Civil Engineering Association eBooks Codes, Manual & Handbook British Standards (BS) BS EN ISO 12958:2010 Geotextiles and geotextile-related products
 mybest
Indonesia
User ID: 32155
Threads: 265
Likes: 3,957 in 566 posts
Given Likes: 686
12-26-2011, 02:02 AM
BS EN ISO 12958:2010 Geotextiles and geotextile-related products. Determination of water flow capacity in their plane
Size: 588 KB | Format: PDF | Publisher: BSI | Year: 31 May 2010 | pages: 20 | ISBN: 978 0 580 68000 7
[Image: 74115937271450787446.png]
BS EN ISO 12958 is an International Standard which specifies a method for determining the constant-head water flow capacity within the plane of a geotextile or geotextile-related product.
If the full water flow capacity characteristics of the geotextile or geotextile-related product have previously been established, then for control purposes it can be sufficient to determine the water flow capacity at two loads and both gradients.
The compressibility of the product over time will substantially influence the in-plane water flow capacity. Test methods for assessing the compressive creep behaviour of geotextiles or geotextile-related products are described in ISO 25619-1.
The test report is judged in conjunction with the long-term compressive creep behaviour in order to assess the long-term flow capacity.
Contents of BS EN ISO 12958:
Foreword
1 Scope
2 Normative references
3 Terms and definitions
4 Principle
5 Apparatus and materials
6 Specimens
6.1 Handling
6.2 Selection
6.3 Number and dimensions
6.4 Specimen condition
7 Test procedure
8 Calculations and expression of results
9 Test report
Annex A (informative) Determination of the correction factor RT for conversion to a water temperature of 20 °C
Annex B (informative) Experimental data and calculations for a specimen
Bibliography
[-] The following 8 users Like mybest's post:8 users Like mybest's post
  • utan, Jackass, kowheng, vpmohammed, ir_71, kvtasp, peixoto, Dell_Brett
 kvtasp
User ID: 7690
Threads: 60
Likes: 2,028 in 379 posts
Given Likes: 791
12-29-2011, 03:03 AM
[-] The following 1 user Likes kvtasp's post:1 user Likes kvtasp's post
  • blaze
 arshiakh
User ID: 37777
Threads: 97
Likes: 3,224 in 617 posts
Given Likes: 214
02-22-2013, 07:34 AM
[/MIRROR] 🔽🔽🔽🔽🔽🔽🔽🔽🔽
  BS EN ISO 11058:2010 Geotextiles and geotextile-related products mybest 2 2,308 02-22-2013, 07:44 AM
Last Post: arshiakh
  BS EN ISO 12956:2010 Geotextiles and geotextile-related products mybest 2 2,301 02-22-2013, 07:30 AM
Last Post: arshiakh
  BS EN 13170:2008 Thermal insulation products for buildings - Factory made products of ir_71 0 1,847 12-26-2011, 09:06 AM
  BS EN 13164:2008 Thermal insulation products for buildings - Factory made products of ir_71 0 1,893 12-25-2011, 05:08 PM
