Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Books and Codes Request [REQUEST] Worked Examples to Eurocode 2: Volume 1
[Request] Worked Examples to Eurocode 2: Volume 1
 zeljko2
Guest
Guests
Likes: 0 in 0 posts
Given Likes:
02-19-2012, 09:01 PM (This post was last modified: 02-19-2012, 09:26 PM by Grunf.)
I need this book:
Title: Worked Examples to Eurocode 2: Volume 1
ISBN:1-904818-84-7
Published: 2010
Publisher: MPA - The Concrete Centre
Description: The aim of this publication is to illustrate through worked examples how BS EN 1992-1-1 (Eurocode 2) may be used in practice to design in-situ concrete building structures. It is intended that these worked examples will explain how calculations to Eurocode 2 may be performed. To download the Errata document for this publication visit
  â€¢
Threads: 307
02-19-2012, 09:36 PM (This post was last modified: 02-19-2012, 09:38 PM by Grunf.)
What about:
[-] The following 6 users Like Grunf's post:6 users Like Grunf's post
  â€¢ Petrit, Mouh@ndiss, Dell_Brett, malc, cve_jule, adams
 concreteok
E-Book Moderator
Malaysia
User ID: 4764
Threads: 38
Likes: 4,964 in 638 posts
Given Likes: 3501
02-20-2012, 10:54 AM
This thread shall remained in REQUEST section.
concrete solution advocate
  â€¢
 gianniorlati
Senior Underground Works Engineer
Italy
User ID: 46169
Threads: 64
Likes: 1,673 in 128 posts
Given Likes: 429
06-27-2020, 10:01 AM
What about Volume 2?
Does anybody know if this second volume has aver been released as a separate issue?
On the Concrete Centre site now, there's a "Worked Examples to Eurocode 2" volume which, seemingly, does not distinguish between volume 1 and 2, hence, I'm confused.
I'd like to buy it but only if it contains what, supposedly, was contained in Volume 2.
[-] The following 1 user Likes gianniorlati's post:1 user Likes gianniorlati's post
  â€¢ hatkam
  [REQUEST] Design of Composite Steel and Concrete Structures with Worked Examples to Eurocode 4 jmksq 0 1,585 03-04-2017, 03:07 PM
Last Post: jmksq
  [REQUEST] Design of Steel Structures with Worked Examples to EN1993-1-1 and EN1993-1-8 jmksq 0 1,379 03-04-2017, 03:02 PM
Last Post: jmksq
