in the numerical model were established by implementing two different concepts on initial modulus of subgrade reaction. One is based on Terzaghi’s concept in which the modulus of subgrade reaction is independent of pile diameter. The other was based on recent research suggesting that the initial modulus of subgrade reaction may be linearly proportional to pile diameter. It was found that the measured natural frequencies were in good agreement with the computed ones when the diameter-independent modulus of subgrade reaction was employed. In addition, the test results show that the damping ratio of the system varied with pile diameter from 3% for 0.4-m pile to 25% for 1.2-m pile.
Ultimate Lateral Resistance to Piles in Cohesionless Soils
Author: Zhang, Lianyang, Silva, Francisco, Grismala, Ralph | Size: 128 KB | Format: PDF | Quality: Original preprint | Publisher: Journal of Geotechnical & Geoenvironmental Engineering; Vol. 131 Issue 1 | Year: 2005 | pages: 78-83 | ISBN: 1090-0241, 1943-5606
[Image: 47406197920384675262.jpg]
Several methods are available for predicting the ultimate lateral resistance to piles in cohesionless soils. However, these methods often produce significantly different ultimate resistance values. This makes it difficult for practicing engineers to effectively select the appropriate method when designing laterally loaded piles in cohesionless soils. By analyzing the lateral soil resistance distribution along the width of the pile and based on the test results of model rigid piles in cohesionless soils collected from the published literature, a simple method is proposed for calculating the ultimate lateral resistance (including frontal soil resistance and side shear resistance) to piles in cohesionless soils. The calculated ultimate lateral resistance from the proposed method agrees well with that obtained from centrifugal tests of flexible model piles. Predicting the lateral load capacity of laboratory and field rigid test piles in cohesionless soils using the proposed method also yields satisfactory results.
If you like these publications, CivilEA's team strongly suggest you to buy them! Support the authors!
Moderator note:Dear lisine, by using Post Gen we will keep this forum the best. Please consider next time use Post Gen it looks better and it is very easy to read the thread. Thank you. Keep on good work!
Features added using Post generator (3fan)
[-] The following 15 users Like lisine's post:15 users Like lisine's post
  β€’ kowheng, mybest, 3fan, mary, Dell_Brett, ting tsai huang, utan, serhioSPA, tluc, nhim4mat2006, zrilek, malc, Mohammad6299, blaze, shadabg
 lisine
Vanuatu
User ID: 17927
Threads: 265
Given Likes: 4631
04-16-2012, 09:24 AM
Reliability-Based Optimization of Design Code for Tension Piles
Author: Ronold, Knut O. | Size: 91 kB | Format: PDF | Quality: Original preprint | Publisher: Journal of Geotechnical and Geoenvironmental Engineering Vol 125 No. 8 | Year: 1999 | pages: 690-696 | ISSN: 1090-0241
[Image: 62993899302346703828.jpg]
Abstract:
Proposes a reliability-based calibration of a design code for offshore tension pile foundations in clay. Background on offshore tension plies; Loading and response; Capacity; Code calibration; Discussion and conclusions.
[-] The following 10 users Like lisine's post:10 users Like lisine's post
  β€’ kowheng, zrilek, 3fan, Dell_Brett, malc, shadabg, utan, Mohammad6299, blaze, Evandrojr
 lisine
Vanuatu
User ID: 17927
Threads: 265
Given Likes: 4631
07-24-2012, 09:28 AM
Factors Affecting Long-Term Efficiency of Compensation Grouting in Clays
Author: Au S., Soga K., Jafari M., Bolton M., Komiya K. | Size: 0.9 MB | Format: PDF | Quality: Original preprint | Publisher: Journal of Geotechnical & Geoenvironmental Engineering; Vol. 129 Issue 3 | Year: Mar2003 | pages: p254-262, 9p | ISSN: 1090-0241, 1943-5606
Compensation grouting has been attracting attention in recent years to control ground settlement caused by underground construction. A successful and effective application of compensation grouting depends not only on the use of a good monitoring system in the field but also on a fundamental understanding of grout behavior in soils. For compensation grouting in clay, there is a need to consider the long-term effectiveness of compensation grouting. Grout injection tests were conducted in the laboratory to examine soil fracturing patterns and consolidation effects in relation to compensation grouting. Both compaction and hydrofracturing modes of grouting were tested on kaolin clay specimens with different overconsolidation ratios. Finite-element analysis was also conducted to simulate the balloon expansion tests (ideal compaction grouting tests) and the results were compared with the data from the laboratory tests. Based on the research findings, new design criteria are proposed to improve the long-term efficiency of compensation grouting for clays.
