Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Archive [REQUEST] AISC papers
[Request] AISC papers
 devilmaycry
User ID: 27027
Threads: 54
Likes: 232 in 63 posts
Given Likes: 460
08-06-2011, 05:52 PM
Hi guys,I really need this paper so for the love of Christ help me,It's in the AISC engineering journal of 2002,thanks in advance!!!
Effect of Compound Buckling on Compression Strength of Built-up Members (Duan, Lian; Reno, Mark; Uang, Chia-Ming)
 yucapareja
User ID: 8
Threads: 40
Likes: 870 in 135 posts
Given Likes: 381
08-06-2011, 09:27 PM
here it is...
[-] The following 16 users Like yucapareja's post:16 users Like yucapareja's post
  • nigema, malc, Jackass, devilmaycry, blaze, sodapas, subin91, knrsa, mastermind, pedzaquino, pmg814, kowheng, bigone, milova, ingchio, yly8
 devilmaycry
User ID: 27027
Threads: 54
Given Likes: 460
08-07-2011, 04:44 AM (This post was last modified: 08-07-2011, 04:51 AM by kowheng.)
Hi yucapareja, thank you for helping me out, I really appreciate what you did for me, just wanted to know if you could post me the entire AISC engineering journal of 2002 (please don't think that I'm greedy it's just that I need them), and if you couldn't that'll be fine, I still owe you alot for helping me out, thanks.
BestCutesmile
 devilmaycry
User ID: 27027
Threads: 54
Given Likes: 460
08-09-2011, 08:41 AM
Hi guys, I need these papers, they're in the AISC engineering journal of 2002, please if anyone has access to this journal help me out,thanks in advance:
A Technical Note: Comparison of Design Specifications for Design of Pipe and Round HSS
Pedestrian Guardrail Systems (Author: Sputo, Thomas)
Block Shear and Net Section Capacities of Structural Tees in Tension: Test Results and
Code Implications (Author: Epstein, Howard I.; Stamberg, Hans)
Composite Steel Joists (Author: Samuelson, David)
Design Concepts for Jib Cranes (Author: Fisher, James M.; Thomas, Steven J.)
Design Method for the Bolts in Bearing-Type Connections with Fillers (Author: Sheikh-Ibrahim, Firas I.)
Dynamic Amplitude Prediction for Ballroom Floors (Author: Hanagan, Linda M.)
Elastic Design Charts for the Rapid Selection of Web Bolts for Composite Steel Bridge Splices (Author: Sheikh-Ibrahim, Firas I.)
Errata & Addendum: AISC LRFD Rules for Block Shear in Bolted Connections--A Review (Author: Kulak, Geoffrey L.; Grondin, Gilbert Y.)
Flexural Capacity and Ductility of HPS-70W Bridge Girders (Author: Yakel, Aaron J.; Mans, Patrick; Azizinamini, Atorod)
Influence of Bolt-Line Eccentricity on WT Tension Member Capacity (Author: Barth, Karl E.; Orbison, James G.; Bartels, Peter A.)
New Fatigue Provisions for the Design of Crane Runway Girders (Author: Fisher , James M.; Van de Pas, Julius P.)
Perfobond Shear Connector for Composite Construction (Author: Medberry, Sara B.; Shahrooz, Bahram M.)
P-V-M Interaction Curves for Seismic Design of Steel Column Base Connections (Author: Arlekar, Jaswant N.; Murty, C.V.R.)
Relating the Seismic Drift Demands of SMRFs to Element Deformation Demands (Author: Gupta, Akshay; Krawinkler, Helmut)
Story-Based Effective Length Factors for Unbraced PR Frames (Author: Xu, Leiand; Liu, Yuxin)
Technical Note: Torsional Analysis of Steel Sections (Author: Moore II, William E.; Mueller, Keith)
Tension Field Action in Hybrid Steel Girders (Author: Barker, Michael G.; Hurst, Austin M; White, Donald W.)
The Effect of Bedding Layer on the Strength of Shear Connection in Full-Depth Precast Deck (Author: Kim, Jong-Hee; Shim, Chang-Su; Matsui, Shigeyuki; Chang, Sung-Pil)
Ultimate Strength Prying Models for Bolted T-stub Connections (Author: Swanson, James A.)
Using Moment and Axial Interaction Equations to Account for Moment and Shear Lag Effects in Tension Members (Author: Epstein, Howard I.; D'Aiuto, Christopher L.)
 Diquan
Costa Rica
User ID: 41
Threads: 23
Likes: 1,205 in 128 posts
Given Likes: 781
08-09-2011, 02:32 PM
Dear devilmaycry,
Here are your files:
[-] The following 19 users Like Diquan's post:19 users Like Diquan's post
  • cve_jule, Dell_Brett, mastermind, malc, ynopum, ting tsai huang, carolinandra, Jackass, HungNguyen29, pedzaquino, devilmaycry, sodapas, Albert, kowheng, slowet, bigone, milova, ska51, febo927
 devilmaycry
User ID: 27027
Threads: 54
Given Likes: 460
08-12-2011, 06:20 PM
Hi guys, I need these papers, they're in the AISC engineering journal of 2010, thanks in advance for the help:
Behavior of Vertical Boundary Elements in Steel Plate Shear Walls (Author: Qu, Bing; Bruneau, Michael)
Closure: Limit State Response of Composite Columns and Beam-Columns Part II: Application of Design Provisions for the 2005 AISC Specification (Author: Leon, Roberto T.; Perea, Tiziano; Hajjar, Jerome F.)
