CompareDWG tools for AutoCAD
(30 days trial and renew)
![[Image: 20600655182286238695.jpg]](http://pic.civilea.com/images/20600655182286238695.jpg)
CompareDWG finds the differences between two revisions of an AutoCAD drawing and displays them graphically.
•Find the differences between two revisions of an AutoCAD drawing.
•In Detailed Mode, compare the complete AutoCAD internal representation of a drawing, not just the graphical appearance.
•In Basic Mode, compare the drawing graphics only (no matching AutoCAD handles are needed).
•Display the differences in AutoCAD, using contrasting colors for Added entities, Deleted entities etc.
•Choose your own markup colors, a legend can be created automatically.
•Save the differences to separate files. This creates for example a DWG file which contains all new entities.
•Create reports on the types and quantities of the entities found in the drawings.
•Compare table entries (layers, linetypes etc) and present the differences in a report.
•Compare drawing variables.
•Include CompareDWG in your own LISP applications.
•Install CompareDWG on a network, users do not need to enter the license code.
•Also works for Architectural Desktop and Autodesk Map, but not for Mechanical Desktop or Inventor.
The new versions are compatible to Autocad 2007 up to 2012 and the old works up to 2006.
If you receive a SDI error in CompareDWG opening a New Compare Job change the Autocad variable SDI to 0.
You can use it to renew BetterWMF posted here
but maybe it will erase your license if you use the license posted in this thread.
![[Image: 08939938766662506750.gif]](http://pic.civilea.com/images/08939938766662506750.gif)
![[Image: 64045084793978574094.gif]](http://pic.civilea.com/images/64045084793978574094.gif)
![[Image: 26357696531889031845.gif]](http://pic.civilea.com/images/26357696531889031845.gif)
![[Image: 23025943860888337266.gif]](http://pic.civilea.com/images/23025943860888337266.gif)
