Civil Engineering Association eBooks Journals, Papers and Presentations Engineering Structures , Journal
 797880
User ID: 29496
Threads: 6
Likes: 5 in 3 posts
Given Likes: 2
#11
10-17-2011, 02:19 PM
here im china i cannt link to 4shared,thank in advance for giving ifile mirror.
[-] The following 1 user Likes 797880's post:1 user Likes 797880's post
  • pssst
 foxxx2010
Lithuania
User ID: 31627
Threads: 19
Likes: 2,013 in 182 posts
Given Likes: 753
#12
10-18-2011, 06:28 AM
Volume 33, Issue 4, Pages 1075-1402 (April 2011)
Size: 44.7 MB | Format: PDF
1.Editorial Board
Page IFC
2.FRP-strengthened RC slabs anchored with FRP anchors
Pages 1075-1087
Scott T. Smith, Shenghua Hu, Seo Jin Kim, Rudolf Seracino
3.Prediction of vehicle-induced local responses and application to a skewed girder bridge
Pages 1088-1097
Jean-Charles Wyss, Di Su, Yozo Fujino
4.Load-slip relationship of tension reinforcement in reinforced concrete members
Pages 1098-1106
Rahimah Muhamad, M.S. Mohamed Ali, Deric Oehlers, A. Hamid Sheikh
5.A simplified method for collapse capacity assessment of moment-resisting frame and shear wall structural systems
Pages 1107-1116
Behrouz Shafei, Farzin Zareian, Dimitrios G. Lignos
6.On the modal incremental dynamic analysis of reinforced concrete structures, using a trilinear idealization model
Pages 1117-1122
P. Zarfam, M. Mofid
7.The structural behavior and simplified thermal analysis of normal-strength and high-strength concrete beams under fire
Pages 1123-1132
E.G. Choi, Y.S. Shin
8.Performance of cable-stayed bridge pylons subjected to blast loading
Pages 1133-1148
Jin Son, Ho-Jung Lee
9.Seismic response of a continuous bridge with bearing protection devices
Pages 1149-1156
Goutam Ghosh, Yogendra Singh, Shashi Kant Thakkar
10.Slenderness limit of the weak axis in the design of rectangular reinforced concrete non-sway columns
Pages 1157-1165
E. Cortés-Moreno, J.L. Bonet, M.L. Romero, P.F. Miguel
11.Improvement of fatigue properties of orthotropic decks
Pages 1166-1169
L. Frýba, Sh. Urushadze
12.Recent developments in optimal reinforcement of RC beam and column sections
Pages 1170-1180
Luisa María Gil-Martín, Mark Aschheim, Enrique Hernández-Montes, Miguel Pasadas-Fernández
13.Monitoring the structural integrity of a flexible riser during a full-scale fatigue test
Pages 1181-1186
T. Clarke, R. Jacques, A. Bisognin, C. Camerini, S. Damasceno, T. Strohaecker
14.Buckling of very slender metal silos under eccentric discharge
Pages 1187-1194
Adam J. Sadowski, J. Michael Rotter
15.Preconsolidation, structural strength of soil, and its effect on subsoil upper structure interaction
Pages 1195-1204
Pavel Kuklík
16.Use of stability coefficients for evaluating the effect in regular steel moment resisting frames
Pages 1205-1216
E.F. Black
17.Numerical modelling of restrained structural subassemblies of steel beam and CFT columns connected using reverse channels in fire
Pages 1217-1231
S. Elsawaf, Y.C. Wang, P. Mandal
18.Fatigue tests on SMA bars in span control
Pages 1232-1239
Sara Casciati, Alessandro Marzi
19.Inelastic second order analysis of steel frame elements flexed about minor axis
Pages 1240-1250
Ahmed H. Zubydan
20.Response of nonlinear single-degree-of-freedom structures to random acceleration sequences
Pages 1251-1258
Abbas Moustafa, Izuru Takewaki
21.Beam–column element for non-linear dynamic analysis of steel members subjected to blast loading
Pages 1259-1266
A. Heidarpour, M.A. Bradford
22.Load rating of concrete-deck-on-steel-stringer bridges using field-calibrated 2D-grid models
Pages 1267-1276
Ahmet Turer, Bahram M. Shahrooz
23.Mechanical properties of constitutive parameters in steel–concrete interface
Pages 1277-1290
Yong-Hak Lee, Young Tae Joo, Ta Lee, Dong-Ho Ha
24.Earthquake vibration control of structures using hybrid mass liquid damper
Pages 1291-1301
Pradipta Banerji, Avik Samanta
25.Shrinkage effects on the flexural stiffness of composite beams with solid concrete slabs: An experimental study
Pages 1302-1315
Safat Al-deen, Gianluca Ranzi, Zora Vrcelj
26.Global sensitivity analysis of unreinforced masonry structure using high dimensional model representation
Pages 1316-1325
D. Mukherjee, B.N. Rao, A. Meher Prasad
27.Climate change impact and risks of concrete infrastructure deterioration
Pages 1326-1337
Mark G. Stewart, Xiaoming Wang, Minh N. Nguyen
28.Effects of soil–foundation–structure interaction on seismic structural response via robust Monte Carlo simulation
Pages 1338-1347
M. Moghaddasi, M. Cubrinovski, J.G. Chase, S. Pampanin, A. Carr
29.EMD-based random decrement technique for modal parameter identification of an existing railway bridge
Pages 1348-1356
X.H. He, X.G. Hua, Z.Q. Chen, F.L. Huang
30.Evaluating the shear-friction resistance across sliding planes in concrete
Pages 1357-1364
Matthew Haskett, Deric John Oehlers, M.S. Mohamed Ali, Surjit Kumar Sharma
31.A novel adaptive spatial scissor-hinge structural mechanism for convertible roofs
Pages 1365-1376
Yenal Akgün, Charis J. Gantes, Werner Sobek, Koray Korkmaz, Konstantinos Kalochairetis
32.Parametrical study of masonry walls subjected to in-plane loading through numerical modeling
Pages 1377-1389
Vladimir G. Haach, Graça Vasconcelos, Paulo B. Lourenço
33.Numerical analysis of the thermal active restrained shrinkage ring test to study the early age behavior of massive concrete structures
Pages 1390-1401
M. Briffaut, F. Benboudjema, J.M. Torrenti, G. Nahas
34.Calendar
Pages I-II
Volume 33, Issue 3, Pages 689-1074 (March 2011)
Size: 51.8 MB | Format: PDF
1.Editorial Board
Page IFC
Review
2.The influence of bending and shear stiffness and rotational inertia in vibrations of cables: An analytical approach
Pages 689-695
R.A. Sousa, R.M. Souza, F.P. Figueiredo, I.F.M. Menezes
Articles
3.Fragility analysis of track-on steel-plate-girder railway bridges in Korea
Pages 696-705
Joonam Park, Eunsoo Choi
4.Equivalent representations of beams with periodically variable cross-sections
Pages 706-719
Tianxin Zheng, Tianjian Ji
5.A comprehensive probabilistic model of chloride ingress in unsaturated concrete
Pages 720-730
E. Bastidas-Arteaga, A. Chateauneuf, M. Sánchez-Silva, Ph. Bressolette, F. Schoefs
6.Experimental and analytical studies on the rotational stiffness of joints for single-layer structures
Pages 731-737
Aitziber Lopez, Iñigo Puente, Hodei Aizpurua
7.A hybrid structural control system using a tuned liquid damper to reduce the wind induced motion of a base isolated structure
Pages 738-746
J.S. Love, M.J. Tait, H. Toopchi-Nezhad
8.Experiment and numerical modeling of prestressed concrete curved slab with spatial unbonded tendons
Pages 747-756
Nan Zhang, Chung C. Fu, Huimin Che
9.Shake table testing of a full-scale seven-story steel–wood apartment building
Pages 757-766
John W. van de Lindt, Steven E. Pryor, Shiling Pei
10.Effects of near-fault ground motions and equivalent pulses on multi-story structures
Pages 767-779
Reza Sehhati, Adrian Rodriguez-Marek, Mohamed ElGawady, William F. Cofer
11.A loophole in the Eurocode 8 allowing for non-conservative seismic design
Pages 780-785
A. Paglietti, M.C. Porcu, M. Pittaluga
12.A design method for seismically isolated bridges with abutment restraint
Pages 786-795
E. Tubaldi, A. Dall’Asta
13.Pseudo-dynamic tests on low-rise shear walls and simplified model based on the structural frequency drift
Pages 796-812
M. Brun, P. Labbe, D. Bertrand, A. Courtois
14.Seismic response analysis of skew bridges with pounding deck–abutment joints
Pages 813-826
Elias G. Dimitrakopoulos
15.Unified analytical approach for determining shear capacity of RC beams strengthened with FRP
Pages 827-842
V. Colotti, R.N. Swamy
16.Structural analysis of Eduardo Torroja’s Frontón de Recoletos’ roof
Pages 843-854
Jose Antonio Lozano-Galant, Ignacio Payá-Zaforteza
17.Crushing and flexural strength of slab–column joints
Pages 855-867
Roberto Guidotti, Miguel Fernández Ruiz, Aurelio Muttoni
18.Stability of columns with semi-rigid connections including shear effects using Engesser, Haringx and Euler approaches
Pages 868-880
J. Dario Aristizabal-Ochoa
19.Effective flexural stiffness of slender reinforced concrete columns under axial forces and biaxial bending
Pages 881-893
20.Punching of flat slabs with in-plane forces
Pages 894-902
A. Pinho Ramos, Válter J.G. Lúcio, Paul E. Regan
21.Interpretation of concrete dam behaviour with artificial neural network and multiple linear regression models
Pages 903-910
J. Mata
22.Application of the continuous wavelet transform on the free vibrations of a steel–concrete composite railway bridge
Pages 911-919
Mahir Ülker-Kaustell, Raid Karoumi
23.Numerical strategies for prediction of drying cracks in heterogeneous materials: Comparison upon experimental results
Pages 920-931
F. Lagier, X. Jourdain, C. De Sa, F. Benboudjema, J.B. Colliat
24.Seismic resistance of earth construction in Portugal
Pages 932-941
Maria Idália Gomes, Mário Lopes, Jorge de Brito
25.A simplified method for flexural capacity assessment of circular RC cross-sections
Pages 942-946
Edoardo Cosenza, Carmine Galasso, Giuseppe Maddaloni
