Civil Engineering Association eBooks Codes, Manual & Handbook British Standards (BS) BS 7985:2002 Code of Practice for the use of rope access methods for industrial purpo
 mybest
Indonesia
User ID: 32155
Threads: 265
Likes: 3,957 in 566 posts
Given Likes: 686
12-13-2011, 11:12 AM
BS 7985:2002 Code of Practice for the use of rope access methods for industrial purposes
Size: 1.33 KB | Format: PDF | Publisher: BSI | Year: 28 February 2002 | pages: 68 | ISBN: 0 580 38790 9
[Image: 66985067743130053029.png]
Recommendations on the use of rope access methods for work at height.
Abstract
This British Standard provides recommendations and guidance on the use of rope access methods for work at a height. It is intended for use by employers, employees and self-employed persons who use rope access methods, and those who commission rope access work, e.g. building owners and contractors.
This British Standard is applicable to the use of rope access methods for access to buildings, other structures (on or offshore) or natural features (such as cliff faces), in which the ropes are suspended from or connected to the structure or natural feature. It is applicable to situations where ropes are used as the primary means of access, egress or support and as the primary means of protection against a fall.
This standard is not intended to apply to the use of rope access methods for leisure activities, arboriculture, general steeplejack methods or emergency personal evacuation systems, or to the use of rope access (line rescue) techniques by the fire brigade and other emergency services for rescue work or for training.
[-] The following 5 users Like mybest's post:5 users Like mybest's post
  â€¢ kowheng, ting tsai huang, vpmohammed, Jackass, kvtasp
 kvtasp
User ID: 7690
Threads: 60
Likes: 2,028 in 379 posts
Given Likes: 791
12-22-2011, 02:55 PM
[-] The following 1 user Likes kvtasp's post:1 user Likes kvtasp's post
  â€¢ peixoto
 arshiakh
User ID: 37777
Threads: 97
Likes: 3,224 in 617 posts
Given Likes: 214
02-26-2013, 06:30 AM
[/MIRROR] 🔽🔽🔽🔽🔽🔽🔽🔽🔽
  â€¢
  BS 8006-1: Code of practice for Strengthened/reinforced soils and other fills ir_71 8 8,233 05-29-2024, 12:10 PM
  BS 5930:2015+A1:2020 - Code of practice for ground investigations concreteok 0 3,922 07-25-2023, 10:35 AM
Last Post: concreteok
  BS 6349-1: Maritime Structures: Code of Practice for General Criteria Gabemzaman 9 10,206 06-07-2023, 05:10 AM
Last Post: ersin
  BS 8476: Code of practice for the safe use of concrete pumps ir_71 2 3,431 02-12-2022, 08:00 AM
  BS 5262:1991 Code of practice for External renderings ir_71 3 3,719 07-31-2021, 08:00 PM
Last Post: monter
  BS 8102:1990 Code of practice for Protection of structures against water from the gro ir_71 6 5,299 07-31-2021, 07:54 PM
Last Post: monter
  BS 8102:2009 - Code of practice for protection of below ground structures against wat Mohammad6299 1 2,552 02-17-2021, 11:20 AM
Last Post: temp1366
