Civil Engineering Association eBooks Water & Hydraulic Engineering Hydraulic Design of Side Weirs
05-09-2011, 05:39 AM (This post was last modified: 03-12-2012, 09:22 AM by Dell_Brett.)
Author: B C Bromwich | Size: 4.9 MB | Format: PDF | Publisher: Thomas Telford Publishing | Year: 2003 | pages: 152 | ISBN: 072773167X
[Image: 51742213987633671353.jpg]
Side weirs are used widely in order to divert flows from rivers, canals, sewers and reservoirs. However, the hydraulic behaviour of this type of weir is complex and difficult to predict accurately by simple methods. This invaluable book presents a new design procedure that was developed by analysing published data on the performance of side weirs and using the results to calibrate a predictive numerical model. Presented in the form of graphs and simplified equations, this new method enables the flow rate discharged by a side weir to be determined by direct calculation.
[-] The following 20 users Like ir_71's post:20 users Like ir_71's post
  â€¢ kaci, malc, ynopum, Dell_Brett, seriousboy, k1k0k0, sasan7351, nhim4mat2006, kowheng, dede, ISTRAKTURA, emmi, hcardenas, zrilek, henrycv, Jackass, lisine, NBZ1400, spat, Rainbow
 ska51
User ID: 11535
Threads: 382
Likes: 9,406 in 1,251 posts
Given Likes: 4017
08-12-2011, 06:22 PM
Other Links:
"Downstream is Weaker"
[-] The following 6 users Like ska51's post:6 users Like ska51's post
  â€¢ kowheng, Dell_Brett, zrilek, nhim4mat2006, cristi, henrycv
 Flexi
User ID: 300
Likes: 5,440 in 422 posts
Given Likes: 110
02-03-2012, 08:28 AM (This post was last modified: 03-12-2012, 09:26 AM by Dell_Brett.)
other links:
regards
Flexi
[-] The following 2 users Like Flexi's post:2 users Like Flexi's post
  â€¢ Dell_Brett, nhim4mat2006
 Jackass
Bolivia
User ID: 29460
Threads: 24
Likes: 1,138 in 115 posts
Given Likes: 7399
03-12-2012, 04:46 AM
Hi
Here is new link
[-] The following 8 users Like Jackass's post:8 users Like Jackass's post
  â€¢ zrilek, kowheng, 3fan, Dell_Brett, isurya, jacs127, shalaka, nhim4mat2006
 ssobhan
User ID: 1054
Threads: 224
Likes: 8,975 in 1,182 posts
Given Likes: 2465
08-16-2013, 04:21 PM
[/MIRROR] 🔽🔽🔽🔽🔽🔽🔽🔽🔽
[-] The following 9 users Like ssobhan's post:9 users Like ssobhan's post
  â€¢ isurya, blaze, Rainbow, ska51, shalaka, nhim4mat2006, zrilek, Tumbero, floatfree
  Flow Transition Design in Hydraulic Structures Dobblo 2 3,866 05-23-2020, 08:39 PM
Last Post: Veggeta
  Hydraulic Design of Labyrinth Weirs febo927 0 1,597 09-19-2018, 05:56 PM
Last Post: febo927
  Design of Hydraulic Gates abudabeeja 9 6,459 06-22-2018, 06:33 PM
  Bridge Design Manual-Hydraulic Design arshiakh 0 1,694 03-01-2013, 02:45 PM
Last Post: arshiakh
  Hydraulic Design Manual, Aug-2009 niki102 4 4,482 01-17-2013, 11:52 AM
Last Post: shadabg
  Hydraulic Design Handbook- Larry W. Mays junaid 5 5,275 12-10-2012, 12:22 PM
Last Post: shadabg
  HYDRAULIC CANALS: Design, Construction, Regulation and Maintenance Badis 6 4,733 04-26-2012, 01:27 PM
Last Post: david-smith