26.Pseudo-plastic moment resistance of continuous beams with cold-formed sigma sections at internal supports: An experimental study
Pages 947-957
Qiang Liu, Jian Yang, Long-yuan Li
27.Seismic response of low-rise steel moment-resisting frame (SMRF) buildings incorporating nonlinear soil–structure interaction (SSI)
Pages 958-967
Prishati Raychowdhury
28.Investigation on the behavior of brick-infilled steel frames with openings, experimental and analytical approaches
Pages 968-980
A.A. Tasnimi, A. Mohebkhah
29.Steel–Concrete–Steel sandwich slabs with lightweight core — Static performance
Pages 981-992
K.M.A. Sohel, J.Y. Richard Liew
30.Pinching hysteretic response of yielding shear panel device
Pages 993-1000
Zhengying Li, Faris Albermani, Ricky W.K. Chan, S. Kitipornchai
31.Plasticity model for directional nonlocality by tension cracks in concrete planar members
Pages 1001-1012
Jae-Yo Kim, Hong-Gun Park, Seong-Tae Yi
32.An iterative interacting method for dynamic analysis of the maglev train–guideway/foundation–soil system
Pages 1013-1024
Y.B. Yang, J.D. Yau
33.Shear capacity evaluation of steel reinforced recycled concrete (RRC) beams
Pages 1025-1033
Gholamreza Fathifazl, A.G. Razaqpur, O. Burkan Isgor, Abdelgadir Abbas, Benoit Fournier, Simon Foo
34.A new model to simulate joint shear behavior of poorly detailed beam–column connections in RC structures under seismic loads, Part I: Exterior joints
Pages 1034-1051
Akanshu Sharma, R. Eligehausen, G.R. Reddy
35.Buckling restrained braces as structural fuses for the seismic retrofit of reinforced concrete bridge bents
Pages 1052-1061
Samer El-Bahey, Michel Bruneau
36.Strain-based strength model for direct punching shear of interior slab–column connections
Pages 1062-1073
Hong-Gun Park, Kyoung-Kyu Choi, Lan Chung
37.Calendar
Pages I-II
[-] The following 18 users Like foxxx2010's post:18 users Like foxxx2010's post
  • kowheng, blaze, Dell_Brett, chairatpk, jcbv, malc, marion33, pm81, ting tsai huang, mybest, pssst, zrilek, sodapas, ircba, Grunf, SCREAM7890, warbeast, uetian19
 foxxx2010
Lithuania
User ID: 31627
Threads: 19
Given Likes: 753
#13
10-19-2011, 09:46 AM
Volume 33, Issue 2, Pages 273-688 (February 2011)
Size: 64.0 MB | Format: PDF
1.Editorial Board
Page IFC
2.Numerical modelling of the cyclic behaviour of RC elements built with plain reinforcing bars
Pages 273-286
José Melo, Catarina Fernandes, Humberto Varum, Hugo Rodrigues, Aníbal Costa, António Arêde
3.Cyclic out-of-plane behaviour of tall reinforced masonry walls under effects
Pages 287-297
Francesca da Porto, Flavio Mosele, Claudio Modena
4.Derivation of the exact stiffness matrix for a two-layer Timoshenko beam element with partial interaction
Pages 298-307
Quang-Huy Nguyen, Enzo Martinelli, Mohammed Hjiaj
5.Analytical investigation of elastic period of infilled RC MRF buildings
Pages 308-319
Paolo Ricci, Gerardo Mario Verderame, Gaetano Manfredi
6.Determination of the critical loading conditions for bridges under crossing trains
Pages 320-329
Alessandra Zambrano
7.Study of super long span cable-stayed bridges with CFRP components
Pages 330-343
Wen Xiong, C.S. Cai, Yin Zhang, Rucheng Xiao
8.Experimental evaluation of the dynamic properties of a wharf structure
Pages 344-356
Rubén Luis Boroschek, Hugo Baesler, Carlos Vega
9.Development of hurricane resistant traffic signal structures
Pages 357-367
Eric V. Johnson Jr., Ronald A. Cook, Forrest J. Masters, Marcus H. Ansley
10.Shear strain in -regions of beams in service
Pages 368-379
P.G. Debernardi, M. Guiglia, M. Taliano
11.Probabilistic loss assessment of light-frame wood construction subjected to combined seismic and snow loads
Pages 380-390
Yue-Jun Yin, Yue Li
12.On the treatment of finite element structures in stochastic linear dynamics using a mode-based meta-model
Pages 391-400
L. Pichler, G.I. Schuëller
13.Bar fracture modeling in progressive collapse analysis of reinforced concrete structures
Pages 401-409
Mehrdad Sasani, Andre Werner, Ali Kazemi
14.A Monte Carlo based method for the dynamic “fragility analysis” of tall buildings under turbulent wind loading
Pages 410-420
Marra A. Smith, Luca Caracoglia
15.Sensitivity analysis of steel buildings subjected to column loss
Pages 421-432
Jinkoo Kim, Jun-Hee Park, Tae-Hyung Lee
16.Multiple cardinality constraints and automatic member grouping in the optimal design of steel framed structures
Pages 433-444
Afonso C.C. Lemonge, Helio J.C. Barbosa, Alvaro L.G.A. Coutinho, Carlos C.H. Borges
17.Wind action evaluation on tension roofs of hyperbolic paraboloid shape
Pages 445-461
Fabio Rizzo, Piero D’Asdia, Massimiliano Lazzari, Lorenzo Procino
18.Probabilistic representation of duration of load effects in timber structures
Pages 462-467
Jochen Kohler, Staffan Svensson
19.Structural dynamic optimal design based on dynamic reliability
Pages 468-476
Juan Ma, Wei Gao, Peter Wriggers, Jianjun Chen, Shahab Sahraee
20.Wind and structural modelling for an accurate fatigue life assessment of tubular structures
Pages 477-491
Junbo Jia
21.Proper Orthogonal Decomposition and Radial Basis Functions in material characterization based on instrumented indentation
Pages 492-501
Vladimir Buljak, Giulio Maier
22.Parametric and pushover analyses on integral abutment bridge
Pages 502-515
Tobia Zordan, Bruno Briseghella, Cheng Lan
23.Experimental investigation on shear behaviour of riveted connections in steel structures
Pages 516-531
M. D’Aniello, F. Portioli, L. Fiorino, R. Landolfo
24.Neoprene–concrete friction relationships for seismic assessment of existing precast buildings
Pages 532-538
Gennaro Magliulo, Vittorio Capozzi, Giovanni Fabbrocino, Gaetano Manfredi
25.Analysis of the strain transfer in a new FBG sensor for Structural Health Monitoring
Pages 539-548
Benjamin Torres, Ignacio Payá-Zaforteza, Pedro A. Calderón, Jose M. Adam
26.Bearing failure in stainless steel bolted connections
Pages 549-562
E.L. Salih, L. Gardner, D.A. Nethercot
27.Experimental behaviour of composite slabs during the heating and cooling fire stages
Pages 563-571
S. Guo, C.G. Bailey
28.Assessment of various kinematic models for instability analysis of sandwich beams
Pages 572-579
Heng Hu, Salim Belouettar, Michel Potier-Ferry, Ahmed Makradi, Yao Koutsawa
29.An experimental study on steel-caged RC columns subjected to axial force and bending moment
Pages 580-590
Julio Garzón-Roca, Joaquín Ruiz-Pinilla, Jose M. Adam, Pedro A. Calderón
30.Vehicle axle load identification on bridge deck with irregular road surface profile
Pages 591-601
S.Q. Wu, S.S. Law
31.Design equation for predicting fire resistance of reinforced concrete beams
Pages 602-614
V.K.R. Kodur, M.B. Dwaikat
32.Unusual structural effects in a variable-depth box girder bridge: The Pujayo viaduct
Pages 615-620
Óscar Ramón Ramos, Frank Schanack, Guillermo Ortega, Marcos J. Pantaleón
33.Evaluation of drift demands in existing steel frames under as-recorded far-field and near-fault mainshock–aftershock seismic sequences
Pages 621-634
Jorge Ruiz-García, Juan C. Negrete-Manriquez
34.Strengthening of a steel railway bridge and its impact on the dynamic response to passing trains
Pages 635-646
Joakim Wallin, John Leander, Raid Karoumi
35.Behaviour of composite beam–column flush end-plate connections subjected to low-probability, high-consequence loading
Pages 647-662
O. Mirza, B. Uy
36.Strengthening multiple span simply-supported girder bridges using post-tensioned negative moment connection technique
Pages 663-673
Wen-Wei Wang, Jian-Guo Dai, Cheng-Kui Huang, Qi-Hang Bao
37.Database-assisted design methodology to predict wind-induced structural behavior of a light-framed wood building
Pages 674-684
Akwasi F. Mensah, Peter L. Datin, David O. Prevatt, Rakesh Gupta, John W. van de Lindt
38.Proportioning of reinforced concrete column sections
Pages 685-688
Mark Aschheim, Luisa María Gil-Martín, Enrique Hernández-Montes
39.Calendar
Pages I-II
  • kowheng, chairatpk, jcbv, Dell_Brett, tluc, marion33, blaze, pm81, ting tsai huang, mybest, malc, pssst, zrilek, sodapas, ircba, Grunf, SCREAM7890, warbeast
 foxxx2010
Lithuania
User ID: 31627
Threads: 19
Given Likes: 753
#14
10-20-2011, 11:39 AM
Volume 33, Issue 1, Pages 1-272 (January 2011)
Size: 30.6 MB | Format: PDF
1.Editorial Board
Page IFC
2.Design and shape optimization of a new type of hollow concrete masonry block using the finite element method
Pages 1-9
J.J. del Coz Díaz, P.J. García Nieto, F.P. Álvarez Rabanal, A. Lozano Martínez-Luengas
3.Measurement of the dynamic displacements and of the modal frequencies of a short-span pedestrian bridge using GPS and an accelerometer
Pages 10-17
Fanis Moschas, Stathis Stiros
4.Strain gradient effects on flexural strength design of normal-strength concrete columns
Pages 18-31
J.C.M. Ho, J. Peng
5.Disproportionate collapse performance of partially restrained steel frames with bolted T-stub connections
Pages 32-43
Guoqing Xu, Bruce R. Ellingwood
6.Comparison of fatigue performances of gapped and partially overlapped CHS -joints
Pages 44-52
C.K. Lee, S.P. Chiew, S.T. Lie, T. Sopha
