Civil Engineering Association eBooks Journals, Papers and Presentations [Techno Press] Structural Engineering and Mechanics
 mybest
Indonesia
User ID: 32155
Threads: 265
Likes: 3,957 in 566 posts
Given Likes: 686
11-29-2011, 01:10 AM (This post was last modified: 11-29-2011, 01:22 AM by mybest.)
Volume 40, Number 1, October10 2011
Size: Total 15.5 MB | Format: PDF | Publisher: Techno Press | Year: 2011
[Image: 86948332179734936511.gif]
1. Ambient vibration tests on a 19 – story asymmetric steel building
H. Shakib and N. Parsaeifard
2. Structural damage identification of plates based on modal data using 2D discrete wavelet transform
A. Bagheri, G. Ghodrati Amiri, M. Khorasani and H. Bakhshi
3. Incorporating uplift in the analysis of shallowly embedded pipelines
Yinghui Tian and Mark J. Cassidy
4. Investigation on electromagnetothermoelastic interaction of functionally graded piezoelectric hollow spheres
Hong-Liang Dai and Yan-Ni Rao
5. A simple mathematical model for static analysis of tall buildings with two outrigger-belt truss systems
Reza Rahgozar, Ali Reza Ahmadi, Omid Hosseini and Mohsen Malekinejad
6. Integrating OpenSees with other software - with application to coupling problems in civil engineering
Quan Gu and Ozgur Ozcelik
7. Experimental study on long-term behaviour of CFRP strengthened RC beams under sustained load
Ehsan Ahmed and Habibur Rahman Sobuz
8. Closed form solutions for element equilibrium and flexibility matrices of eight node rectangular plate bending element using integrated force method
H.R. Dhananjaya, P.C. Pandey, J. Nagabhushanamb and Ismail Othamon
[-] The following 22 users Like mybest's post:22 users Like mybest's post
  β€’ malc, kowheng, henrycv, thebeatles, ssobhan, warbeast, Grunf, gulilero, Dell_Brett, cordoba123, oanm2000, NBZ1400, Sumatra, seriousboy, zrilek, tluc, blaze, ting tsai huang, cace-01, Gkatzogias, sharky, TAFATNEB
 mybest
Indonesia
User ID: 32155
Threads: 265
Given Likes: 686
11-29-2011, 09:23 AM
Volume 40, Number 2, October 25 2011
Size: Total 13.3 MB | Format: PDF | Publisher: Techno Press | Year: 2011
1. Roller compacted concrete pavements reinforced with steel and polypropylene fibers
Morteza Madhkhan, Rasool Azizkhani and Mohammad E. Torki
2. Characterization and shaking table tests of multiple trench friction pendulum system with numerous intermediate sliding plates
C.S. Tsai and Yung-Chang Lin
3. A refined finite element for first-order plate and shell analysis
Sung-Cheon Han, Worsak Kanok-Nukulchai and Won-Hong Lee
4. Experimental and theoretical research on the compression performance of CFRP sheet confined GFRP short pole
Li Chen, Qilin Zhao and Kebin Jiang
5. Model predictive control strategies for protection of structures during earthquakes
Long-He Xu and Zhong-Xian Li
6. Correction of node mapping distortions using universal serendipity elements in dynamical problems
Semih KΓΌΓ§ΓΌkarslan and Ali Demir
7. Large deflection analysis of laminated composite plates using layerwise displacement model
M. Cetkovic and Dj. Vuksanovic
8. Generalized curved beam on elastic foundation solved by transfer matrix method
Marcello Arici and Michele Fabio Granata
[-] The following 13 users Like mybest's post:13 users Like mybest's post
  β€’ cordoba123, kowheng, oanm2000, NBZ1400, Sumatra, malc, seriousboy, Dell_Brett, zrilek, tluc, blaze, ting tsai huang, cace-01
 mybest
Indonesia
User ID: 32155
Threads: 265
Given Likes: 686
11-30-2011, 03:03 AM (This post was last modified: 11-30-2011, 03:04 AM by mybest.)
