Volume 40, Number 1, October10 2011
Size: Total 15.5 MB | Format: PDF | Publisher: Techno Press | Year: 2011
1. Ambient vibration tests on a 19 β story asymmetric steel building
H. Shakib and N. Parsaeifard
2. Structural damage identification of plates based on modal data using 2D discrete wavelet transform
A. Bagheri, G. Ghodrati Amiri, M. Khorasani and H. Bakhshi
3. Incorporating uplift in the analysis of shallowly embedded pipelines
Yinghui Tian and Mark J. Cassidy
4. Investigation on electromagnetothermoelastic interaction of functionally graded piezoelectric hollow spheres
Hong-Liang Dai and Yan-Ni Rao
5. A simple mathematical model for static analysis of tall buildings with two outrigger-belt truss systems
Reza Rahgozar, Ali Reza Ahmadi, Omid Hosseini and Mohsen Malekinejad
6. Integrating OpenSees with other software - with application to coupling problems in civil engineering
Quan Gu and Ozgur Ozcelik
7. Experimental study on long-term behaviour of CFRP strengthened RC beams under sustained load
Ehsan Ahmed and Habibur Rahman Sobuz
8. Closed form solutions for element equilibrium and flexibility matrices of eight node rectangular plate bending element using integrated force method
H.R. Dhananjaya, P.C. Pandey, J. Nagabhushanamb and Ismail Othamon
π CLICK HERE π
![[Image: 86948332179734936511.gif]](https://pic.civilea.com/images/86948332179734936511.gif)