7.Tests on reinforced concrete beams strengthened in shear using near surface mounted CFRP and steel bars
Pages 53-62
Khaldoun N. Rahal, Hatem A. Rumaih
8.Tests and models for engineered wood product connections using small steel tube fasteners
Pages 63-68
Bona Murty, Andi Asiz, Ian Smith
9.Performance of toe-nail connections under realistic wind loading
Pages 69-76
Murray J. Morrison, Gregory A. Kopp
10.Evaluation of buckling-restrained braced frame seismic performance considering reserve strength
Pages 77-89
Christopher Ariyaratana, Larry A. Fahnestock
11.A method to assess peak storm wind speeds using detailed damage surveys
Pages 90-98
Gregory A. Kopp, Murray J. Morrison, Bahareh Kordi, Craig Miller
12.Influence of variations in concrete material properties on the serviceability of reinforced and prestressed concrete flexural members
Pages 99-106
T. Vincent, T. Ozbakkaloglu, R. Seracino, W. Kaggwa
13.The composite effect of steel fibres and stirrups on the shear behaviour of beams using self-consolidating concrete
Pages 107-117
Yining Ding, Zhiguo You, Said Jalali
14.Accurate time-dependent analysis of concrete bridges considering concrete creep, concrete shrinkage and cable relaxation
Pages 118-126
Francis T.K. Au, X.T. Si
15.The complex variable element-free Galerkin (CVEFG) method for elasto-plasticity problems
Pages 127-135
Miaojuan Peng, Dongming Li, Yumin Cheng
16.Aggregate interlock in lightweight concrete continuous deep beams
Pages 136-145
Keun-Hyeok Yang, Ashraf F. Ashour
17.Variation of structural vibration characteristics versus non-uniform temperature distribution
Pages 146-153
Yong Xia, You-Lin Xu, Ze-Long Wei, Hong-Ping Zhu, Xiao-Qing Zhou
18.Probabilistic model for failure initiation of reinforced concrete interior beam–column connections subjected to seismic loading
Pages 154-162
Nilanjan Mitra, Sudeshna Mitra, Laura N. Lowes
19.A fuzzy inference-based approach for building damage risk assessment on mining terrains
Pages 163-170
A. Malinowska
20.Defect distribution and reliability assessment of wind turbine blades
Pages 171-180
Henrik Stensgaard Toft, Kim Branner, Peter Berring, John Dalsgaard Sørensen
21.Advanced dynamic finite element analysis of a skew steel railway bridge
Pages 181-190
G. Kaliyaperumal, B. Imam, T. Righiniotis
22.Analytical evaluation of essential facilities fragility curves by using a stochastic approach
Pages 191-201
Giuseppe Carlo Marano, Rita Greco, Emiliano Morrone
23.Fatigue assessment of highway steel bridges in presence of seismic loading
Pages 202-209
A. Pipinato, C. Pellegrino, C. Modena
24.Modelling and analysis of time-dependent behaviour of historical masonry under high stress levels
Pages 210-217
E. Verstrynge, L. Schueremans, D. Van Gemert, M.A.N. Hendriks
25.Probabilistic seismic demand analysis of a slender RC shear wall considering soil–structure interaction effects
Pages 218-229
Yuchuan Tang, Jian Zhang
26.Seismic behavior of code designed steel plate shear walls
Pages 230-244
Jeffrey W. Berman
27.Performance of axially restrained concrete encased steel composite columns at elevated temperatures
Pages 245-254
Ben Young, Ehab Ellobody
28.Coupling of smoothed particle hydrodynamics and finite element method for impact dynamics simulation
Pages 255-264
Zhichun Zhang, Hongfu Qiang, Weiran Gao
Short communication
29.Refined Mindlin–Reissner theory of forced vibrations of shear deformable plates
Pages 265-272
Milan Batista
30.Calendar
Pages I-II
  • kowheng, marion33, Dell_Brett, chairatpk, blaze, jcbv, tluc, pm81, ting tsai huang, mybest, malc, pssst, zrilek, sodapas, ircba, Grunf, SCREAM7890, warbeast
 foxxx2010
Lithuania
User ID: 31627
Threads: 19
Given Likes: 753
#15
10-22-2011, 06:58 AM
Volume 32, Issue 12, Pages 3827-4000 (December 2010)
Size: 18.0 MB | Format: PDF
1.Editorial Board
Page IFC
2.Characteristic Dynamic Increment for extreme traffic loading events on short and medium span highway bridges
Pages 3827-3835
Eugene J. OBrien, Daniel Cantero, Bernard Enright, Arturo González
3.In-structure shock of underground structures: A theoretical approach
Pages 3836-3844
Guowei Ma, Hongyuan Zhou, Yong Lu, Karen Chong
4.Nonlinear inelastic dynamic analysis of suspension bridges
Pages 3845-3856
Seung-Eock Kim, Huu-Tai Thai
5.Experimental study of hybrid FRP reinforced concrete beams
Pages 3857-3865
Denvid Lau, Hoat Joen Pam
6.Structural safety and serviceability evaluations of prestressed concrete hybrid bridge girders with corrugated or steel truss web members
Pages 3866-3878
Kwang-Hoe Jung, Jong-Won Yi, Jang-Ho Jay Kim
7.A fuzzy random approach of stochastic seismic response spectrum analysis
Pages 3879-3887
Giuseppe Carlo Marano, Emiliano Morrone, Sara Sgobba, Subrata Chakraborty
8.Wind-induced fatigue collapse of real slender structures
Pages 3888-3898
Maria Pia Repetto, Giovanni Solari
9.Nonlinear finite element analysis of a 50 years old reinforced concrete trough bridge
Pages 3899-3910
Benjamin Richard, Sébastien Epaillard, Christian Cremona, Lennart Elfgren, Lucas Adelaide
10.Modelling and experimental assessment of punching shear in flat slabs with shearheads
Pages 3911-3924
M.A. Eder, R.L. Vollum, A.Y. Elghazouli, T. Abdel-Fattah
11.Out-of-plane shaking table tests on unreinforced masonry panels in RC frames
Pages 3925-3935
Yi-Hsuan Tu, Tsung-Hua Chuang, Pai-Mei Liu, Yuan-Sen Yang
12.A frame element model for the analysis of reinforced concrete structures under shear and bending
Pages 3936-3954
Steffen Mohr, Jesús M. Bairán, Antonio R. Marí
13.Geometric issues and ultimate load capacity of masonry arch bridges from the northwest Iberian Peninsula
Pages 3955-3965
Daniel V. Oliveira, Paulo B. Lourenço, Cláudia Lemos
14.Time-dependent behaviour of timber lightweight concrete composite floors
Pages 3966-3973
L.F. Jorge, J. Schänzlin, S.M.R. Lopes, H. Cruz, U. Kuhlmann
15.3-D nonlinear dynamic progressive collapse analysis of multi-storey steel composite frame buildings — Parametric study
Pages 3974-3980
Feng Fu
16.On the prediction of the interaction effect caused by continuous ballast on filler beam railway bridges by experimentally supported numerical studies
Pages 3981-3988
T. Rauert, H. Bigelow, B. Hoffmeister, M. Feldmann
17.Second order effects in slender concrete columns-reformulation of the Eurocode 2 method based on nominal curvature
Pages 3989-3993
Helena Barros, Vitor D. Silva, Carla Ferreira
18.The new frequency response functions for structural health monitoring
Pages 3994-3999
L. Gelman
19.Calendar
Pages I-II
Volume 32, Issue 11, Pages 3433-3826 (November 2010)
Size: 38.7 MB | Format: PDF
1.Editorial Board
Page IFC
2.Coupled and uncoupled nonlinear elastic finite element models for monotonically loaded sheathing-to-framing joints in timber based shear walls
Pages 3433-3442
Johan Vessby, Erik Serrano, Anders Olsson
3.Assessment of flexural lateral load distribution methodologies for stringer bridges
Pages 3443-3451
Devin K. Harris
4.Optimal adjustment of EC-2 shear formulation for concrete elements without web reinforcement using Genetic Programming
Pages 3452-3466
Juan L. Pérez, Antoni Cladera, Juan R. Rabuñal, Fernando Martínez Abella
5.Optimization of retrofitting distortion-induced fatigue cracking of steel bridges using monitored data under uncertainty
Pages 3467-3477
Ming Liu, Dan M. Frangopol, Kihyon Kwon
6.Structural behavior of ultra high performance concrete beams subjected to bending
Pages 3478-3487
In Hwan Yang, Changbin Joh, Byung-Suk Kim
7.A genetic algorithm for beam–slab layout design of rectilinear floors
Pages 3488-3500
Anan Nimtawat, Pruettha Nanakorn
8.Effect of the manufacturing process on the behaviour of press-braked thin-walled steel columns
Pages 3501-3515
W.M. Quach, J.G. Teng,, K.F. Chung
9.Interaction of combined loads on the lateral stability of thin-walled composite beams
Pages 3516-3527
Sebastián P. Machado
10.Experimental study of externally prestressed segmental beam under torsion
Pages 3528-3538
M.A. Algorafi, A.A.A. Ali, I. Othman, M.S. Jaafar, M.P. Anwar
11.Simple design procedure of a friction damper for reducing seismic responses of a single-story structure
Pages 3539-3547
Kyung-Won Min, Ji-Young Seong, Jinkoo Kim
12.Seismic strengthening of non-ductile reinforced concrete frames using aluminum shear links as energy-dissipation devices
Pages 3548-3557
Dipti R. Sahoo, Durgesh C. Rai
13.Numerical simulation of idealised three-dimensional downburst wind fields
Pages 3558-3570
M.S. Mason, D.F. Fletcher, G.S. Wood
14.Non-stationary random vibration analysis for train–bridge systems subjected to horizontal earthquakes
Pages 3571-3582
Z.C. Zhang, J.H. Lin, Y.H. Zhang, Y. Zhao, W.P. Howson, F.W. Williams
15.System identification of concrete gravity dams using artificial neural networks based on a hybrid finite element–boundary element approach
Pages 3583-3591
I. Karimi, N. Khaji, M.T. Ahmadi, M. Mirzayee
16.Establishing concrete cracking strength interval using possibility theory with an application to predict the possible reinforced concrete deflection interval
Pages 3592-3600
Jung J. Kim, Mahmoud M. Reda Taha, Timothy J. Ross
17.Modeling of the seismic behavior of shear-critical reinforced concrete columns