Volume 40, Number 3, November10 2011
Size: 19 MB | Format: PDF | Publisher: Techno Press | Year: 2011
1. A method for evaluation of longitudinal joint connections of decked precast concrete girder bridges
Matthew Z. Smith, Yue Li and William M. Bulleit
2. Modeling of triple concave friction pendulum bearings for seismic isolation of buildings
Muhammet Yurdakul and Sevket Ates
3. Bifurcations of non-semi-simple eigenvalues and the zero-order approximations of responses at critical points of Hopf bifurcation in nonlinear systems
Yu Dong Chen, Chun Yan Pei and Su Huan Chen
4. Post-buckling analysis of Timoshenko beams with various boundary conditions under non-uniform thermal loading
Turgut Kocaturk and Seref Doguscan Akbas
5. Vibration attenuation in periodic composite Timoshenko beams on Pasternak foundation
Hong-Jun Xiang and Zhi-Fei Shi
6. An incompatible 3D solid element for structural analysis at elevated temperatures
Xinmeng Yu, Xiaoxiong Zha and Zhaohui Huang
7. Behavior of reinforced concrete beams filled with demolished concrete lumps
Bo Wu, Zhe Xu, Zhongguo John Ma, Qiongxiang Liu and Wei Liu
8. Active control of a nonlinear and hysteretic building structure with time delay
Kun Liu, Long-Xiang Chen and Guo-Ping Cai
  β€’ Sumatra, malc, kowheng, seriousboy, Dell_Brett, zrilek, oanm2000, Jackass, tluc, NBZ1400, blaze, cace-01, ting tsai huang
 mybest
Indonesia
User ID: 32155
Threads: 265
Given Likes: 686
12-01-2011, 11:07 AM
Volume 40, Number 4, November25 2011
Size: Total 34 MB | Format: PDF | Publisher: Techno Press | Year: 2011
Experimental study on Chinese ancient timber-frame building by shaking table test
Xi-cheng Zhang, Jian-yang Xue, Hong-tie Zhao and Yan Sui
Simulation of vibrations of Ting Kau Bridge due to vehicular loading from measurements
F.T.K. Au, P. Lou, J. Li, R.J. Jiang, J. Zhang, C.C.Y. Leung, P.K.K. Lee, J.H. Lee, K.Y. Wong and H.Y. Chan
Influence of near-fault ground motions characteristics on elastic seismic response of asymmetric buildings
R. Tabatabaei and H. Saffari
A study on transverse vibration characteristics of a sandwich plate with asymmetrical faces
Namshik Ahn and Kangsu Lee
Shake-table responses of a low-rise RC building model having irregularities at first story
Han Seon Lee, Dong Wook Jung, Kyung Bo Lee, Hee Cheul Kim and Kihak Lee
Concurrent flexural strength and deformability design of high-performance concrete beams
J.C.M. Ho and K.J.H. Zhou
Stability analysis of bimodular pin-ended slender rod
Wenjuan Yao, Jianwei Ma and Baolin Hu
Free vibration of an axially functionally graded pile with pinned ends embedded in Winkler-Pasternak elastic medium
Dogan Cetin and Mesut Simsek
[-] The following 7 users Like mybest's post:7 users Like mybest's post
  β€’ Dell_Brett, kowheng, tluc, NBZ1400, seriousboy, blaze, cace-01
 mybest
Indonesia
User ID: 32155
Threads: 265
Given Likes: 686
12-03-2011, 09:48 AM
Volume 40, Number 5, December10 2011
Size: Total 27 MB | Format: PDF | Publisher: Techno Press | Year: December10 2011
High-velocity impact of large caliber tungsten projectiles on ordinary Portland and calcium aluminate cement based HPSFRC and SIFCON slabs. Part I: experimental investigations
H. Korucu and P. Gulkan
Abstract; Full Text (10925K)
High-velocity impact of large caliber tungsten projectiles on ordinary Portland and calcium aluminate cement based HPSFRC and SIFCON slabs. Part II: numerical simulation and validation
P. Gulkan and H. Korucu
Abstract; Full Text (7955K)
