Civil Engineering Association Various Free Discussion [PROBLEM] PDF Secure
[Problem] PDF Secure
 mybest
Indonesia
User ID: 32155
Threads: 265
Likes: 3,957 in 566 posts
Given Likes: 686
01-20-2012, 01:59 PM
Dear member.
I have question to ask
1. How to remove "secure" of pdf? For example if I want to insert a page into my pdf file.
2. How to make my pdf file to became "real secure" so no one can edit?
Regards.
mybest
[-] The following 1 user Likes mybest's post:1 user Likes mybest's post
  โ€ข uetian19
 ynopum
Burundi
User ID: 2733
Threads: 24
Likes: 2,399 in 365 posts
Given Likes: 155
01-20-2012, 02:14 PM
Use this program to remove the protection:
๐Ÿ‘‰ CLICK HERE ๐Ÿ‘ˆ
There are 3 types of protection of PDF files:
1. Forbid editing (copy, print, etc.) - this can be very easily bypassed using the above program.
2. Use a password to open the file - this can be bypassed by the above program, but needs too much time. Also anybody who tries to open the PDF needs the password to do so. Then, having the password he can do almost everything with the PDF.
3. Use tricks. The variety of these is not big. Generally the idea is to make the data in the PDF difficult to be edited:
- decomposing the text letters to splines, or other graphics objects, so simple copying of the text will not work anymore.
- converting the graphics to a raster image.
- splitting the raster image to many small raster images.
Generally all these can be bypassed using OCR programs like Abby FineReader that convert raster images to some other usable format.
There should be also some option to make "improper" PDF file, that can be opened properly by Acrobat. I haven't seen yet such intentionally "damaged PDFs" that open with mistake.
Another question is if you need to show somebody that a file has been edited - this is called usually "signature". It gives information if the file was kept untouched, or not.
[-] The following 5 users Like ynopum's post:5 users Like ynopum's post
  โ€ข 3fan, malc, Grunf, Dell_Brett, mybest
 mybest
Indonesia
User ID: 32155
Threads: 265
Given Likes: 686
01-22-2012, 01:15 AM
Thank you ynopum, It's the answer for question number 1. Is there any answer to question number 2? Is it possbile to make my pdf file "Real Secure"? I don't want someone use this application to delete protection of my file.
regards.
mybest.
  โ€ข
 ynopum
Burundi
User ID: 2733
Threads: 24
Given Likes: 155
01-22-2012, 11:37 AM
As I can't imagine your specific case (type of the contents, what users will try to modify it, and what they may want to modify) I will suggest you the following easy way for raster conversion, that will prevent easy copying, and modifying especially of the text contents.
1. Make your PDF
2. Open it in Adobe Acrobat (the full one, not "reader' only)
3. Export the PDF to a raster images (File/Export/Image/PNG) giving a proper resolution, at least 300 dpi if you want the prints to look nice)
4. Close the file and create a new PDF using these exported images (there are several ways to reach this option in Adobe Acrobat).
This doesn't protect from printing!
[-] The following 3 users Like ynopum's post:3 users Like ynopum's post
  โ€ข 3fan, Sumatra, Grunf
 Dell_Brett
Admin Deputy
Admin Deputy
Brazil
User ID: 4
Threads: 246
Likes: 19,038 in 2,189 posts
Given Likes: 42508
01-22-2012, 11:42 AM
Iยดm afraid that is not enough!
A good OCR program can restore "quasi" 100% of the contents...
[-] The following 3 users Like Dell_Brett's post:3 users Like Dell_Brett's post
  โ€ข 3fan, mybest, Grunf
 ynopum
Burundi
User ID: 2733
Threads: 24
Given Likes: 155
01-22-2012, 01:36 PM
If the data is "top-secret" somebody can make an .exe program that shows the pages (raster images would be the easiest way to be used in standalone executable), and the program can disable Printscreen button, also any known OCR applications that are loaded in the memory, etc.
Another option is to use a Flash application style, as this is very popular way to prevent the users from mass-copying documents on webpages. In this case the user's browser will be used to show the flash document.
It depends how "deep" is the problem with security. And regarding we are bounded to the PDF format there aren't many options to keep the document pleasantly readable for the human, and difficult to be recognized by OCR software.
  โ€ข 3fan, Sumatra, Grunf, Dell_Brett, mybest