Pages 3601-3615
T. Ravi Mullapudi, Ashraf Ayoub
18.Control strategy for mitigating the response of structures subjected to earthquake actions
Pages 3616-3628
Nikos G. Pnevmatikos, Charis J. Gantes
19.Shore overloads during shoring removal
Pages 3629-3638
M. Azkune, I. Puente, A. Santilli
20.Framework for analytical quantification of disaster resilience
Pages 3639-3649
Gian Paolo Cimellaro, Andrei M. Reinhorn, Michel Bruneau
21.Design optimization and dynamic analysis of a tensegrity-based footbridge
Pages 3650-3659
Nizar Bel Hadj Ali, Landolf Rhode-Barbarigos, Alberto A. Pascual Albi, Ian F.C. Smith
22.Modelling the bond between concrete and reinforcing steel in a fire
Pages 3660-3669
Zhaohui Huang
23.Assessment of long-term behavior of tuned mass dampers by system identification
Pages 3670-3682
Benedikt Weber, Glauco Feltrin
24.Fault detection based on Kernel Principal Component Analysis
Pages 3683-3691
Viet Ha Nguyen, Jean-Claude Golinval
25.Simplified analysis of the dynamic soil–structure interaction of a portal frame railway bridge
Pages 3692-3698
Mahir Ülker-Kaustell, Raid Karoumi, Costin Pacoste
26.Mixed mode fracture toughness: An empirical formulation for determination in asymmetric DCB specimens
Pages 3699-3703
V. Mollón, J. Bonhomme, J. Viña, A. Argüelles
27.Structural reliability of eccentrically-loaded sections in RC columns made of recycled aggregate concrete
Pages 3704-3712
Marco Breccolotti, Annibale Luigi Materazzi
28.Postbuckling analysis of beams of arbitrary cross section using BEM
Pages 3713-3724
J.A. Dourakopoulos, E.J. Sapountzakis
29.The projection gradient algorithm with error control for structural reliability
Pages 3725-3733
Frédéric Duprat, Alain Sellier, Xuan Son Nguyen, Gérard Pons
30.Computerised interaction diagrams and moment capacity contours for composite steel–concrete cross-sections
Pages 3734-3757
C.G. Chiorean
31.Uncertainty and sensitivity analysis of creep models for uncorrelated and correlated input parameters
Pages 3758-3767
Holger Keitel, Andrea Dimmig-Osburg
32.Time-dependent reliability analysis of existing RC structures in a marine environment using hazard associated with airborne chlorides
Pages 3768-3779
Mitsuyoshi Akiyama, Dan M. Frangopol, Ikumasa Yoshida
33.Buckling of laminated glass elements in out-of-plane bending
Pages 3780-3788
C. Amadio, C. Bedon
34.Flexural strength and behavior of steel and FRP-reinforced concrete-filled FRP tube beams
Pages 3789-3800
Hamdy M. Mohamed, Radhouane Masmoudi
35.An unconventional earthquake resistant abutment with transversely directed R/C walls
Pages 3801-3816
Sevasti D. Tegou, Stergios A. Mitoulis, Ioannis A. Tegos
36.Optimizing the design of rockfall embankments with a discrete element method
Pages 3817-3826
J.-P. Plassiard, F.-V. Donzé
37.Calendar
Pages I-II
[-] The following 19 users Like foxxx2010's post:19 users Like foxxx2010's post
  • kowheng, blaze, lisine, jcbv, Dell_Brett, marion33, tluc, pm81, ting tsai huang, mybest, malc, chairatpk, pssst, zrilek, sodapas, ircba, Grunf, SCREAM7890, levanduy
 foxxx2010
Lithuania
User ID: 31627
Threads: 19
Given Likes: 753
#16
10-27-2011, 01:01 PM
Volume 32, Issue 7, Pages 1791-1956 (July 2010)
Size: 40.5 MB | Format: PDF
Learning from Structural Failures
1.Editorial Board
Page IFC
2.Editorial
Page 1791
Jose M. Adam, Francisco J. Pallares
3.A study of the collapse of a WWII communications antenna using numerical simulations based on design of experiments by FEM
Pages 1792-1800
J.J. del Coz Díaz, P.J. García Nieto, A. Lozano Martínez-Luengas, J.L. Suárez Sierra
4.Evaluation study on structural fault of a Renaissance Italian palace
Pages 1801-1813
Michele Betti, Gianni Bartoli, Maurizio Orlando
5.Case study: Damage of an RC building after a landslide—inspection, analysis and retrofitting
Pages 1814-1820
P. Tiago, E. Júlio
6.Deep trench, landslide and effects on the foundations of a residential building: A case study
Pages 1821-1829
A. Brencich
7.Forensic diagnosis of a shield tunnel failure
Pages 1830-1837
Wei F. Lee, Kenji Ishihara
8.Failure of concrete T-beam and box-girder highway bridges subjected to cyclic loading from traffic
Pages 1838-1845
Kent K. Sasaki, Terry Paret, Juan C. Araiza, Peder Hals
9.Durability problem of RC structures in Tuzla industrial zone — Two case studies
Pages 1846-1860
Radomir Folić, Damir Zenunović
10.Transverse vibrations in existing railway bridges under resonant conditions: Single-track versus double-track configurations
Pages 1861-1875
M.D. Martínez-Rodrigo, J. Lavado, P. Museros
11.Case study: Analytical investigation on the failure of a two-story RC building damaged during the 2007 Pisco-Chincha earthquake
Pages 1876-1887
Oh-Sung Kwon, Eungsoo Kim
12.An evaluation of effective design parameters on earthquake performance of RC buildings using neural networks
Pages 1888-1898
M. Hakan Arslan
13.Structural performance of the historic and modern buildings of the University of L’Aquila during the seismic events of April 2009
Pages 1899-1924
A.M. Ceci, A. Contento, L. Fanale, D. Galeota, V. Gattulli, M. Lepidi, F. Potenza
14.Collapse modelling analysis of a precast soft storey building in Australia
Pages 1925-1936
Ari Wibowo, John L. Wilson, Nelson T.K. Lam, Emad F. Gad
15.Earthquake-induced poundings of a seismically isolated building with adjacent structures
Pages 1937-1951
Panayiotis C. Polycarpou, Petros Komodromos
16.Failure literacy in structural engineering
Pages 1952-1954
Norbert Delatte
Book Review
17.Book review
Page 1955
Jose M. Adam
18.Calendar
Pages I-II
Volume 32, Issue 6, Pages 1495-1790 (June 2010)
Size: 33.8 MB | Format: PDF
1.Editorial Board
Page IFC
2.Integral abutment bridge response under thermal loading
Pages 1495-1508
WooSeok Kim, Jeffrey A. Laman
3.Strength and ductility of reinforced concrete slabs containing welded wire fabric and subjected to support settlement
Pages 1509-1521
R. Ian Gilbert, Zafer I. Sakka
4.Shear resistance of cold-formed steel framed shear walls with 0.686 mm, 0.762 mm, and 0.838 mm steel sheet sheathing
Pages 1522-1529
Cheng Yu
5.Code approaches to vortex shedding and own model
Pages 1530-1536
Andrzej Flaga, Tomasz Lipecki
6.Force transfer mechanism and shear strength of reinforced concrete beams
Pages 1537-1546
W.W. Kuo, T.J. Cheng, S.J. Hwang
7.Fragility analysis of steel moment frames with various seismic connections subjected to sudden loss of a column
Pages 1547-1555
Junhee Park, Jinkoo Kim
8.Limit and shakedown analysis of 3D steel frames via approximate ellipsoidal yield surfaces
Pages 1556-1567
M.-A.A. Skordeli, C.D. Bisbos
9.Criteria for uniqueness and extrema of moments in continuous end spans with differential settlement
Pages 1568-1576
W.M. Sebastian
10.The impact of the earthquake incident angle on the seismic loss estimation
Pages 1577-1589
Nikos D. Lagaros
11.Experimental investigation of the temperature effect on the structural response of SG-laminated reinforced glass beams
Pages 1590-1599
Christian Louter, Jan Belis, Freek Bos, Dieter Callewaert, Frederik Veer
12.Behaviour of combined channel/angle connections to tubular columns under monotonic and cyclic loading
Pages 1600-1616
C. Málaga-Chuquitaype, A.Y. Elghazouli
13.Non-linear analysis of two-layer timber beams considering interlayer slip and uplift
Pages 1617-1630
A. Kroflič, I. Planinc, M. Saje, G. Turk, B. Čas
14.Exact solution of the bending vibration problem of FGM beams with variation of material properties
Pages 1631-1640
J. Murín, M. Aminbaghai, V. Kutiš
15.Interaction diagrams for ambient and heated concrete sections
Pages 1641-1649
Angus Law, Martin Gillie
16.Shape and size optimisation of concrete shells
Pages 1650-1658
Antonio Tomás, Pascual Martí
17.Fatigue analysis of overhead sign support structures
Pages 1659-1670
Jennifer Kacin, Piervincenzo Rizzo, Mahdi Tajari
18.Analytical and numerical analysis of multilayered beams with interlayer slip
Pages 1671-1680
João Batista M. Sousa Jr, Amilton R. da Silva
19.Second-order analysis and design of imperfect composite beam–columns
Pages 1681-1690
M. Fong, Y.P. Liu, S.L. Chan
20.A new method for progressive collapse analysis of RC frames under blast loading
Pages 1691-1703
Yanchao Shi, Zhong-Xian Li, Hong Hao
21.Acoustic emission monitoring of bridges: Review and case studies
Pages 1704-1714
Archana Nair, C.S. Cai
22.Damage detection in instrumented structures without baseline modal parameters
Pages 1715-1722
Ramsés Rodríguez, J. Alberto Escobar, Roberto Gómez
23.Neural networks model and adaptive neuro-fuzzy inference system for predicting the moment capacity of ferrocement members
Pages 1723-1734
Mohammed A. Mashrei, Nabeel Abdulrazzaq, Turki Y. Abdalla, M.S. Rahman
24.Earthquake response of ten-story story-drift-controlled reinforced concrete frames with hysteretic dampers
Pages 1735-1746
Juan Andrés Oviedo A., Mitsumasa Midorikawa, Tetsuhiro Asari
25.Constructing input to neural networks for modeling temperature-caused modal variability: Mean temperatures, effective temperatures, and principal components of temperatures
Pages 1747-1759