[-] The following 12 users Like lisine's post:12 users Like lisine's post
  β€’ kowheng, Dell_Brett, brandizzo, 3fan, malc, zrilek, shadabg, utan, mary, Mohammad6299, blaze, Evandrojr
 lisine
Vanuatu
User ID: 17927
Threads: 265
Given Likes: 4631
10-08-2012, 08:20 AM
Time-Dependent Mechanical Response of HDPE Geomembranes
Author: Merry Scott M., Bray Jonathan D. | Size: 0.96 MB | Format: PDF | Quality: Original preprint | Publisher: Journal of Geotechnical & Geoenvironmental Engineering, Vol. 123 Issue 1 | Year: January 1997 | pages: 57-65, 9p | ISSN: 1090-0241
[Image: 84567691860675284426.jpg]
[-] The following 11 users Like lisine's post:11 users Like lisine's post
  β€’ kowheng, mary, zrilek, malc, devilmaycry, Dell_Brett, Mohammad6299, blaze, Evandrojr, oanm2000, shadabg
 lisine
Vanuatu
User ID: 17927
Threads: 265
Given Likes: 4631
12-11-2012, 09:00 AM
Bearing Capacity of Piled Rafts on Soft Clay Soils
Author: Luca de Sanctis, Alessandro Mandolini | Size: 0.26 MB | Format: PDF | Quality: Original preprint | Publisher: Journal of Geotechnical & Geoenvironmental Engineering, Vol. 132 Issue 12 | Year: December 2006 | pages: p1600-1610, 11p
[Image: 39047930632968402555.jpg]
[-] The following 8 users Like lisine's post:8 users Like lisine's post
  β€’ Dell_Brett, kowheng, blaze, mary, malc, oanm2000, tluc, shadabg
 lisine
Vanuatu
User ID: 17927
Threads: 265
Given Likes: 4631
12-26-2012, 02:09 PM
Performance of a Cantilever Retaining Wall
Author: Bentler Joseph, Labuz Joseph | Size: 0.2 MB | Format: PDF | Quality: Original preprint | Publisher: Journal of Geotechnical & Geoenvironmental Engineering, Vol. 132, Issue 8, | Year: August 2006 | pages: p1062-1070, 9p
[Image: 70746261648303262650.jpg]
[-] The following 7 users Like lisine's post:7 users Like lisine's post
  β€’ Dell_Brett, Songoku, kowheng, tluc, blaze, malc, shadabg
 lisine
Vanuatu
User ID: 17927
Threads: 265
Given Likes: 4631
01-07-2013, 09:25 AM
Contribution to Piled Raft Foundation Design
Author: Prakoso Widjojo, Kulhawy Fred | Size: 1.6 MB | Format: PDF | Quality: Scanner | Publisher: Journal of Geotechnical & Geoenvironmental Engineering, Vol. 127 Issue 1 | Year: Jan2001 | pages: 17-24
[Image: 72175307714544978775.jpg]
Simplified Nonlinear Analysis for Settlement Prediction of Pile Groups
Author: Castelli Francesco, Maugeri Michael | Size: 0.46 MB | Format: PDF | Quality: Original preprint | Publisher: Journal of Geotechnical & Geoenvironmental Engineering, Vol. 128 Issue 1 | Year: January 2002 | pages: 76-84
[Image: 62992631478977477988.jpg]
Both papers
  β€’ ssobhan, kowheng, blaze, oanm2000, Dell_Brett, malc, tluc, mary, KhaLed-S.E, shadabg
 mary
User ID: 31558
Threads: 37
Likes: 341 in 77 posts
Given Likes: 692
01-09-2013, 09:39 PM
Physical Modeling of Raft on Settlement Reducing Piles
Author: Vincenzo Fioravante; Daniela Giretti; and Michele Jamiolkowski | Size: 7 MB | Format: PDF | Quality: Unspecified | Publisher: From Research to Practice in Geotechnical Engineering | Year: 2008 | pages: 24
[Image: 77514211424084974304.jpg]