Free vibration of a rectangular plate with an attached three-degree-of-freedom spring-mass system
M. Febbo, D.V. Bambill and R.E. Rossi
Abstract; Full Text (808K)
Loss of strength in asbestos-cement water pipes due to leaching
Lluis Gil, Marco A. Perez, Ernest Bernat and Juan J. Cruz
Abstract; Full Text (2438K)
Hydroelastic vibration analysis of liquid-contained rectangular tanks
Kyeong-Hoon Jeong
Abstract; Full Text (2120K)
A modified modal perturbation method for vibration characteristics of non-prismatic Timoshenko beams
Danguang Pan, Genda Chen and Menglin Lou
Abstract; Full Text (546K)
Parametrically excited viscoelastic beam-spring systems: nonlinear dynamics and stability
Mergen H. Ghayesh
Abstract; Full Text (630K)
Hybrid damage monitoring of steel plate-girder bridge under train-induced excitation by parallel accelerationimpedance approach
D.S. Hong, H.J. Jung and J.T. Kim
Abstract; Full Text (5258K)
[-] The following 9 users Like mybest's post:9 users Like mybest's post
  β€’ Dell_Brett, kowheng, jcbv, NBZ1400, seriousboy, marion33, malc, blaze, cace-01
 mybest
Indonesia
User ID: 32155
Threads: 265
Given Likes: 686
12-04-2011, 05:46 AM
Volume 39, Number 1, July10 2011
Size: Total 38 MB | Format: PDF | Publisher: Techno Press
Applications of Hilbert-Huang transform to structural damage detection
Dung-Jiang Chiou, Wen-Ko Hsu, Cheng-Wu Chen, Chih-Min Hsieh, Jhy-Pyng Tang and Wei-Ling Chiang
Abstract; Full Text (6864K)
Physics based basis function for vibration analysis of high speed rotating beams
R. Ganesh and Ranjan Ganguli
Abstract; Full Text (3903K)
An accurate substructural synthesis approach to random responses
Z.G. Ying, W.Q. Zhu, S.Q. Ye and Y.Q. Ni
Abstract; Full Text (1974K)
Study on damage detection software of beam-like structures
Jiawei Xiang, Zhansi Jiang, Yanxue Wang and Xuefeng Chen
Abstract; Full Text (3272K)
Geodesic shape finding of membrane structure with geodesic string by the dynamic relaxation method
K.S. Lee and S.E. Han
Abstract; Full Text (16183K)
A note on buckling and vibration of clamped orthotropic plates under in-plane loads
D.H. Felix, D.V. Bambill and C.A. Rossit
Abstract; Full Text (291K)
Experimental and analytical investigation on seismic behavior of RC framed structure by pushover method
Akanshu Sharma, G.R. Reddy, R. Eligehausen and K.K. Vaze
Abstract; Full Text (4794K)
Capacity design by developed pole placement structural control
Fereidoun Amini and Kaveh Karami
Abstract; Full Text (2133K)
[-] The following 8 users Like mybest's post:8 users Like mybest's post
  β€’ Dell_Brett, blaze, kowheng, tluc, malc, cace-01, seriousboy, TAFATNEB
 mybest
Indonesia
User ID: 32155
Threads: 265
Given Likes: 686
12-05-2011, 04:02 PM
Volume 40, Number 6, December25 2011
Size: Total 23 MB | Format: PDF | Publisher: Techno Press
Signal processing based damage detection in structures subjected to random excitations
Luis A. Montejo
Abstract; Full Text (3895K)
Performance-based framework for soil-structure systems using simplified rocking foundation models
J. Paul Smith-Pardo
Abstract; Full Text (2830K)
Local buckling of thin and moderately thick variable thickness viscoelastic composite plates
Nasrin Jafari, Mojtaba Azhari and Amin Heidarpour
Abstract; Full Text (1065K)
A new experimental technique on the tubular joints of spatial grid structures
Zhi-Hua Chen, Guo-Jun Sun and Zhi-Shan Luo
Abstract; Full Text (2795K)
A numerical solution for a finite internally cracked plate using hybrid crack element method
Y.Z. Chen
Abstract; Full Text (309K)