H.F. Zhou, Y.Q. Ni, J.M. Ko
26.An algorithm for grouping members in a structure
Pages 1760-1768
Richard Walls, Alex Elvin
27.Effects of bolt–plate arrangements on steel plate strengthened reinforced concrete beams
Pages 1769-1778
R.K.L. Su, W.H. Siu, S.T. Smith
28.Truss vs solid modeling of tendons in prestressed concrete structures: Consequences on mechanical capacity of a Representative Structural Volume
Pages 1779-1790
Ludovic Jason, Shahrokh Ghavamian, Alexis Courtois
29.Calendar
Pages I-II
Volume 32, Issue 5, Pages 1199-1494 (May 2010)
Size: 38.5 MB | Format: PDF
1.Editorial Board
Page IFC
2.An efficient mathematical programming method for the elastoplastic analysis of frames
Pages 1199-1214
Konstantinos V. Spiliopoulos, Theodoros N. Patsios
3.Full-scale field trials to assess dry-stone retaining wall stability
Pages 1215-1222
Anne-Sophie Colas, Jean-Claude Morel, Denis Garnier
4.Nonlinear dynamic simulations of progressive collapse for a multistory building
Pages 1223-1235
Leslaw Kwasniewski
5.Numerical and experimental investigation of the behavior of high strength concrete columns in fire
Pages 1236-1243
Faris Ali, Ali Nadjai, S. Choi
6.Micromodelling of eccentrically loaded brickwork: Study of masonry wallettes
Pages 1244-1251
Jose M. Adam, Antonio Brencich, Tim G. Hughes, Tony Jefferson
7.Integrated wind load analysis and stiffness optimization of tall buildings with 3D modes
Pages 1252-1261
C.M. Chan, M.F. Huang, K.C.S. Kwok
8.Strength, cracking and deflection performance of large-scale self-consolidating concrete beams subjected to shear failure
Pages 1262-1271
A.A.A. Hassan, K.M.A. Hossain, M. Lachemi
9.A modified approach of energy balance concept based multimode pushover analysis to estimate seismic demands for buildings
Pages 1272-1283
Yi Jiang, Gang Li, Dixiong Yang
10.Reliability of steel frames designed in accordance with the National Building Code of Canada seismic provisions and its implication in codified design
Pages 1284-1291
H.P. Hong, P. Hong, W. Wang
11.Performance assessment of precast concrete segmental bridge columns with a shear resistant connecting structure
Pages 1292-1303
T.-H. Kim, H.-M. Lee, Y.-J. Kim, H.M. Shin
12.Collapse mechanisms at the foundation interface of geometrically similar concrete gravity dams
Pages 1304-1311
Gabriella Bolzon
13.A methodology for deriving analytical fragility curves for masonry buildings based on stochastic nonlinear analyses
Pages 1312-1323
M. Rota, A. Penna, G. Magenes
14.Experimental validation of free vibrations from nonsymmetrical thin walled beams
Pages 1324-1332
Daniel Ambrosini
15.Influence of variations in geometric parameters and an alternative design for improved fatigue life of a mining dragline joint
Pages 1333-1340
Suraj Joshi, John W.H. Price, Daya P. Dayawansa
16.Ultimate strength analysis of normal and high strength concrete wall panels with varying opening configurations
Pages 1341-1355
Hong Guan, Carlia Cooper, Dong-Jun Lee
17.Stress and acceleration analysis of coupled vehicle and long-span bridge systems using the mode superposition method
Pages 1356-1368
Y.L. Xu, Q. Li, D.J. Wu, Z.W. Chen
18.Determination of impact factor for steel railway bridges considering simultaneous effects of vehicle speed and axle distance to span length ratio
Pages 1369-1376
Sajad Ahmad Hamidi, Farhad Danshjoo
19.Dynamic analysis of concrete arch dams by ideal-coupled modal approach
Pages 1377-1383
Ahmad Aftabi Sani, Vahid Lotfi
20.A geometric nonlinear model for composite beams with partial interaction
Pages 1384-1396
Gianluca Ranzi, Andrea Dall’Asta, Laura Ragni, Alessandro Zona
21.Web crippling of aluminium tubes with perforated webs
Pages 1397-1410
Feng Zhou, Ben Young
22.Numerical modelling of cracks in masonry walls due to thermal movements in an overlying slab
Pages 1411-1422
K.G.S. Dilrukshi, W.P.S. Dias, R.K.N.D. Rajapakse
23.A simplified approach for evaluating plastic axial and moment capacity curves for beam–columns with non-uniform thermal gradients
Pages 1423-1436
Mahmud Dwaikat, Venkatesh Kodur
24.Inverse identification of creep of concrete from in situ load–displacement monitoring
Pages 1437-1445
Sungmoon Jung, Jamshid Ghaboussi
25.Reliability-based optimal design of linear dynamical systems under stochastic stationary excitation and model uncertainty
Pages 1446-1458
Alexandros A. Taflanidis
26.Generic modelling of composite steel–concrete slabs subjected to shrinkage, creep and thermal strains including partial interaction
Pages 1459-1465
Mark A. Bradford
27.Numerical models for the seismic assessment of an old masonry tower
Pages 1466-1478
Fernando Peña, Paulo B. Lourenço, Nuno Mendes, Daniel V. Oliveira
28.Component mode synthesis combining robust enriched Ritz approach for viscoelastically damped structures
Pages 1479-1488
A.M.G. de Lima, A.R. da Silva, D.A. Rade, N. Bouhaddi
29.Optimization of RC structure performance in marine environment
Pages 1489-1494
Rui Miguel Ferreira
30.Calendar
Pages I-II
Volume 32, Issue 4, Pages 911-1198 (April 2010)
Size: 60.3 MB | Format: PDF
1.Editorial Board
Page IFC
2.The vulnerability of residential window glass to lightweight windborne debris
Pages 911-921
Forrest J. Masters, Kurtis R. Gurley, Nirav Shah, George Fernandez
3.Strength prediction of squat structural walls via calibration of a shear–flexure interaction model
Pages 922-932
4.Leonardo M. Massone4.Modelling the response of cyclically loaded bridge columns embedded in warm and seasonally frozen soils
Pages 933-943
L.M. Wotherspoon, S. Sritharan, M.J. Pender
5.Nonlinear behavior of code-designed reinforced concrete concentric braced frames under lateral loading
Pages 944-963
Eber Alberto Godínez-Domínguez, Arturo Tena-Colunga
6.Seismic strengthening of rectangular reinforced concrete columns using fiber reinforced polymers
Pages 964-973
Okan Ozcan, Baris Binici, Guney Ozcebe
7.Application of lumped dissipation model in nonlinear analysis of reinforced concrete structures
Pages 974-981
Gerson Moacyr Sisniegas Alva, Ana Lúcia Homce de Cresce El Debs
8.Distortional buckling of overhanging monorails
Pages 982-987
N.S. Trahair
9.Nonlinear reinforced concrete frame element with torsion
Pages 988-1002
Hamid R. Valipour, Stephen J. Foster
10.Experimental and analytical studies on the stability of structural steel tube and coupler scaffolds without X-bracing
Pages 1003-1015
Hongbo Liu, Qiuhong Zhao, Xiaodun Wang, Ting Zhou, Dong Wang, Jie Liu, Zhihua Chen
11.Moving force identification based on stochastic finite element model
Pages 1016-1027
S.Q. Wu, S.S. Law
12.Built-up hybrid composite box girders fabricated and tested in flexure
Pages 1028-1037
Amir Fam, Hart Honickman
13.Time-dependent analyses of segmentally constructed balanced cantilever bridges
Pages 1038-1045
Richard Malm, Håkan Sundquist
14.A unified formulation for hollow and solid concrete-filled steel tube columns under axial compression
Pages 1046-1053
Min Yu, Xiaoxiong Zha, Jianqiao Ye, Chunyan She
15.Fully integrated design and analysis of Tensioned Fabric Structures: Finite elements and case studies
Pages 1054-1068
J.B. Pargana, D. Lloyd-Smith, B.A. Izzuddin
16.Studies for controlling human-induced vibration of the Pedro e Inês footbridge, Portugal. Part 1: Assessment of dynamic behaviour
Pages 1069-1081
Elsa Caetano, Álvaro Cunha, Filipe Magalhães, Carlos Moutinho
17.Studies for controlling human-induced vibration of the Pedro e Inês footbridge, Portugal. Part 2: Implementation of tuned mass dampers
Pages 1082-1091
Elsa Caetano, Álvaro Cunha, Carlos Moutinho, Filipe Magalhães
18.Plastic optimization of 3D steel frames under fixed or repeated loading: Reduction formulation
Pages 1092-1099
Hoang Van Long, Nguyen Dang Hung
19.An unconventional restraining system for limiting the seismic movements of isolated bridges
Pages 1100-1112
20.A brace-type seismic damper based on yielding the walls of hollow structural sections
Pages 1113-1122
Amadeo Benavent-Climent
21.An innovative passive control technique for industrial precast frames
Pages 1123-1132
Paolo Martinelli, Maria Gabriella Mulas
22.Resistance of the component ‘lateral faces of RHS’ at high temperature
Pages 1133-1139
Carlos López-Colina, Miguel A. Serrano-López, Fernando L. Gayarre, Francisco J. Suárez
23.The effect of fatigue on the arrangement of hangers in tied arch bridges
Pages 1140-1147
Carlo Pellegrino, Giovanni Cupani, Claudio Modena
24.Thermo-mechanical analysis of the fire performance of dowelled timber connection
Pages 1148-1157
P. Racher, K. Laplanche, D. Dhima, A. Bouchaïr
25.Designing tensegrity modules for pedestrian bridges
Pages 1158-1167
Landolf Rhode-Barbarigos, Nizar Bel Hadj Ali, René Motro, Ian F.C. Smith
26.An innovative isolation device for aseismic design
Pages 1168-1183
M. Ismail, J. Rodellar, F. Ikhouane
27.Design model for the verification of the separating function of light timber frame assemblies
Pages 1184-1195
Andrea Frangi, Vanessa Schleifer, Mario Fontana
Book Review
28.Book review
Page 1196
Tibor Tarnai
Corrigendum
29.Corrigendum to: “Evaluation of peak resultant response for wind-excited tall buildings” [Eng Struct 31 (2009) 858–868]
