Civil Engineering Association eBooks Codes, Manual & Handbook British Standards (BS) BS 644:2009 Timber windows. Fully finished factory-assembled windows of various types
 mybest
Indonesia
User ID: 32155
Threads: 265
Likes: 3,957 in 566 posts
Given Likes: 686
12-16-2011, 10:21 AM
BS 644:2009 Timber windows. Fully finished factory-assembled windows of various types. Specification
Size: 748 KB | Format: PDF | Year: 28 February 2009 | pages: 28 | ISBN: 978 0 580 56200 6
[Image: 01839878887679043429.png]
BS 644 specifies requirements for the design, construction and performance of fully finished and glazed factory-assembled timber windows of various types.
It applies to windows that have been treated with either opaque, non-opaque finishes, or that are designed to support an externally fixed covering of another material, and that have been factory-glazed. It does not apply to windows supplied as kits for site assembly.
BS 644 applies to windows fabricated into frames in a factory, to be installed vertically (±15°) into the external face of buildings, as single or multi-light units, in coupled assemblies when appropriate, of the following types:
a) Hinged: side-hung (open in or out), top-hung (open out), bottom hung (open in), tilt and turn or turn before tilt
b) Projecting: side-hung (open in or open out) and top-hung (open out)
c) Pivoted: horizontal and vertical (hung centrally or off-centre)
d) Sliding: horizontal and vertical
e) Side-hung and top-hung (open out) fully reversible
f) Fixed light
g) Direct glazed frames.
BS 644 should be used for assemblies in which any frame member is not longer than 3 m. It does not apply to curtain walls that span across horizontal structural members of floors but does apply to windows within a curtain walling system. It is also applicable to assemblies up to the factory gate.
[-] The following 3 users Like mybest's post:3 users Like mybest's post
  • kowheng, Jackass, kvtasp
 kvtasp
User ID: 7690
Threads: 60
Likes: 2,028 in 379 posts
Given Likes: 791
12-22-2011, 02:50 PM
[-] The following 2 users Like kvtasp's post:2 users Like kvtasp's post
  • kowheng, peixoto
 arshiakh
User ID: 37777
Threads: 97
Likes: 3,224 in 617 posts
Given Likes: 214
02-25-2013, 07:12 AM
[/MIRROR] 🔽🔽🔽🔽🔽🔽🔽🔽🔽
[-] The following 3 users Like arshiakh's post:3 users Like arshiakh's post
  • narendra, Dell_Brett, knrsa
  BS EN 408:2010 Timber structures - Structural timber and glued laminated timber - Det ir_71 1 3,944 08-30-2023, 06:30 PM
Last Post: albani
  BS 8213-1:2004 Windows doors and rooflights mybest 2 2,866 07-14-2014, 06:08 AM
Last Post: wisamnn
  BS EN 949:1999 Windows and curtain walling, doors, blinds and shutters mybest 1 2,064 02-21-2013, 01:40 PM
Last Post: arshiakh
  BS 7668:2004 Weldable structural steels — Hot finished structural hollow sections in ir_71 1 2,545 02-18-2013, 12:19 PM
  BS 6375:2009 part 1, 2 and 3 Performance of windows and doors ir_71 1 2,650 09-22-2012, 04:49 AM