A study on the topographical and geotechnical effects in 2-D soil-structure interaction analysis under ground motion
Oguz Akin Duzgun and Ahmet Budak
Abstract; Full Text (2328K)
Influence of high-cycle fatigue on the tension stiffening behavior of flexural reinforced lightweight aggregate concrete beams
How-Ji Chen, Te-Hung Liu, Chao-Wei Tang and Wen-Po Tsai
Abstract; Full Text (9844K)
Behavior of exterior reinforced concrete beam-column joints including a new reinforcement
Matthew J. Fisher and Halil Sezen
Abstract; Full Text (3609K)
  β€’ malc, Dell_Brett, cace-01, tluc, kowheng, lisine, seriousboy
 mybest
Indonesia
User ID: 32155
Threads: 265
Given Likes: 686
12-13-2011, 10:35 AM
Volume 39, Number 2, July25 2011
Size: Rar 24 MB | Format: PDF | Publisher: Techno Press
Curved laminate analysis
Yih-Cherng Chiang
Abstract; Full Text (2373K)
Damage detection in truss bridges using vibration based multi-criteria approach
H.W. Shih, D.P. Thambiratnam and T.H.T. Chan
Abstract; Full Text (3893K)
Experimental behavior of eccentrically loaded R.C. short columns strengthened using GFRP wrapping
S.K. Elwan and A.S. Rashed
Abstract; Full Text (8249K)
A dynamic nondestructive damage detection methodology for orthotropic plate structures
Amir Hossein Gandomi, Mohammad G. Sahab and Alireza Rahai
Abstract; Full Text (6146K)
Theoretical and experimental serviceability performance of SCCs connections
Ali Akbar Maghsoudi
Abstract; Full Text (7826K)
Prediction of moments in composite frames considering cracking and time effects using neural network models
Umesh Pendharkar, Sandeep Chaudharyb and A.K. Nagpal
Abstract; Full Text (1795K)
Pressure impulse diagrams for simply-supported steel columns based on residual load-carrying capacities
Jong Yil Park and Theodor Krauthammer
Abstract; Full Text (844K)
[-] The following 6 users Like mybest's post:6 users Like mybest's post
  β€’ kowheng, Dell_Brett, tluc, skyscraper, lisine, TAFATNEB
 mybest
Indonesia
User ID: 32155
Threads: 265
Given Likes: 686
12-15-2011, 08:55 AM
Volume 39, Number 3, August10 2011
Size: Rar 19 MB | Format: PDF | Publisher: Techno Press
Corrections for effects of biaxial stresses in annealed glass
Ilham Nurhuda, Nelson T.K. Lam, Emad F. Gad and Ignatius Calderone
Abstract; Full Text (1893K)
Numerical studies on shear connectors in push-out tests under elevated temperatures
Aaron J. Wang
Abstract; Full Text (5458K)
New slave-node constraints and element for adaptive analysis of C0 plates
K.Y. Sze and D. Wu
Abstract; Full Text (3277K)
Efficacy of CFRP configurations for shear of RC beams: experimental and NLFE
Ahmed B. Shuraim
Abstract; Full Text (13437K)
Nonlinear analysis of concrete-filled steel composite columns subjected to axial loading
Alireza Bahrami, Wan Hamidon Wan Badaruzzaman and Siti Aminah Osman
Abstract; Full Text (3872K)
Performance of multi-storey structures with high damping rubber bearing base isolation systems
Turan Karabork
Abstract; Full Text (1112K)
Analytical fragility curves for typical Algerian reinforced concrete bridge piers
Abderrahmane Kibboua, Mounir Naili, Djillali Benouar and Fouad Kehila
Abstract; Full Text (4052K)
Identification of progressive collapse pushover based on a kinetic energy criterion
K. Menchel, T.J. Massart and Ph. Bouillard
Abstract; Full Text (522K)
[-] The following 5 users Like mybest's post:5 users Like mybest's post
  β€’ kowheng, lisine, kvtasp, tluc, Dell_Brett
  [Techno Press] Wind And Structues mybest 3 8,561 12-20-2011, 12:30 PM
Last Post: mybest