Page 1197
Xinzhong Chen, Guoqing Huang
30.Calendar
Pages I-II
Volume 32, Issue 3, Pages 617-910 (March 2010)
Size: 70.5 MB | Format: PDF
1.Editorial Board
Page IFC
2.Shear strength of heavily reinforced concrete members with circular cross section
Pages 617-626
Uffe G. Jensen, Linh C. Hoang, Henrik B. Joergensen, Lars S. Fabrin
3.Optimization of bridge maintenance strategies based on multiple limit states and monitoring
Pages 627-640
André D. Orcesi, Dan M. Frangopol, Sunyong Kim
4.The influence of different safety formats proposed by Eurocode 2 on the deformability and design of slender structural elements
Pages 641-647
João Santos, João Vinagre
5.Behavior of concrete prisms confined with FRP composites under axial cyclic compression
Pages 648-655
R. Abbasnia, H. Ziaadiny
6.Experimental investigation of actively confined concrete using shape memory alloys
Pages 656-664
Moochul Shin, Bassem Andrawes
7.Finite element modeling of confined concrete-I: Drucker–Prager type plasticity model
Pages 665-679
T. Yu, J.G. Teng, Y.L. Wong, S.L. Dong
8.Finite element modeling of confined concrete-II: Plastic-damage model
Pages 680-691
9.CFDST stub columns subjected to large deformation axial loading
Pages 692-703
Xiao-Ling Zhao, Le-Wei Tong, Xing-Yi Wang
10.Imperfection analysis of austenitic stainless steel plate girders failing by shear
Pages 704-713
M.F. Hassanein
11.Effectiveness of adding confinement for ductility improvement of high-strength concrete columns
Pages 714-725
J.C.M. Ho, J.Y.K. Lam, A.K.H. Kwan
12.Performance enhancement of R/C building columns and beam–column joints through shotcrete jacketing
Pages 726-740
Alexander-Dimitrios G. Tsonos
13.Warping shear stresses in nonlinear nonuniform torsional vibrations of bars by BEM
Pages 741-752
E.J. Sapountzakis, V.J. Tsipiras
14.Coupled experimental and numerical investigation of structural glass panels with small slenderness subjected to locally introduced axial compression
Pages 753-761
Danijel Mocibob, Jan Belis
15.Application of symbolic data analysis for structural modification assessment
Pages 762-775
Alexandre Cury, Christian Crémona, Edwin Diday
16.Experimental tests and numerical modeling of reinforced masonry arches
Pages 776-792
Ilaria Cancelliere, Maura Imbimbo, Elio Sacco
17.Exact reliability calculation with quadratic failure indices in random vibration
Pages 793-799
Enrique de la Fuente, Miguel A. Sanz, José L. Hernando
18.Fatigue assessment of welded trapezoidal joints of a very fast ferry subjected to combined load
Pages 800-807
Y. Garbatov, S. Rudan, C. Guedes Soares
19.Dynamic performance of existing high-speed railway bridges under resonant conditions retrofitted with fluid viscous dampers
Pages 808-828
20.Long-term deflections in cracked reinforced concrete flexural members
Pages 829-842
Antonio R. Marí, Jesús M. Bairán, Noemi Duarte
21.A numerical model based on nonconvex–nonsmooth optimization for the simulation of bending tests on composite slabs with profiled steel sheeting
Pages 843-853
K.A. Tzaros, E.S. Mistakidis, P.C. Perdikaris
22.Monitoring and enhanced fatigue evaluation of a steel railway bridge
Pages 854-863
John Leander, Andreas Andersson, Raid Karoumi
23.An improved ant colony optimization for the design of planar steel frames
Pages 864-873
A. Kaveh, S. Talatahari
24.Structural assessment of corroded self-consolidating concrete beams
Pages 874-885
25.Impulsive loading events and similarity scaling
Pages 886-896
I.M. Snyman
26.On shear bond strength of FRP-concrete structures
Pages 897-905
Yefei Wu, Zhiqiang Zhou, Qingda Yang, Weiqiu Chen
Short Communication
27.An elementary derivation of basic equations of the Reissner and Mindlin plate theories
Pages 906-909
Milan Batista
28.Calendar
Pages I-II
[-] The following 12 users Like foxxx2010's post:12 users Like foxxx2010's post
  • tluc, marion33, Dell_Brett, kowheng, mybest, malc, pssst, zrilek, sodapas, ircba, Grunf, warbeast
 foxxx2010
Lithuania
User ID: 31627
Threads: 19
Given Likes: 753
#17
10-31-2011, 12:20 PM
Volume 32, Issue 2, Pages 337-616 (February 2010)
Size: 72.5 MB | Format: PDF
1.Editorial Board
Page IFC
2.Response of high frequency floors: A literature review
Pages 337-352
C.J. Middleton, J.M.W. Brownjohn
3.Experimental analysis of the “Saint Andrea” Masonry Bell Tower in Venice. A new method for the determination of “Tower Global Young’s Modulus E”
Pages 353-360
G. Russo, O. Bergamo, L. Damiani, D. Lugato
4.Effects of support settlement on continuous deep beams and STM modeling
Pages 361-372
Ning Zhang, Kang-Hai Tan
5.Performance of reinforced concrete T beams strengthened in shear with NSM CFRP laminates
Pages 373-384
S.J.E. Dias, J.A.O. Barros
6.The seismic performance of a semi-rigid composite joint with a double-sided extended end-plate. Part I: Experimental research
Pages 385-396
Javier Gracia, Eduardo Bayo, Fabio Ferrario, Oreste Bursi, Aurelio Braconi, Walter Salvatore
7.Seismic performance of semi-rigid composite joints with a double-sided extended end-plate. Part II: Seismic simulations
Pages 397-408
8.Application of nonlinear fluid–structure interaction methods to seismic analysis of anchored and unanchored tanks
Pages 409-423
Z. Ozdemir, M. Souli, Y.M. Fahjan
9.Cyclic testing and numerical modelling of carbon steel and stainless steel tubular bracing members
Pages 424-441
K.H. Nip, L. Gardner, A.Y. Elghazouli
10.Experimental correlations between destructive and non-destructive tests on ancient timber elements
Pages 442-448
C. Calderoni, G. De Matteis, C. Giubileo, F.M. Mazzolani
11.Mechanical and informational modeling of steel beam-to-column connections
Pages 449-458
JunHee Kim, Jamshid Ghaboussi, Amr S. Elnashai
12.Finite element prediction of interfacial stresses in structural members bonded with a thin plate
Pages 459-471
L. Zhang, J.G. Teng
13.An analytical model for crack spacing of thick reinforced concrete plates
Pages 472-482
N. Dawood, H. Marzouk
14.Performance of equilibrium-based system identification algorithms with incomplete state data
Pages 483-497
W. Elmer VII, J.Z. Stafsudd, E. Taciroglu
15.Design and analysis of braced frames with shape memory alloy and energy-absorbing hybrid devices
Pages 498-507
Chuang-Sheng Walter Yang, Reginald DesRoches, Roberto T. Leon
16.Experimental behavior and design of a new kinematic isolator
Pages 508-522
Jaime Besa, Juan C. de la Llera, Rosita Jünemann
17.Non-proportional damage identification in steel frames
Pages 523-533
Ma Ge, Eric M. Lui, Ajit C. Khanse
18.Ultimate strength of a steel–concrete composite bridge deck slab with profiled sheeting
Pages 534-546
Hyeong-Yeol Kim, Youn-Ju Jeong
19.Out-of-plane strength of brick masonry retrofitted with horizontal NSM CFRP strips
Pages 547-555
C.R. Willis, R. Seracino, M.C. Griffith
20.Response of post-tensioned concrete beams with unbonded tendons including serviceability and ultimate state
Pages 556-569
N.A. Vu, A. Castel, R. François
21.The influence of a train’s critical speed and rail discontinuity on the dynamic behavior of single-span steel bridges
Pages 570-579
George T. Michaltsos, Ioannis G. Raftoyiannis
22.Fire design of steel-to-timber dowelled connections
Pages 580-589
Carsten Erchinger, Andrea Frangi, Mario Fontana
23.Depth to bedrock randomness effect on design spectra in the city of Algiers (Algeria)
Pages 590-599
M. Badaoui, M.K. Berrah, A. Mebarki
24.Moisture-induced stresses in spruce cross-laminates
Pages 600-606
Thomas Gereke, Peter Niemz
25.Modelling masonry arches shape using terrestrial laser scanning data and nonparametric methods
Pages 607-615
J. Armesto, Javier Roca-Pardiñas, H. Lorenzo, P. Arias
26.Calendar
Pages I-II
Volume 32, Issue 1, Pages 1-336 (January 2010)
Size: 73.4 MB | Format: PDF
1.Editorial Board
Page IFC
2.Variance decomposition and global sensitivity for structural systems
Pages 1-10
Sanjay R. Arwade, Mohammadreza Moradi, Arghavan Louhghalam
3.Probabilistic estimation of residual drift demands for seismic assessment of multi-story framed buildings
Pages 11-20
Jorge Ruiz-García, Eduardo Miranda
4.Development of dynamic impact factor for performance evaluation of existing multi-girder concrete bridges
Pages 21-31
Lu Deng, C.S. Cai
5.Effect of cross-sectional aspect ratio on the strength of CFRP-confined rectangular concrete columns
Pages 32-45
Yu-Fei Wu, You-Yi Wei
6.Seismic performance of circular RC columns subjected to axial force, bending, and torsion with low and moderate shear
Pages 46-59
Suriya Prakash, Abdeldjelil Belarbi, Young-Min You
7.Behavior of concrete-filled steel tubular planar intersecting connections under axial compression, Part 1: Experimental study
Pages 60-68
Chao Huang, Xiao-lei Han, Jing Ji, Jia-min Tang
8.Simplified monotonic moment–curvature relation considering fixed-end rotation and axial force effect
Pages 69-79
Hyo-Gyoung Kwak, Sun-Pil Kim
9.Vector Form Intrinsic Finite Element analysis of nonlinear behavior of steel structures exposed to fire
Pages 80-92
K.H. Lien, Y.J. Chiou, R.Z. Wang, P.A. Hsiao
10.Effects of the combination of axial and shear loading on the behaviour of headed stud steel anchors
