Civil Engineering Association eBooks Journals, Papers and Presentations Journal of Earthquake Engineering
 Sumatra
User ID: 14369
Threads: 72
Likes: 1,925 in 240 posts
Given Likes: 1580
#21
09-25-2011, 02:49 AM
Author: Various | Size: 9.2 MB | Format: PDF | Publisher: Imperial College Press | Year: 2001
Vol. 5, Issue 3 - 4
SOME DESIGN PRINCIPLES RELEVANT TO TORSIONAL PHENOMENA IN DUCTILE BUILDINGS
T. PAULAY
SENSITIVITY OF PARAMETERS FOR PROBABILISTIC SEISMIC HAZARD ANALYSIS USING A LOGIC TREE APPROACH
G. GRÜNTHAL and R. WAHLSTRΓ–M
ANALYTICAL MODELLING OF THE SEISMIC BEHAVIOUR OF PRECAST CONCRETE FRAMES DESIGNED WITH DUCTILE CONNECTIONS
STEFANO PAMPANIN, M. J. NIGEL PRIESTLEY and S. SRITHARAN
REPEATABLE DYNAMIC RELEASE TESTS ON A BASE-ISOLATED BUILDING
A. R. BIXIO, M. DOLCE, D. NIGRO, F. C. PONZO, F. BRAGA and M. NICOLETTI
IS THERE A NEAR-FIELD FOR SMALL-TO-MODERATE MAGNITUDE EARTHQUAKES?
JULIAN J. BOMMER, GEORGE GEORGALLIDES and IAIN J. TROMANS
DUCTILITY REDUCTION FACTOR OF MDOF SHEAR-BUILDING STRUCTURES
H. MOGHADDAM and R. K. MOHAMMADI
ANALYSIS OF PORE PRESSURE GENERATION AND DISSIPATION IN COHESIONLESS MATERIALS DURING SEISMIC LOADING
A. PECKER, J. H. PREVOST and L. DORMIEUX
ON THE CHARACTERISATION OF THE PHASE SPECTRUM FOR STRONG MOTION SYNTHESIS
MANISH SHRIKHANDE and VINAY K. GUPTA
A CAPACITY PREDICTION PROCEDURE FOR CONCRETE-FILLED STEEL COLUMNS
K. A. S. SUSANTHA, HANBIN GE and TSUTOMU USAMI
A PROCEDURE FOR COMBINING VERTICAL AND HORIZONTAL SEISMIC ACTION EFFECTS
C. J. COLLIER and A. S. ELNASHAI
ASSESSMENT OF THE NATURAL FREQUENCY OF THE SEDIMENTARY COVER IN THE COLOGNE AREA (GERMANY) USING NOISE MEASUREMENTS
STEFANO PAROLAI, PETER BORMANN and CLAUS MILKEREIT
CODE PROVISIONS AND ANALYTICAL MODELLING FOR THE IN-PLANE FLEXIBILITY OF FLOOR DIAPHRAGMS IN BUILDING STRUCTURES
I. N. DOUDOUMIS and A. M. ATHANATOPOULOU
[-] The following 10 users Like Sumatra's post:10 users Like Sumatra's post
  β€’ kowheng, subin91, Gkatzogias, blaze, Dell_Brett, zrilek, Grunf, iceman84, jacs127, pssst
 3fan
Romania
User ID: 29614
Threads: 141
Likes: 7,359 in 1,207 posts
Given Likes: 5546
#22
09-25-2011, 05:17 PM (This post was last modified: 09-25-2011, 05:21 PM by 3fan.)
