Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Archive [REQUEST] Empirical Model-Building and Response Surfaces
[Request] Empirical Model-Building and Response Surfaces
Threads: 307
10-05-2011, 02:30 PM (This post was last modified: 10-05-2011, 02:31 PM by Grunf.)
REQUEST Empirical Model-Building and Response Surfaces
Author: George E. P. Box (Author), Norman R. Draper (Author) | Size: ?? MB | Format: PDF | Publisher: Wiley; No Edition Stated edition | Year: January 1987 | pages: 688 | ISBN: 0471810339, 9780471810339
[Image: 02256310192382659416.jpg]
An innovative discussion of building empirical models and the fitting of surfaces to data. Introduces the general philosophy of response surface methodology, and details least squares for response surface work, factorial designs at two levels, fitting second-order models, adequacy of estimation and the use of transformation, occurrence and elucidation of ridge systems, and more. Some results are presented for the first time. Includes real-life exercises, nearly all with solutions.
  â€¢
  [REQUEST] Modification of Empirical Strong Ground Motion Attenuation tunc 1 2,261 10-27-2014, 08:54 AM
  [REQUEST] Seismic Response of Base-Isolated Benchmark Building with Variable Sliding Isolators ali akbar 1 1,860 02-11-2014, 03:44 AM
Last Post: Mohammad6299
  [REQUEST] Empirical model of the nonlinear vibration of cracked reinforced concrete beams netsonicyxf 0 1,571 12-05-2012, 09:18 AM
Last Post: netsonicyxf
  [REQUEST] Empirical study of behavior of clay shale slopes gibran 0 1,565 01-04-2012, 05:12 PM
Last Post: gibran
  [REQUEST] ROSE Notes: Nonlinear Earthquake Response Analysis of RC Building by Prof. Otani Sumatra 0 1,894 08-07-2011, 09:33 AM
Last Post: Sumatra
  [REQUEST] Proceeding : "On the Response Modification Factors for Reinforced Concrete Building" budis 0 1,636 12-19-2010, 06:38 AM
Last Post: budis
  [REQUEST] Model Building in Mathematical Programming belgacem 0 1,568 11-20-2010, 09:37 PM
Last Post: belgacem