Pages 93-105
O. Mirza, B. Uy
11.Structural reliability analysis of reinforced grouted concrete block masonry walls in compression
Pages 106-114
Ximei Zhai, Mark G. Stewart
12.Hybrid health monitoring of prestressed concrete girder bridges by sequential vibration-impedance approaches
Pages 115-128
Jeong-Tae Kim, Jae-Hyung Park, Dong-Soo Hong, Woo-Sun Park
13.Effect of soil–bridge interaction on the magnitude of internal forces in integral abutment bridge components due to live load effects
Pages 129-145
Murat Dicleli, Semih Erhan
14.Damage identification on arched masonry structures using ambient and random impact vibrations
Pages 146-162
L.F. Ramos, G. De Roeck, P.B. Lourenço, A. Campos-Costa
15.Acceleration feedback control of human-induced floor vibrations
Pages 163-173
Iván M. Díaz, Paul Reynolds
16.A story shear-based adaptive pushover procedure for estimating seismic demands of buildings
Pages 174-183
Kazem Shakeri, Mohsen A. Shayanfar, Toshimi Kabeyasawa
17.The significance of continuity in a multi-panel composite floor
Pages 184-194
Tianxin Zheng, Tianjian Ji, Brian R. Ellis
18.Lateral pressure over formwork on large dimension concrete blocks
Pages 195-206
I. Puente, A. Santilli, A. Lopez
19.Towards the development of an in situ non-destructive method to control the quality of concrete-to-concrete interfaces
Pages 207-217
P. Santos, E. Júlio, J. Santos
20.Post-cracking shear modulus of reinforced concrete membrane elements
Pages 218-225
Khaldoun N. Rahal
21.An improved design formula for a biaxially loaded slender RC column
Pages 226-237
Hyo-Gyoung Kwak, Ji-Hyun Kwak
22.Evaluation of the performance of a sliding-type base isolation system with a NiTi shape memory alloy device considering temperature effects
Pages 238-249
Osman E. Ozbulut, Stefan Hurlebaus
23.In-plane thermoelastic behaviour and buckling of pin-ended and fixed circular arches
Pages 250-260
Yong-Lin Pi, Mark Andrew Bradford
24.Critical correlation of bi-directional horizontal ground motions
Pages 261-272
K. Fujita, I. Takewaki
25.Strength reduction factors for near-fault forward-directivity ground motions
Pages 273-285
Joanna L. Gillie, Adrian Rodriguez-Marek, Cole McDaniel
26.Updating the reliability of a concrete bridge structure based on condition assessment with uncertainties
Pages 286-296
S.S. Law, J. Li
27.Hysteretic energy and damping capacity of flexural elements constructed with different concrete strengths
Pages 297-305
Abdelsamie Elmenshawi, Tom Brown
28.A simplified strategy for force finding analysis of suspendomes
Pages 306-318
Qing-shuai Cao, Zhi-hong Zhang
29.Finite element analysis of curved steel girders with tubular flanges
Pages 319-327
Jun Dong, Richard Sause
30.Derivation of equivalent gust effect factors for wind loading on low-rise buildings through Database-Assisted-Design approach
Pages 328-336
Dong-Woo Seo, Luca Caracoglia
31.Calendar
Pages I-II
[-] The following 13 users Like foxxx2010's post:13 users Like foxxx2010's post
  • monter, mybest, Dell_Brett, kowheng, malc, chairatpk, pssst, marion33, zrilek, sodapas, ircba, Grunf, warbeast
 foxxx2010
Lithuania
User ID: 31627
Threads: 19
Given Likes: 753
#18
01-30-2012, 09:05 AM
Mirror link for posts #1 and #2:
[-] The following 8 users Like foxxx2010's post:8 users Like foxxx2010's post
  • Dell_Brett, mybest, chairatpk, marion33, zrilek, sodapas, Grunf, warbeast
 foxxx2010
Lithuania
User ID: 31627
Threads: 19
Given Likes: 753
#19
01-30-2012, 11:16 AM (This post was last modified: 01-30-2012, 11:51 AM by foxxx2010.)
Volume 31, Issue 12, Pages 2803-3120 (December 2009)
Size: 70.1 MB | Format: PDF | Quality: Original preprint
1.Editorial Board
Page IFC
2.Dynamic testing of a soil–steel composite railway bridge
Pages 2803-2811
Esra Bayoğlu Flener, Raid Karoumi
3. Elastic buckling of cold-formed steel columns and beams with holes
Pages 2812-2824
Cristopher D. Moen, B.W. Schafer
4. Finite difference analysis of simply supported RC slabs for blast loadings
Pages 2825-2832
J. Jones, C. Wu, D.J. Oehlers, A.S. Whittaker, W. Sun, S. Marks, R. Coppola
5. Monitoring the effects of impact damages on modal parameters in carbon fiber entangled sandwich beams
Pages 2833-2841
Amir Shahdin, Laurent Mezeix, Christophe Bouvet, Joseph Morlier, Yves Gourinat
6. Guided wave damage characterisation in beams utilising probabilistic optimisation
Pages 2842-2850
C.T. Ng, M. Veidt, H.F. Lam
7. Effectiveness of cable networks of various configurations in suppressing stay-cable vibration
Pages 2851-2864
Luca Caracoglia, Delong Zuo
8. Seismic analysis of reinforced concrete frame-wall systems considering ductility effects in accordance to Eurocode
Pages 2865-2872
Juraj Králik, Juraj Králik Jr
9. Lateral–distortional buckling of monorails
Pages 2873-2879
N.S. Trahair
10. Hybrid-member stiffness matrix accounting for geometrical nonlinearity and member inelasticity in semi-rigid frameworks
Pages 2880-2895
Yuxin Liu
11. Length of critical region for confinement steel in limited ductility high-strength reinforced concrete columns
Pages 2896-2908
H.J. Pam, J.C.M. Ho
12. Probabilistic collapse analysis of degrading Multi Degree of Freedom structures under earthquake excitation
Pages 2909-2921
Mouchir Chenouda, Ashraf Ayoub
13. Optimization of elastic columns using axial grading concept
Pages 2922-2929
Karam Y. Maalawi
14. Residual stresses in autofrettaged vessel made of functionally graded material
Pages 2930-2935
B. Haghpanah Jahromi, G.H. Farrahi, M. Maleki, H. Nayeb-Hashemi, A. Vaziri
15. Full-scale validation of vortex suppression techniques for mitigation of roof uplift
Pages 2936-2946
Collette Blessing, Arindam Gan Chowdhury, Jason Lin, Peng Huang
16. Post-earthquake loss assessment based on structural component damage inspection for residential RC buildings
Pages 2947-2953
Q. Xue, C.W. Wu, C.C. Chen, W.Y Chou
17. Longterm sensor-based monitoring of an LRFD designed steel girder bridge
Pages 2954-2965
Samir N. Shoukry, Mourad Y. Riad, Gergis W. William
18. A simplified analysis method for characterizing unbonded post-tensioned precast wall systems
Pages 2966-2975
Sriram Aaleti, Sri Sritharan
19. Influence of inelastic seismic response modeling on regional loss estimation
Pages 2976-2987
Joshua S. Steelman, Jerome F. Hajjar
20. Long-term deflection of cracked composite beams with nonlinear partial shear interaction — A study using neural networks
Pages 2988-2997
Mohammed A. Sakr, Sherief S.S. Sakla
21. Characterization of shaking intensity distribution and seismic assessment of RC buildings for the Kashmir (Pakistan) earthquake of October 2005
Pages 2998-3015
Sung Jig Kim, Amr S. Elnashai
22. A computer method for nonlinear inelastic analysis of 3D semi-rigid steel frameworks
Pages 3016-3033
C.G. Chiorean
23. A macro-element to simulate dynamic Soil-Structure Interaction
Pages 3034-3046
Stéphane Grange, Panagiotis Kotronis, Jacky Mazars
24. Testing and numerical modelling of lean duplex stainless steel hollow section columns
Pages 3047-3058
M. Theofanous, L. Gardner
25. Retrofitting of R/C shear walls by means of high performance jackets
Pages 3059-3064
Alessandra Marini, Alberto Meda
26. A numerical method to design reinforced concrete sections subjected to axial forces and biaxial bending based on ultimate strain limits
Pages 3065-3071
L. Pallarés, Pedro F. Miguel, Miguel A. Fernández-Prada
27. Modeling of insulated CFRP-strengthened reinforced concrete T-beam exposed to fire
Pages 3072-3079
R.A. Hawileh, M. Naser, W. Zaidan, H.A. Rasheed
28. Evaluation of equivalent linear methods for estimating target displacements of existing structures
Pages 3080-3089
Yu-Yuan Lin, Eduardo Miranda
29. Dynamic analysis of three-dimensional bridge–high-speed train interactions using a wheel–rail contact model
Pages 3090-3106
Van Nguyen Dinh, Ki Du Kim, Pennung Warnitchai
30. Development of a baseline for structural health monitoring for a curved post-tensioned concrete box–girder bridge
Pages 3107-3115
Chengyin Liu, John T. DeWolf, Jeong-Ho Kim
31. Response of GLARE© panels to blast loading
Pages 3116-3120
G.S. Langdon, Y. Chi, G.N. Nurick, P. Haupt
32. Calendar
Pages I-II
[Image: comments.png]
RARed PDFs
Volume 31, Issue 11, Pages 2507-2802 (November 2009)
Size: 63.7 MB | Format: PDF | Quality: Original preprint
1. Editorial Board
Page IFC
2. Uncertain linear systems in dynamics: Retrospective and recent developments by stochastic approaches
Pages 2507-2517
G.I. Schuëller, H.J. Pradlwarter
3. Steel corrosion on RC structures under sustained service loads — A critical review
Pages 2518-2525
Goitseone Malumbela, Mark Alexander, Pilate Moyo
4. The structural behaviour of a pre-stressed column–beam connection as an alternative to the traditional timber joint system
Pages 2526-2533
T. Shiratori, A.J.M. Leijten, K. Komatsu
5. Tsunami bore forces on a compliant residential building model
Pages 2534-2539
John W. van de Lindt, Rakesh Gupta, Rachel A. Garcia, Jebediah Wilson
6. Experimental monotonic and cyclic behaviour of blind-bolted angle connections
Pages 2540-2553
A.Y. Elghazouli, C. Málaga-Chuquitaype, J.M. Castro, A.H. Orton