[-] The following 4 users Like 3fan's post:4 users Like 3fan's post
  β€’ Dell_Brett, Sumatra, tluc, zrilek
 Sumatra
User ID: 14369
Threads: 72
Given Likes: 1580
#23
10-04-2011, 01:58 PM
Author: Various | Size: 13.3 MB | Format: PDF | Publisher: Imperial College Press | Year: 2002
Vol. 6 Issue 1
DAMAGE DIRECTIVITY IN BURIED PIPELINES OF KOBE CITY DURING THE 1995 EARTHQUAKE
- SHIRO TAKADA, NEMAT HASSANI & KATSUMI FUKUDA
ON THE OPTIMAL LOCATION OF SENSORS IN MULTI-STOREYED BUILDINGS
- ALOKE K. DATTA, MANISH SHRIKHANDE & DILIP K. PAUL
SIMULATION OF NONLINEAR SOIL-STRUCTURE INTERACTION ON A SHAKING TABLE
- KAZUO KONAGAI & RAQUIB AHSAN
WHEN SHOULD SEISMIC RETROFITTING OF EXISTING STRUCTURES BE IMPLEMENTED IN ORDER TO MINIMIZE EXPECTED LOSSES
- IVO VANZI
SEISMIC HAZARD IN GREECE BASED ON DIFFERENT STRONG GROUND MOTION PARAMETERS
- S. I. KOUTRAKIS, G. P. KARAKAISIS, P. M. HATZIDIMITRIOU, P. K. KOLIOPOULOS & V. N. MARGARIS
MOMENT RESISTING WELDED CONNECTIONS: AN EXTENSIVE REVIEW OF DESIGN PRACTICE AND EXPERIMENTAL RESEARCH IN USA, JAPAN AND EUROPE
- ELENA MELE
Vol. 6 Special Issue 1
LIQUEFACTION AND PILED FOUNDATIONS: SOME ISSUES
- JOHN BERRILL & SUSUMU YASUDA
DETERMINISTIC VS. PROBABILISTIC SEISMIC HAZARD ASSESSMENT: AN EXAGGERATED AND OBSTRUCTIVE DICHOTOMY
- JULIAN J. BOMMER
RELEVANCE OF BEAM-COLUMN JOINT DAMAGE AND COLLAPSE IN RC FRAME ASSESSMENT
- GIAN MICHELE CALVI, GUIDO MAGENES & STEFANO PAMPANIN
SEISMIC ASSESSMENT OF GRAVITY LOAD DESIGNED R.C. FRAMES: CRITICAL ISSUES IN STRUCTURAL MODELLING
- EDOARDO COSENZA, GAETANO MANFREDI & GERARDO MARIO VERDERAME
DO WE REALLY NEED INELASTIC DYNAMIC ANALYSIS?
- AMR S. ELNASHAI
METHODS FOR SEISMIC RISK ANALYSIS: STATE OF THE ART VERSUS ADVANCED STATE OF THE PRACTICE
- P. FRANCHIN, A. LUPOI & P. E. PINTO
STRATEGIES FOR REPAIR AND SEISMIC UPGRADING OF BOLU VIADUCT 1, TURKEY
- M. J. N. PRIESTLEY & G. M. CALVI
SIMULATION ISSUES WITH A REAL-TIME, FULL-SCALE SEISMIC TESTING SYSTEM
- J. S. SHORTREED, F. SEIBLE & G. BENZONI
[-] The following 7 users Like Sumatra's post:7 users Like Sumatra's post
  β€’ kowheng, zrilek, Gkatzogias, Grunf, iceman84, Dell_Brett, pssst
 Sumatra
User ID: 14369
Threads: 72
Given Likes: 1580
#24
10-08-2011, 05:03 AM
Author: Various | Size: 4.3 MB | Format: PDF | Publisher: Imperial College Press | Year: 2002
Vol. 6 Issue 2
A SUMMARY OF RESULTS OF SIMULATED SEISMIC LOAD TESTS ON REINFORCED CONCRETE BEAM-COLUMN JOINTS, BEAMS AND COLUMNS WITH SUBSTANDARD REINFORCING DETAILS
- R. PARK
MODELLING OF NONLINEAR DYNAMIC BEHAVIOUR OF A SHALLOW STRIP FOUNDATION WITH MACRO-ELEMENT
- C. CREMER, A. PECKER and L. DAVENNE
MODELLING OF RC MEMBERS UNDER CYCLIC BIAXIAL FLEXURE AND AXIAL FORCE
- S. N. BOUSIAS, T. B. PANAGIOTAKOS and M. N. FARDIS
CALIBRATION OF FORCE REDUCTION FACTORS OF RC BUILDINGS
- A. M. MWAFY and A. S. ELNASHAI
REPORT ON DAMAGE TO INDUSTRIAL FACILITIES IN THE 1999 KOCAELI EARTHQUAKE, TURKEY
- KOHEI SUZUKI
[-] The following 8 users Like Sumatra's post:8 users Like Sumatra's post
  β€’ kowheng, kostis, Grunf, zrilek, tluc, iceman84, Gkatzogias, Dell_Brett
 Sumatra
User ID: 14369
Threads: 72
Given Likes: 1580
#25
10-08-2011, 09:53 AM
Author: Various | Size: 11.4 MB | Format: PDF | Publisher: Imperial College Press | Year: 2002
Vol. 6 Issue 3