The paper presents the results of extensive centrifuge tests modeling rigid circular piled rafts laying on a bed of loose very fine silica sand. The tests were aimed at investigating the behavior of rafts on settlement reducing piles. The testing program included: an unpiled raft, rafts on 1, 3, 7 and 13 piles. In each test, some model piles were instrumented with load cells to determine the distribution of load along the shaft. Beneath the rafts, two types of model piles, close-ended and free headed were installed: quasi displacement (QD) and quasi-non displacement (QND) piles. The obtained results permitted figuring out the role of piles in terms of their effectiveness as settlement reducers and to quantify the load sharing mechanism between piles and the raft-soil contact. The tests were aimed at investigating the load transfer mechanisms adopted in the design approach, and in particular at validating a numerical code which can be used in engineering practice. The paper describes the details of experiments undertaken, the adopted procedures and some of the results; where not specified, all the experimental data given in this paper referred to model scale. The adopted numerical code is briefly described and its validation, via test results on quasi-non displacement piles, is also reported.
[-] The following 7 users Like mary's post:7 users Like mary's post
  β€’ KhaLed-S.E, Dell_Brett, malc, lisine, tluc, kowheng, shadabg
 lisine
Vanuatu
User ID: 17927
Threads: 265
Given Likes: 4631
01-17-2013, 12:43 PM
Intramethod Variability in ReMi Dispersion Measurements and Vs Estimates at Shallow Bedrock Sites
Author: Cox Brady R., Beekman Andrew N. | Size: 1.1 MB | Format: PDF | Quality: Original preprint | Publisher: Journal of Geotechnical & Geoenvironmental Engineering, Vol. 137, Issue 4 | Year: Apr2011 | pages: 354-362
[Image: 33467576353755211911.jpg]
[-] The following 6 users Like lisine's post:6 users Like lisine's post
  β€’ giguni, kowheng, tluc, Dell_Brett, shadabg, malc
 lisine
Vanuatu
User ID: 17927
Threads: 265
Given Likes: 4631
#10
02-06-2013, 11:50 AM
Centrifuge testing of large laterally loaded pile groups in sands
Author: McVay Michael; Zhang Limin | Size: 1.01 MB | Format: PDF | Quality: Scanner | Publisher: Journal of Geotechnical & Geoenvironmental Engineering, Vol. 124, Issue 10 | Year: Oct 1998 | pages: 1016-1026
[Image: 87486450793829017965.jpg]
  β€’ freequo, kowheng, Grunf, mary, Dell_Brett, shadabg, malc, uetian19
Pages (2): 1 2 Next »
  Journal of Wind Engineering and Industrial Aerodynamics foxxx2010 39 57,581 01-27-2021, 12:55 AM
Last Post: civilphongvan
  ASCE Journal of Structural Engineering (2003~ 2009) Badis 5 13,067 03-23-2017, 03:27 PM
Last Post: camto2
  B&SE - The Bridge & Structural Engineering Journal RyanRS 1 7,037 11-22-2015, 09:08 PM
  Paper of Journal of Engineering Mechanics peixoto 1 5,942 12-01-2010, 05:11 PM
Last Post: hich
  Journal of Engineering Mechanics 1983;109(3):691–705. lizard 1 5,799 11-26-2010, 01:25 PM
Last Post: hich