7. The response of a 344 m long bridge to non-uniform earthquake ground motions
Pages 2554-2567
J. Wang, A.J. Carr, N. Cooke, P.J. Moss
8. Ultimate strength of stiffened plates with a square opening under axial and out-of-plane loads
Pages 2568-2579
M. Suneel Kumar, P. Alagusundaramoorthy, R. Sundaravadivelu
9. Bond behaviour of FRP-to-clay brick masonry joints
Pages 2580-2587
C.R. Willis, Q. Yang, R. Seracino, M.C. Griffith
10. Mechanical performance of eccentrically loaded pre-stressing concrete filled circular steel tube columns by means of expansive cement
Pages 2588-2597
Xu Chang, Cheng-Kui Huang, Ya-Juan Chen
11. Fluid pressure on unanchored rigid flat-bottom cylindrical tanks due to uplift motion and its approximation
Pages 2598-2606
Tomoyo Taniguchi, Yoshinori Ando, Teruhiro Nakashima
12. Statistical and analytical models for roof components in existing light-framed wood structures
Pages 2607-2616
Bagyalakshmi Shanmugam, Bryant G. Nielson, David O. Prevatt
13. Dynamic behavior of elevated tanks with soil–structure interaction
Pages 2617-2629
Sekhar Chandra Dutta, Somnath Dutta, Rana Roy
14. Finite element study of steel beams reinforced while under load
Pages 2630-2642
Yi Liu, Liam Gannon
15.Analysis of actuator delay compensation methods for real-time testing
Pages 2643-2655
Cheng Chen, James M. Ricles
16.Shell form-finding: Physical and numerical design tools
Pages 2656-2666
P. Bellés, N. Ortega, M. Rosales, O. Andrés
17. Shell form-finding: Physical and numerical design tools
Pages 2656-2666
18. Historic bridge modelling using laser scanning, ground penetrating radar and finite element methods in the context of structural dynamics
Pages 2667-2676
Izabela Lubowiecka, Julia Armesto, Pedro Arias, Henrique Lorenzo
19. Analysis of randomly vibrating structures under hybrid uncertainty
Pages 2677-2686
Giuseppe Carlo Marano, Emiliano Morrone, Giuseppe Quaranta
20. Upper bound limit analysis of meso-mechanical spandrel models for the pushover analysis of 2D masonry frames
Pages 2696-2710
G. Milani, K. Beyer, A. Dazio
21. Optimization of cold-formed steel pallet racking cross-sections for flexural–torsional buckling with constraints on the geometry
Pages 2711-2722
M.M. Pastor, M. Casafont, E. Chillarón, A. Lusa, F. Roure, M.R. Somalo
22. Base isolation of slide-rocking non-symmetric rigid blocks under impulsive and seismic excitations
Pages 2723-2734
A. Di Egidio, A. Contento
23. Multidomain finite and discrete elements method for impact analysis of a concrete structure
Pages 2735-2743
Jessica Rousseau, Emmanuel Frangin, Philippe Marin, Laurent Daudeville
24. Inelastic displacement ratios for SDOF structures subjected to repeated earthquakes
Pages 2744-2755
George D. Hatzigeorgiou, Dimitri E. Beskos
25. Static strain energy and dynamic amplification factor on multiple degree of freedom systems
Pages 2756-2765
C.M. Mozos, A.C. Aparicio
26. Multi-stage production cost optimization of semi-rigid steel frames using genetic algorithms
Pages 2766-2778
Nizar Bel Hadj Ali, Mohamed Sellami, Anne-Françoise Cutting-Decelle, Jean-Claude Mangin
27. Displacement based seismic verification method for thin-walled circular steel columns subjected to bi-directional cyclic loading
Pages 2779-2786
N.G. Kulkarni, A. Kasai, H. Tsuboi
28. Generic nonlinear modelling of restrained steel beams at elevated temperatures
Pages 2787-2796
A. Heidarpour, M.A. Bradford
29. Design of viscous dampers targeting multiple cable modes
Pages 2797-2800
F. Weber, G. Feltrin, M. Maślanka, W. Fobo, H. Distl
30. Discussion on “Predicting the shear strength of reinforced concrete beams using artificial neural networks” by M.Y. Mansour, M. Dicleli, J.Y. Lee, J. Zhang [Eng Struct 26 (2004) 781–799]
Page 2801
A.H. Gandomi, A.H. Alavi
31. Calendar
Pages I-II
RARed PDFs
  • kowheng, Dell_Brett, tluc, mybest, malc, pssst, marion33, zrilek, sodapas, ircba, Grunf, warbeast
 foxxx2010
Lithuania
User ID: 31627
Threads: 19
Likes: 2,013 in 182 posts
Given Likes: 753
#20
01-31-2012, 07:09 AM
Volume 31, Issue 10, Pages 2215-2506 (October 2009)
Size: 56.1 MB | Format: PDF | Quality: Original preprint
1. Editorial Board
Page IFC
2.Simplified model for damage in squat RC shear walls
Pages 2215-2223
Edward D. Thomson, María E. Perdomo, Ricardo Picón, María E. Marante, Julio Flórez-López
3. Real-time wireless vibration monitoring for operational modal analysis of an integral abutment highway bridge
Pages 2224-2235
Matthew J. Whelan, Michael V. Gangone, Kerop D. Janoyan, Ratneshwar Jha
4. Simulation of offshore wind turbine response for long-term extreme load prediction
Pages 2236-2246
Puneet Agarwal, Lance Manuel
5. Experiments on the residual load-bearing capacity of prestressed confined concrete columns
Pages 2247-2256
Lars Janke, Christoph Czaderski, Jürgen Ruth, Masoud Motavalli
6. Crack detection in beam-like structures
Pages 2257-2264
Marta B. Rosales, Carlos P. Filipich, Fernando S. Buezas
7. Field measurement and wind tunnel simulation of hurricane wind loads on a single family dwelling
Pages 2265-2274
Z. Liu, D.O. Prevatt, L.D. Aponte-Bermudez, K.R. Gurley, T.A. Reinhold, R.E. Akins
8.Development of building vulnerability functions in subsidence regions from empirical methods
Pages 2275-2286
Ali Saeidi, Olivier Deck, Tierry Verdel
9. Assessment of masonry arch railway bridges using non-destructive in-situ testing methods
Pages 2287-2298
Zoltán Orbán, Marc Gutermann
10.Reliability-based evaluation of design code provisions for circular concrete-filled steel columns
Pages 2299-2308
André T. Beck, Walter L.A. de Oliveira, Silvana De Nardim, Ana L.H.C. ElDebs
11. Experimental investigation into the interfacial shear strength of AGS-FRP tube confined concrete pile
Pages 2309-2316
Gefu Ji, Zhenyu Ouyang, Guoqiang Li
12. Bridge support elastic reactions under vertical earthquake ground motion
Pages 2317-2326
Frederic Legeron, M. Neaz Sheikh
13. Numerical integration of a class of 3d plastic-damage concrete models and condensation of 3d stress–strain relations for use in beam finite elements
Pages 2327-2336
Afsin Saritas, Filip C. Filippou
14. Experimental and analytical study of carbon fiber-reinforced polymer (FRP)/autoclaved aerated concrete (AAC) sandwich panels
Pages 2337-2344
Mohammed A. Mousa, Nasim Uddin
15. Pounding mitigation and unseating prevention at expansion joints of isolated multi-span bridges
Pages 2345-2356
Shehata E. Abdel Raheem
16. Numerical and experimental analyses of multiple-dowel steel-to-timber joints in tension perpendicular to grain
Pages 2357-2367
B.H. Xu, A. Bouchaïr, M. Taazount, E.J. Vega
17. Macroscopic FE model for tracing the fire response of reinforced concrete structures
Pages 2368-2379
Venkatesh Kodur, Monther Dwaikat, Nikhil Raut
18. Modeling short-term tension stiffening in reinforced concrete prisms using a continuum-based finite element model
Pages 2380-2391
H.Q. Wu, R.I. Gilbert
19. The effects of temperature variations on the long-term behaviour of composite steel–concrete beams
Pages 2392-2406
Francesca Giussani
20. Performance and robust stability trade-off in minimax LQG control of vibrations in flexible structures
Pages 2407-2413
Allahyar Montazeri, Javad Poshtan, Amir Choobdar
21. Closed form solution of the alongwind-induced fatigue damage to structures
Pages 2414-2425
22. Generalized SDOF system for seismic analysis of concrete rectangular liquid storage tanks
Pages 2426-2435
J.Z. Chen, M.R. Kianoush
23. Edge debonding in FRP strengthened beams: Stress versus energy failure criteria
Pages 2436-2447
A. Carpinteri, P. Cornetti, N. Pugno
24. Extracting the bridge frequencies indirectly from a passing vehicle: Parametric study
Pages 2448-2459
Y.B. Yang, K.C. Chang
25. Progressive failure of prestressed concrete sleepers under multiple high-intensity impact loads
Pages 2460-2473
Sakdirat Kaewunruen, Alex M. Remennikov
26. Identification of parameters of vehicles moving on bridges
Pages 2474-2485
L. Deng, C.S. Cai
27. Nonlinear seismic analyses of a high gravity dam with and without the presence of reinforcement
Pages 2486-2494
Yuchuan Long, Chuhan Zhang, Yanjie Xu
28. Experimental study on partially deteriorated strength concrete columns confined with CFRP
Pages 2495-2505
Hua Wei, Zhimin Wu, Xia Guo, Fumin Yi
29. Calender
Pages I-II
RARed PDFs
  • jcbv, Dell_Brett, tluc, kowheng, 3fan, malc, chairatpk, pssst, marion33, zrilek, Grunf, warbeast, semirigid
Pages (6): « Previous 1 2 3 4 5 6 Next »
  The AISC Engineering Journal Archive [1964-2001] agelos100 2 7,809 03-02-2020, 01:50 AM
  AISC Engineering Journal Fourth Quarter 2014 Volume 51, No. 4 malc 1 6,615 10-15-2014, 07:26 AM
Last Post: Saze808
  Journal of Engineering Mechanics - Papers lisine 3 7,726 06-28-2013, 09:24 AM
  Journal of Materials in Civil Engineering - Papers lisine 3 8,404 06-28-2013, 09:24 AM
  Journal of Structural Engineering - Papers lisine 10 19,085 06-07-2013, 06:41 AM
  Journal Engineering Structures - Papers lisine 6 12,189 04-10-2013, 07:01 AM
  Journal Earthquake Engineering & Structural Dynamics - Papers lisine 5 10,777 02-12-2013, 10:56 AM