INDEPENDENT HARMONIC CONTROL FOR STRUCTURAL ENGINEERING
- ALESSANDRO BARATTA and OTTAVIA CORBI
RELATION BETWEEN BUILDING DAMAGE AND GROUND CONDITIONS IN THE 1999 QUINDIO EARTHQUAKE IN COLOMBIA
- TAKAO HASHIMOTO and MASAKATSU MIYAJIMA
IDENTIFICATION AND VERIFICATION OF SEISMIC DEMAND FROM DIFFERENT HYSTERETIC MODELS
- SHUNG-TSAIR CHUNG and CHIN-HSIUNG LOH
NON-LINEAR SEISMIC RESPONSE OF EC8 DESIGNED RC BUILDING STRUCTURES
- M. DOLCE and F. C. PONZO
AN ALGORITHM FOR COMPUTING ISODUCTILE RESPONSE SPECTRA
- M. INEL, M. A. ASCHHEIM and D. P. ABRAMS
EFFECT OF SOIL-STRUCTURE INTERACTION ON SEISMICALLY ISOLATED BRIDGES
- C. C. SPYRAKOS and A. G. VLASSIS
Vol. 6 Issue 4
EVALUATION OF ACCIDENTAL ECCENTRICITY IN BUILDINGS DUE TO ROTATIONAL COMPONENT OF EARTHQUAKE
- H. SHAKIB and R. Z. TOHIDI
NUMERICAL ANALYSIS OF EMBANKMENT FOUNDATION LIQUEFACTION COUNTERMEASURES
- AHMED ELGAMAL, ENDER PARRA, ZHAOHUI YANG and KORHAN ADALIER
SEISMIC BEHAVIOUR OF A R/C WALL: NUMERICAL SIMULATION AND EXPERIMENTAL VALIDATION
- RUI FARIA, NELSON VILA POUCA and RAIMUNDO DELGADO
SEISMIC RISK ASSESSMENT OF RC STRUCTURES WITH THE "2000 SAC/FEMA" METHOD
- G. LUPOI, A. LUPOI and P. E. PINTO
SHAKING TABLE DYNAMICS: RESULTS FROM A TEST-ANALYSIS COMPARISON STUDY
- TOMASO L. TROMBETTI and JOEL P. CONTE
SEISMIC DESIGN OF BASE-ISOLATED STRUCTURES USING CONSTANT STRENGTH SPECTRA
- ARTURO TENA-COLUNGA
  β€’ tluc, iceman84, Grunf, kowheng, Gkatzogias, Dell_Brett, zrilek, pssst
 Sumatra
User ID: 14369
Threads: 72
Given Likes: 1580
#26
10-10-2011, 11:20 PM (This post was last modified: 10-10-2011, 11:31 PM by Sumatra.)
New link for
Journal Earthquake Engineering --> Vol. 1 Issue 1
Let's share..
[-] The following 6 users Like Sumatra's post:6 users Like Sumatra's post
  β€’ 3fan, Grunf, Dell_Brett, zrilek, tluc, pssst
 Sumatra
User ID: 14369
Threads: 72
Given Likes: 1580
#27
10-11-2011, 03:18 PM
Author: Various | Size: 14.6 MB | Format: PDF | Publisher: Imperial College Press | Year: 2003
Vol. 7 Special Issue 1
EFFECTS OF SPATIAL VARIABILITY OF SOIL PROPERTIES ON SURFACE GROUND MOTION
- DOMINIC ASSIMAKI, ALAIN PECKER, RADU POPESCU and JEAN PREVOST
SEISMIC FRAGILITY OF REINFORCED CONCRETE STRUCTURES USING A RESPONSE SURFACE APPROACH
- P. FRANCHIN, A. LUPOI, P. E. PINTO and M. IJ. SCHOTANUS
PROBABILISTIC SEISMIC DEMAND MODELS AND FRAGILITY ESTIMATES FOR RC BRIDGES
- PAOLO GARDONI, KHALID M. MOSALAM and ARMEN DER KIUREGHIAN
DEVELOPMENT OF A SIMPLIFIED DEFORMATION-BASED METHOD FOR SEISMIC VULNERABILITY ASSESSMENT
- S. GLAISTER and R. PINHO
EVALUATION OF OUT-OF-PLANE STABILITY OF UNREINFORCED MASONRY WALLS SUBJECTED TO SEISMIC EXCITATION
- MICHAEL C. GRIFFITH, GUIDO MAGENES, GIAMMICHELE MELIS and LUIGINO PICCHI
AN EXPLORATION OF THE NATURE OF THE SCATTER IN GROUND-MOTION PREDICTION EQUATIONS AND THE IMPLICATIONS FOR SEISMIC HAZARD ASSESSMENT
- LUIS F. RESTREPO-VELEZ and JULIAN J. BOMMER
THE LIMITATIONS AND PERFORMANCES OF DIFFERENT DISPLACEMENT BASED DESIGN METHODS
- T. J. SULLIVAN, G. M. CALVI, M. J. N. PRIESTLEY and M. J. KOWALSKY
Vol. 7 Issue 1
PERFORMANCE-BASED DESIGN OF ADDED VISCOUS DAMPERS USING CAPACITY SPECTRUM METHOD
- JINKOO KIM, HYUNHOON CHOI and KYUNG-WON MIN
EXPERIMENTAL EVALUATION OF MEMBER-BY-MEMBER MODELS AND DAMAGE INDICES FOR INFILLED FRAMES