Current Steel Structures Research (Q2-2010) (Author: Bjorhovde, Reidar)
ht
Discussion: Limit State Response of Composite Columns and Beam-Columns Part II: Application of Design Provisions for the 2005 AISC Specification (Author: Geschwindner, Louis F.)
ht
Mathematical-Mechanical Model of WUF-B Connection Under Monotonic Load (Author: Yim, Hyun Chang; Krauthammer, Ted)
Stiffener Requirements to Prevent Edge Buckling (Author: Dowswell, Bo)
Tables for Eccentrically Loaded WT Shapes in Compression (Author: Gordon, Mark E)
A Strength Design Approach to Ponding (Author: Silver, Edward)
An Experimental Analysis of Strength and Ductility of High-Strength Fasteners (Author: Moore, Amy M.; Rassati, Gian A.; Swanson, James A.)
Current Steel Structures Research (Q3-2010) (Author: Bjorhovde, Reidar)
Limit States for Horizontal Shear at a Braced Frame Beam Flange (Author: Hungerford, Brent E.)
Single-Plate Shear Connection Design to Meet Structural Integrity Requirements (Author: Geschwindner, Louis F.; Gustafson, Kurt D.)
Transfer Forces in Steel Structures (Author: Dowswell, Bo)
Bending of Top Plates in Base Chair Connections (Author: Dowswell, Bo)
Closure: Critical Evaluation of Equivalent Moment Factor Procedures for Laterally Unsupported Beams (Author: Wong, Edward; Driver, Robert G.)
Current Steel Structures Research (Q4-2010) (Author: Bjorhovde, Reidar)
Design of Structural Steel Pipe Racks (Author: Drake, Richard M.; Walter, Robert J.)
Discussion: Critical Evaluation of Equivalent Moment Factor Procedures for Laterally Unsupported Beams (Author: Wilkerson, Steven)
Prediction of Bolted Connection Capacity for Block Shear Failures along Atypical Paths (Author: Cai, Qing; Drive, Robert G.)
 Diquan
Costa Rica
User ID: 41
Threads: 23
Given Likes: 781
08-12-2011, 10:53 PM
Dear devilmaycry,
[-] The following 16 users Like Diquan's post:16 users Like Diquan's post
  • mastermind, carolinandra, kowheng, malc, Jackass, Dell_Brett, unix0123, HungNguyen29, devilmaycry, sodapas, Albert, bigone, milova, subin91, ska51, febo927
 devilmaycry
User ID: 27027
Threads: 54
Given Likes: 460
08-15-2011, 05:59 PM
Hi guys, I need these papers, they're in the AISC engineering journal of 2000, thanks in advance for the help, I owe you alot:
A New Approach for Design of Steel Beam-Columns
Author: Aminmansour, Abbas
Design of Concrete-Filled Hollow Structural Steel Columns for Fire Endurance
Author: Kodur, Venkatesh K.R.; MacKinnon, David H.
Developments in Long Span Composite Slabs
Author: Widjaja, Budi R.; Easterling, W. Samuel
Errata: Beam-Column Base Plate Design (2)
Examination of AISC LRFD Shear Lag Design Provisions
Author: Kirkham, William J.; Miller, Thomas H.
Experiments on the Effects of Power Actuated Fasteners on the Strength of Open Web Steel Joists
Author: Engelhardt, Michael D.; Kates, Zachary; Beck, Hermann; Stasney, Blake
Gusset Plate Connection to Round HSS Tension Members
Author: Cheng, J.J.R.; Kulak, Goeffrey L.
Inelastic Design and Testing of Steel Bridges Comprising Noncompact Sections
Author: Hartnagel, Bryan A.; Barker, Michael G.
LRFD Beam-Column Graphical Design Aid
Author: Keil, William J.
Modeling of Support Conditions at the Bases of Tall Buildings
Author: Nair, R. Shankar
Nonlinear Analysis of Composite Steel Girder Bridges
Author: Deng, Linzhong; Ghosn, Michel
[-] The following 1 user Likes devilmaycry's post:1 user Likes devilmaycry's post
  • sodapas
 Diquan
Costa Rica
User ID: 41
Threads: 23
Given Likes: 781
08-16-2011, 04:53 PM
Dear devilmaycry,
[-] The following 14 users Like Diquan's post:14 users Like Diquan's post
  • malc, Dell_Brett, kowheng, devilmaycry, Albert, sodapas, Jackass, slowet, ISTRAKTURA, bigone, milova, subin91, ska51, febo927
 unix0123
User ID: 14411
Threads: 1
Likes: 99 in 15 posts
Given Likes: 55
#10
08-17-2011, 01:43 AM (This post was last modified: 08-17-2011, 02:21 AM by unix0123.)
Hi,
To complete the whole set of 2010 AISC Journals (Post #7), we only need these 2 papers:
Seismic Demand on Column Splices in Steel Moment Frames
Singly Symmetric Combination Section Crane Girder Design Aids
(08-17-2011, 01:43 AM)unix0123 Wrote: To complete the whole set of 2010 AISC Journals (Post #7), we only need these 2 papers:
Sorry, I forgot to say you can have Q1 (first quarter) of 2010 AISC Journal here:
[-] The following 3 users Like unix0123's post:3 users Like unix0123's post
  • bigone, milova, ska51
Pages (5): 1 2 3 4 5 Next »
  [REQUEST] AISC Papers devilmaycry 1 1,912 04-03-2013, 03:27 PM
Last Post: apocalipse
