Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Archive [REQUEST] AISC papers
[Request] AISC papers
 Diquan
Costa Rica
User ID: 41
Threads: 23
Likes: 1,205 in 128 posts
Given Likes: 781
#11
08-17-2011, 08:15 PM
Dear unix0123,
Here are your files:
[-] The following 10 users Like Diquan's post:10 users Like Diquan's post
  â€¢ malc, unix0123, Jackass, Dell_Brett, kowheng, sodapas, slowet, bigone, milova, febo927
 devilmaycry
User ID: 27027
Threads: 54
Likes: 232 in 63 posts
Given Likes: 460
#12
08-18-2011, 04:08 AM
Hi, I need these papers, they're in the AISC engineering journal of 2000, thanks in advance for the help:
Panel Zone Yielding in Steel Moment Connections
Author: El-Tawil, Sherif
Design of Welded Steel Moment Connections Using Truss Analogy
Author: Goel, Subhash C.; Lee, Kyoung-Hyeog; Stojadinovic, Bozidar
Errata: Panel Zone Yielding in Steel Moment Connections
  â€¢
Away  mastermind
Egypt
User ID: 11465
Threads: 14
Likes: 392 in 45 posts
Given Likes: 327
#13
08-19-2011, 06:51 PM
hi dears, i need this stuff from AISC
  â€¢
 unix0123
User ID: 14411
Threads: 1
Likes: 99 in 15 posts
Given Likes: 55
#14
08-21-2011, 12:57 AM
Hi, is it possible to have these Journals from AISC?
2009 Q2, Q3 and Q4
Current Steel Structures Research (Q2-2009)
Design of Unstiffened Extended Single-Plate Shear Connections
Experimental Evaluation of the Influence of Connection Typology on the Behavior of Steel Structures Under Fire
Shear Behavior of A325 and A490 High-Strength Bolts in Fire and Post-Fire
Collapse Performance of Low-Ductility Chevron Braced Steel Frames in Moderate Seismic Regions
Current Steel Structures Research (Q3-2009)
Estimating Inelastic Drifts and Link Rotation Demands in EBFs
Experimental Evaluation of Kaiser Bolted Bracket Steel Moment-Resisting Connections
Experimental Investigation of Fillet-Welded Joints Subjected to Out-of-Plane Eccentric Loads
Experimental Study of Bolted Connection Strength at Elevated Temperatures
Composite Action in CFT Components and Connections
Design of Unsymmetric Members
Design and Behavior of Multi-Orientation Fillet Weld Connections
Design Aspects of Single-Angle Members
Response of Concrete-Filled HSS Columns in Real Fires
2011 Q1 and Q2
A Simple Stepped-Column Buckling Model and Computer Algorithm
Analysis and Design of Steel Slit Panel Frames (SSPFs) for Seismic Areas
Closure: Design and Behavior of Multi-Orientation Fillet Weld Connections
Current Steel Structures Research (Q1-2011)
Discussion: Design and Behavior of Multi-Orientation Fillet Weld Connections
Fillet Weld Design for Rectangular HSS Connections
Plastic Moment of Intermediate Horizontal Boundary Elements of Steel Plate Shear Walls
A Yield Line Component Method for Bolted Flange Connections
Current Steel Structures Research, No. 26
On the Need for Stiffeners for and the Effect of Lap Eccentricity on Extended Single-Plate Connections
Performance of the Unified Block Shear Equation for Common Types of Welded Steel Connections
Strength Design Criteria for Steel Beam-Columns with Fire-Induced Thermal Gradients
Technical Note: New Z-BREAKSS: Post-tensioned Rocking Connection Detail Free of Beam Growth
The Development of a New Design Procedure for Conventional Single-Plate Shear Connections
  â€¢
 Diquan
Costa Rica
User ID: 41
Threads: 23
Given Likes: 781
#15
08-22-2011, 08:27 PM
Dear devilmaycry and unix0123,
and
Dear mastermind,
The information that you're requesting is not free for AISC members. But the document on the design for web-tapered members can be found here in CivilEA under the Design Guide 25. That Design Guide is very, very complete and have examples on each area.
[-] The following 15 users Like Diquan's post:15 users Like Diquan's post
  â€¢ malc, Dell_Brett, unix0123, kowheng, Jackass, sodapas, devilmaycry, mastermind, miquan, carolinandra, slowet, bigone, bigone, milova, febo927
 unix0123
User ID: 14411
Threads: 1
Given Likes: 55
#16
08-23-2011, 03:47 AM
Dear Diquan
I forgot to ask for this one:
Current Steel Structures Research (Q4-2009)
  â€¢
 Diquan
Costa Rica
User ID: 41
Threads: 23
Given Likes: 781
#17
08-23-2011, 10:48 AM
Dear unix0123,
Here is your file:
[-] The following 11 users Like Diquan's post:11 users Like Diquan's post
  â€¢ kowheng, Dell_Brett, sodapas, devilmaycry, unix0123, Jackass, slowet, bigone, malc, milova, febo927
 devilmaycry
User ID: 27027
Threads: 54
Given Likes: 460
#18
08-23-2011, 05:37 PM
I need these papers, they're from AISC engineering journal of 2009, thanks in advance:Cutesmile
A Model Specification for Stability Design by Direct Analysis
Current Steel Structures Research (Q1-2009)
Design Aids for Built-Up I-Shaped Beams with Slender Webs
Errata: Design Aid for Triangular Bracket Plates Using AISC Specifications
Technical Note: Optimum Flexural Design of Steel Members Utilizing Moment Gradient and Cb
The Effect of Selected RFI Variables on Steel Fabrication Performance
  â€¢
 Diquan
Costa Rica
User ID: 41
Threads: 23
Given Likes: 781
#19
08-24-2011, 06:13 PM
Dear devilmaycry,
[-] The following 12 users Like Diquan's post:12 users Like Diquan's post
  â€¢ marion33, Dell_Brett, malc, devilmaycry, lisine, Grunf, Jackass, kowheng, sodapas, bigone, milova, febo927
 devilmaycry
User ID: 27027
Threads: 54
Given Likes: 460
#20
10-24-2011, 12:46 PM
Hi, I need this paper, thanks in advance....
Plastic Design by Moment Balancing
Author: Gaylord, Edwin H.
  â€¢
Pages (5): « Previous 1 2 3 4 5 Next »
  [REQUEST] AISC Papers devilmaycry 1 1,868 04-03-2013, 03:27 PM
Last Post: apocalipse