- FELICE COLANGELO
HINTS ABOUT SITE AMPLIFICATION EFFECTS COMPARING MACROSEISMIC HAZARD ESTIMATE WITH MICROTREMOR MEASUREMENTS: THE AGRI VALLEY (ITALY) EXAMPLE
- MARIA ROSARIA GALLIPOLI, MARCO MUCCIARELLI, DARIO ALBARELLO, VINCENZO LAPENNA, MARCELLO SCHIATTARELLA and GIORGIO CALVANO
SLIDING MODE CONTROL OF BUILDING FRAMES UNDER RANDOM GROUND MOTION
- S. SARBJEET and T. K. DATTA
PERFORMANCE-BASED SEISMIC RESPONSE OF FRAME STRUCTURES INCLUDING RESIDUAL DEFORMATIONS PART I: SINGLE-DEGREE OF FREEDOM SYSTEMS
- CONSTANTIN CHRISTOPOULOS, STEFANO PAMPANIN and M. J. NIGEL PRIESTLEY
PERFORMANCE-BASED SEISMIC RESPONSE OF FRAME STRUCTURES INCLUDING RESIDUAL DEFORMATIONS PART II: MULTI-DEGREE OF FREEDOM SYSTEMS
- STEFANO PAMPANIN, CONSTANTIN CHRISTOPOULOS and M. J. NIGEL PRIESTLEY
[-] The following 9 users Like Sumatra's post:9 users Like Sumatra's post
  β€’ blaze, Gkatzogias, Dell_Brett, zrilek, tluc, kowheng, iceman84, monter, pssst
 Sumatra
User ID: 14369
Threads: 72
Given Likes: 1580
#28
12-23-2011, 01:46 PM
Author: Various | Size: 7.4 MB | Format: PDF | Publisher: Imperial College Press | Year: 2003 | pages: 149-346
Vol. 7 Issue 2
Reappraisal of Magnitude of 20th Century Earthquakes in Switzerland
--N. N. Ambraseys
Page: 149-191
New Empirical Response Spectral Attenuation Laws for Moderate European Earthquakes
--Catherine Berge-Thierry, Fabrice Cotton, Oona Scotti, DaphnΓ©-Anne Griot-Pommera and Yoshimitsu Fukushima
Page: 193-222
Seismic Protection of Light Secondary Systems Through Different Base Isolation Systems
--Mauro Dolce and Donatello Cardone
Page: 223-250
Ground Motion Analysis in the Anchorage Basin: 1-D Approach
--Artak Martirosyan, Niren Biswas, Utpal Dutta, David Cole and Apostolos Papageorgiou
Page: 251-274
Influence of Iran's Earthquake Ground Motion Parameters on Design Spectra Using Deterministic and Probabilistic Approaches
--Mohsen Tehranizadeh and Farzaneh Hamedi
Page: 275-295
Strength Reduction Factors for Ductile Structures with Passive Energy Dissipating Devices
--Danny Arroyo-Espinoza and Amador Teran-Gilmore
Page: 297-325
Comments on "Archaeoseismology in Italy: Case Studies and Implications on Long-Term Seismicity"
--Emanuela Guidoboni
Page: 329-335
Response from the Authors of "Archaeoseismology in Italy: Case Studies and Implications on Long-Term Seismicity"
--Fabrizio Galadini and Paolo Galli
Page: 339-346
[-] The following 5 users Like Sumatra's post:5 users Like Sumatra's post
  β€’ Dell_Brett, tluc, kowheng, Gkatzogias, pssst
 Sumatra
User ID: 14369
Threads: 72
Given Likes: 1580
#29
12-24-2011, 01:54 PM
Author: Various | Size: 7.5 MB | Format: PDF | Publisher: Imperial College Press | Year: 2003 | pages: 347-511
Vol. 7 Issue 3
Seismic Hazard Assessment of Metropolitan Tehran, Iran
--G. Ghodrati Amiri, R. Motamed and H. Rabet Es-Haghi
Page: 347-372
Note on the Inclusion of Site Classification Information in Equations to Estimate Strong Ground Motions
--John Douglas
Page: 373-380
Compressive Behaviour of Carbon Fibre Composite Jacketed Concrete with Circular and Non-Circular Cross-Sections
--Alper Ilki and Nahit Kumbasar
Page: 381-406
On the Seismic Vulnerability of Existing Unreinforced Masonry Buildings
--K. Lang and H. Bachmann
Page: 407-426
