Civil Engineering Association Software Software Product Bentley Products Bentley RAM Elements (SELECT Series 3) 12.05.00.12 + 12.05.01.18 update
Threads: 1,118
12-31-2011, 06:42 AM (This post was last modified: 06-09-2012, 09:02 PM by oanm2000.)
Size: 329.56 + 56.24 MB
[Image: 86510753862874684181.gif]
This program provides unequaled flexibility for the design and analysis of different types of 2D or 3D structures containing linear members and shell elements.
The types of analysis available are: First order (Linear Analysis), Second order (P-Delta Analysis) and Dynamic (Seismic Analysis).
In addition, RAM Elements is also capable of designing hot-rolled or cold-formed steel members, wood (sawn lumber and glulam) and reinforced concrete members using the AISC 360-05 ASD, AISC 360-05 LRFD , BS 5950-00, AISI 01 ASD, AISI 01 LRFD, AS4100-98, NDS 05 ASD, ASD 05 LRFD, ACI 318-99, ACI 318-05 y BS8110-97 codes respectively. The program includes special modules for designing spread footings, combined footings, reinforced concrete columns, retaining walls, concrete walls, tilt-up walls, masonry walls, continuous beams and trusses. Additionally RAM Elements has links with RAM Connection, a revolutionary tool that allows the fast design of steel connections inside or outside RAM Elements, STAAD.Pro, the RAM Structural System and ProSteel (SDNF).
[Image: tips.png]
See struceng solution
or
Password:
CivilEA
[-] The following 47 users Like BennyP's post:47 users Like BennyP's post
  β€’ kowheng, mahyarov, malc, maad59, blaze, pingfan2, wesam_19701970, Dell_Brett, aema, cordoba123, panchotevi, Octavio, ecarkarq, liamsi, ripach, coxxxyboy, benny, tarugo, aguila, jjmtz, kimjos, stash, Vanfa, jokerβ„’, horacio, RICARDI, yutt, lgarg, jose19356, oanm2000, 88FeNIX, AVHEAG, nickycruz, ali akbar, zrilek, royal_eagle, simanta, khang02, ykhackhack, anurrba, albani, odiclas, pedzaquino, bigone, subin91, Nilupa, valinhas
Away  jokerβ„’
User ID: 10925
Threads: 79
Likes: 7,246 in 938 posts
Given Likes: 2428
01-09-2012, 12:11 PM
Mirror
OR
No limits to creativity
[-] The following 15 users Like jokerβ„’'s post:15 users Like jokerβ„’'s post
  β€’ 3fan, Dell_Brett, valinhas, oanm2000, fretts08, 88FeNIX, ykhackhack, ali akbar, zrilek, blaze, simanta, pedzaquino, bigone, narendra, Nilupa
Away  jokerβ„’
User ID: 10925
Threads: 79
Given Likes: 2428
04-29-2012, 03:22 PM
[-] The following 14 users Like jokerβ„’'s post:14 users Like jokerβ„’'s post
  β€’ zrilek, oanm2000, Dell_Brett, valinhas, haze, ykhackhack, albani, pedzaquino, bigone, narendra, subin91, araza023, Nilupa, oreslaw
 tomdavar
User ID: 4999
Threads: 2
Likes: 86 in 17 posts
Given Likes: 56
05-28-2012, 03:15 AM
RAM Elements v12.5.2 Update
Update only
[-] The following 14 users Like tomdavar's post:14 users Like tomdavar's post
  β€’ zrilek, coxxxyboy, blaze, albani, ykhackhack, oanm2000, haze, benny, RICARDI, Dell_Brett, valinhas, jokerβ„’, bigone, Nilupa
Away  jokerβ„’
User ID: 10925
Threads: 79
Given Likes: 2428
06-24-2012, 10:57 AM
Install Bentley RAM Elements (SELECT Series 3) 12.05.00.12
Update
[-] The following 8 users Like jokerβ„’'s post:8 users Like jokerβ„’'s post
  β€’ oanm2000, haze, zrilek, bigone, Dell_Brett, araza023, Nilupa, valinhas
 ykhackhack
United States
User ID: 36960
Likes: 3,670 in 707 posts
Given Likes: 8693
09-08-2012, 03:24 AM
[-] The following 9 users Like ykhackhack's post:9 users Like ykhackhack's post
  β€’ coxxxyboy, mahyarov, Dell_Brett, oanm2000, araza023, Nilupa, bigone, fefdbi, davegabj
  Bentley RAM Elements v23 poolmand 0 4,161 10-04-2023, 08:33 AM
  Bentley RAM Elements CONNECT Edition V16 Update 5 v16.05.00.213 x64 poolmand 0 4,682 11-23-2021, 07:08 AM
  Bentley ProStructures CONNECT Edition Update 5.2 (10.05.02.50) x64 poolmand 0 4,451 10-19-2021, 12:01 PM
  Bentley OpenPlant Modeler CONNECT Edition V10 Update 9 (10.09.00.74) x64 poolmand 0 3,931 10-17-2021, 01:06 PM
  Bentley SACS Connect V11 update 3 er.shyams 2 7,605 02-13-2021, 04:30 AM
Last Post: structural
  Bentley RAM Concept v06.02.00.014 Connect Edition Update 2 KhaLed-S.E 2 8,010 09-08-2020, 09:06 AM
  Portable Bentley RAM Connection V8i (SELECT Series 3) 7.3.1 jamildear4u 4 17,120 09-25-2017, 06:25 PM
Last Post: Aviator