Simulation of the Fourier Phase Spectrum for the Generation of Synthetic Accelerograms
--V. Montaldo, A. S. Kiremidjian, H. ThrΓ‘insson and G. Zonno
Page: 427-445
Simulation of Ridge-Weathering Effects on the Ground Motion Characteristics
--J. P. Narayan
Page: 447-461
Strut-and-Tie Computer Modelling of Reinforced Concrete Bridge Joint Systems
--Nicholas H. T. To, Jason M. Ingham and Sri Sritharan
Page: 463-493
Friction Damped Steel Moment-Resisting Frames Subjected to Long-Distance Earthquakes: Influence of Weld Fractures
--Assawin Wanitkorkul, Panitan Lukkunaprasit and Andre Filiatrault
Page: 495-510
Erratum
Erratum: "Seismic Design of Base-Isolated Structures Using Constant Strength Spectra"
--Arturo Tena-Colunga
Page: 511-511
[-] The following 4 users Like Sumatra's post:4 users Like Sumatra's post
  β€’ Dell_Brett, kowheng, Gkatzogias, pssst
 Sumatra
User ID: 14369
Threads: 72
Given Likes: 1580
#30
12-25-2011, 02:04 PM
Author: Various | Size: 9.7 MB | Format: PDF | Publisher: Imperial College Press | Year: 2003 | pages: 513-617
Vol. 7 Issue 4
Seismic Response of Linked Marginal Wharf Segments
--G. Benzoni and M. J. N. Priestley
Page: 513-539
Ductile Steel Connections for Seismic Resistant Precast Buildings
--F. J. Crisafulli and J. I. Restrepo
Page: 541-553
Site Amplification Factor in Anchorage, Alaska Based on Long Period Microtremors
--M. Dravinski, G. Ding and N. N. Biswas
Page: 555-571
Attenuation Relation for West Eurasia Determined with Recent Near-Fault Records from California, Japan and Turkey
--Yoshimitsu Fukushima, Catherine Berge-Thierry, Philippe Volant, DaphnΓ©-Anne Griot-Pommera and Fabrice Cotton
Page: 573-598
Quick Survey of the Possible Causes of Damage Enhancement Observed in San Giuliano After the 2002 Molise, Italy Seismic Sequence
--Marco Mucciarelli, Angelo Masi, Marco Vona, Maria Rosaria Gallipoli, Paolo Harabaglia, Riccardo Caputo, Sabatino Piscitelli, Enzo Rizzo, Matteo Picozzi, Dario Albarello and Carmine Lizza
Page: 599-614
Integrated Passive-Active System for Seismic Protection of a Cable-Stayed Bridge
--Kyu-Sik Park, In-Won Lee, Hyung-Jo Jung and Jeong-Gyu Park
Page: 615-633
Fatigue Analysis of Moment Resisting Steel Frames
--Ioannis Vayas, Aris Sophocleous and Florea Dinu
Page: 635-654
Empirical Evaluation of Site Effects by Means of H/V Spectral Ratios at the Locations of Strong Motion Accelerometers in Israel
--Y. Zaslavsky, A. Shapira and J. Leonov
Page: 655-677
Author Index Volume 7 (2003)
Page: 679-683
[-] The following 2 users Like Sumatra's post:2 users Like Sumatra's post
  β€’ kowheng, Gkatzogias
Pages (4): « Previous 1 2 3 4 Next »
  The AISC Engineering Journal Archive [1964-2001] agelos100 2 8,302 03-02-2020, 01:50 AM
  AISC Engineering Journal Fourth Quarter 2014 Volume 51, No. 4 malc 1 6,867 10-15-2014, 07:26 AM
Last Post: Saze808
  Journal of Engineering Mechanics - Papers lisine 3 8,037 06-28-2013, 09:24 AM
  Journal of Materials in Civil Engineering - Papers lisine 3 8,769 06-28-2013, 09:24 AM
  Journal of Structural Engineering - Papers lisine 10 19,781 06-07-2013, 06:41 AM
  Journal Engineering Structures - Papers lisine 6 12,671 04-10-2013, 07:01 AM
  Journal Earthquake Engineering & Structural Dynamics - Papers lisine 5 11,286 02-12-2013, 10:56 AM
